Chris Denton | 05/06/2015 15:07:09 |
275 forum posts | I've been using aluminium for years. Today I used a piece that I bought from a seller on ebay, it's supposed to be 6082. When turned it cuts into small chips and powder. Any idea what it is? I've never seen aluminium like this before.
Andrew Johnston | 05/06/2015 15:22:10 |
![]() 7061 forum posts 719 photos | The chances of it being 6082 are probably zero; it is more likely to be ex-saucepan! Andrew |
Boiler Bri | 05/06/2015 15:58:53 |
![]() 856 forum posts 212 photos | Don't get it too hot, or else! 🚒 Bri |
Spanna | 05/06/2015 17:04:28 |
15 forum posts | That's a rough old finish too. Are you going fast enough |
Bowber | 05/06/2015 17:19:42 |
169 forum posts 24 photos | Looks like cast Ali to me, is your tip for Ali? Steve |
Thor 🇳🇴 | 05/06/2015 17:22:13 |
![]() 1766 forum posts 46 photos | Hi Chris, It may be a Pb - Bi alloyed free cutting aluminium. Newer free cutting alloys may have Sn - Bi or just Bi to avoid lead. Thor |
Bob Brown 1 | 05/06/2015 17:52:53 |
![]() 1022 forum posts 127 photos | Looking at the way it machines my money is on a 2000 series aluminium probably 2024, but not 6082 as I have machined lots of 6082, swarf without a chip breaker comes off in a spiral. What size 6082 do you need as I probably have a piece for the cost of postage. Bob
Chris Denton | 05/06/2015 19:44:40 |
275 forum posts | This was a 250mm bar, the ends were sawn so I think it came from a longer bar. The surface finish on the UN-cut bar is very good, minimal extrusion lines. Slightly darker colour to 6082, 6061, 7075. I don't think it's cast (extrusion lines) but could be 2000 series?
In the picture the cut taken was 2mm depth at 1000rpm 0.2mm feed with no lube, probably why it looks rough.
It's not particularly soft.
Maximum cut I could take was 5mm at 600rpm 0.2mm feed. Every speed / feed was producing similar chips, except for a 0.1mm cut at 1000rpm 0.1mm feed, which made very short spirals.
I've ordered another piece now thanks!
Clive Hartland | 05/06/2015 20:22:40 |
![]() 2929 forum posts 41 photos | The ends of extruded bars are sometimes discarded and not used, likely your Ebay supplier has been able to get these off cuts and now you are having problems. I have often found similar effect on stock bar I have bought and now cut off the first 2 to 3 inches. Maybe some one else has had this happen. Also I sometimes find that just under the skin, about 3 mm in a hard layer which does not machine well. Clive |
Chris Denton | 05/06/2015 23:11:35 |
275 forum posts | Possibly then. I'll put it in some caustic soda tomorrow and see what the smut is like. |
Jon | 07/06/2015 19:51:03 |
1001 forum posts 49 photos | 100% not 6082 that comes off continuous until broken up, I use it daily for best anodising and strength ratio. Free machining comes off exactly like pictured whether that's 2011T6 or 6262T6 no idea. Fine cut on after picky above will come off like chrome. Heavy cut with coolant and right tips can come off satin. Production or small batch work I wouldn't hesitate to use 2011T6 (T6 being harder)
Chris Denton | 07/06/2015 20:01:23 |
275 forum posts |
Thanks. 6061 & 6063 anodise the best but 6082 is very good The chips are fairly square on these, no matter the cut depth - your right! EDIT: just seen you said strength / anodising ratio for 6082 - so your right!
