Tubal Cain videos
Roger Hulett | 19/05/2015 21:35:25 |
131 forum posts 9 photos | When Tubal Cain describes the principles of gear cutting, he makes use of a "lathe mandrel". This is a slightly tapered mandrel. Does anyone know where these can be purchased, short of ordering from USA.I have looked at the regular Engineering suppliers,but to no avail. |
Muzzer | 19/05/2015 22:00:43 |
![]() 2904 forum posts 448 photos | Try expanding mandrels, available from the likes of Arc Euro, RDG Tools etc. |
John Haine | 19/05/2015 22:10:54 |
5563 forum posts 322 photos | Or make one. |
John Stevenson | 19/05/2015 22:15:37 |
![]() 5068 forum posts 3 photos | These are more suited for light work, grinding etc. Would not fancy using one on things like gear cutting with interrupted cuts. If you need a mandrel them make one as John says but hold the work with a big washer and nut. |
Lambton | 20/05/2015 06:08:58 |
![]() 694 forum posts 2 photos | These mandrels used to be made by Jones and Shipman and as JS says they are not really suitable for heavy work. However they are very useful for dealing with jobs that cannot be easily mounted other than buy an existing hole. They have very shallow tapers and so are size specific. The work has to be forced on and off using a mandrel press. I have some up to 5/8" and would like to get a few bigger ones but I have not found any source of them. They are occasionally advertised on eBay and fetch good prices. |
Thor 🇳🇴 | 20/05/2015 07:52:52 |
![]() 1766 forum posts 46 photos | Hi Roger, As John say, why not make one. I have made my own mandrels for cutting gears, I have tried to attach a photo that show a mandrel I made for cutting some module 1 gears in Delrin. The mandrel is intended to be used between centers. To make sure that the gear blank doesn't rotate on the mandrel I drilled a 2mm hole in the flange of the mandrel (red arrow) - using the washer you can see in the photo as a drilling jig. I also use the washer to dill a corresponding hole in the gear blank. A short piece of 2mm silver steel prevents the blank from rotating. The left end of the mandrel is threaded and I use the washer and a nut to clamp the blank. Thor |
Ian S C | 21/05/2015 06:40:41 |
![]() 7468 forum posts 230 photos | In my last year at school, we made a hand grinder, that required two gears to be cut, the large one was mounted on a taper mandrel, the small one was integral with the shaft. We made our own mandrels. For most work requiring a mandrel these days (not gear cutting), I turn a step on the end of a larger bit of shaft, drill and tap the end, put the artical on the mandrel, then bolt a substantial washer on the end of the shaft. Ian S C |
Neil Wyatt | 21/05/2015 11:35:37 |
![]() 19226 forum posts 749 photos 86 articles | I often make a split mandrel for things like that (assuming a decent sized hole). Make it a close fit, then drill the end and tap with the tip of a taper tap. Slot across, wind in a suitable screw and it grips much better. Neil |
Bowber | 21/05/2015 13:43:40 |
169 forum posts 24 photos | Posted by Neil Wyatt on 21/05/2015 11:35:37:
I often make a split mandrel for things like that (assuming a decent sized hole). Make it a close fit, then drill the end and tap with the tip of a taper tap. Slot across, wind in a suitable screw and it grips much better. Neil Exactly what I do as well, works very well and gets a good grip on the part. Steve |
Roger Hulett | 22/05/2015 15:27:10 |
131 forum posts 9 photos | I would like to thank everyone who has contributed to this thread. Very interesting.It was not so much about how to do a particular task,but why a product for doing that task is not readily available in UK wheras in USA they are cheap and widely available. Tubal Cain did make the point that when milling or gear cutting using one of these mandrels,because they were mounted against the cutting action,the tendency was to drive the gear further on to the mandrel,thus tightening it further. I take the point of unavailability further, Dave Gingery's book re dividing heads can be obtained in UK at a grossly inflated price , a 20DP,14.5PA,No 4 Involute gear cutter is rarer than hens teeth in UK,but 2 a penny (I exaggerate) in USA. What has happened to the great British engineering tradition ?? I suppose it has moved to Taiwan,China and India. Sorry Rant over |
John Stevenson | 22/05/2015 23:01:43 |
![]() 5068 forum posts 3 photos | Tracy tools stock that cutter. |
Roger Hulett | 23/05/2015 11:26:37 |
131 forum posts 9 photos | I phoned them last week to order two gear cutters,they supplied one but were out of stock with the other and didn't know when new stock would arrive. Same with RDG, 12 weeks until new stock arrives.
Tony Ray | 23/05/2015 16:31:51 |
238 forum posts 47 photos | Do have a look at Ivan Laws gear cutting book one of the workshop practise series. In it you will find details of how to make an accurate single point cutting tool. I have used involute and single point cutters and the latte does work very well. |
Bowber | 23/05/2015 17:54:10 |
169 forum posts 24 photos | Yes but they are a pain to make, I made one and then gave up and bought the next. Ok if you can't buy one though. Steve |
