Vertical Tailstock Alignment
David Cambridge | 29/04/2015 12:57:13 |
252 forum posts 68 photos | Last night I thought I’d go down the avenue of checking the alignment between my WM180 headstock and tailstock by putting a centre in both. Just by eye I can see it’s just a tiny fraction of a mm out in both the horizontal and vertical. I have some set screws to twiddle to fix things in the horizontal, but I can’t see how to fix the problem in the vertical. However, before I start worrying I read on some other forum that vertical misalignment makes no difference if I’m just turning a diameter. Is this really the case ?, and what do other people think as I can’t figure out why it would not be important? David |
JasonB | 29/04/2015 13:11:55 |
![]() 25215 forum posts 3105 photos 1 articles | If turning between centres with the tailstock end above or below ctr you will get a tapered piece of work that is larger at the tailstock end. Make sure there is no swarf trapped under the tailstock, MT sockets are clean and that the centres you are using are not off. Also when turning between ctrs there will be some pressure pushing against the tailstock which may be enough to lift a slightly sloppy fitting barrel so a static test may give a false reading.. |
Brian Wood | 29/04/2015 14:00:26 |
2742 forum posts 39 photos | Hello David, I don't know your model lathe but general principles apply irrespective of the machine involved. Don't believe the tripe you have read, alignment in both axes is important for parallel turning between centres and drilling down the central axis of a workpiece There are other tests you need to make. What happens to the alignment of the centres when the tailstock barrel is extended? I am looking for evidence of a nose down attitude here which would mean aiming a drill downwards into a job. This is different to being dispaced horizontally but still aiming along a line parallel with the lathe bed. Ideally you will need to measure as best you can how much these values are, a good DTI will show that and whether or not the situation gets worse with tailstock barrel extension. Correction Across the lathe bed you have the offset screws to move the tailstock laterally as a body. There is no such adjustment vertically and that will mean separating the bed shoe and tailstock body to shim up the front of the tailstock to correct nose down or shim the whole length of the tailstock to lift the body vertically Why has it happened? The most obvious cause is swarf being trapped under the bed shoe wearing down that component. Another possible cause is that the tailstock is not the original fitting and has been changed. You can correct it as indicated, examination of the bed shoe with the tailstock off the lathe might be instructive. I hope this brief reply helps you Brian
Edited By Brian Wood on 29/04/2015 14:03:03 Edited By Brian Wood on 29/04/2015 14:03:30 |
Dinosaur Engineer | 29/04/2015 14:21:07 |
147 forum posts 4 photos | lathe manufacturers purposely apply the tailstock height tolerance so that it may be a little high . This is to allow for wear. A small height error will have an almost negligible effect on the diameter being turned. |
JasonB | 29/04/2015 14:36:50 |
![]() 25215 forum posts 3105 photos 1 articles | The error is very much dependant on the dia being turned eg on a 3mm shaft a 0.1mm height error gives about the same diameter error but a 0.2mm height error gives a 0.3mm diameter error, almost 10% which is maybe a bit more than negligable and it gets progressively worse. In practical terms this would be 10thou play in the fit of an IC engine valves which would have a big effect on a 30mm shaft 0.1mm height error gives only 0.001mm on dia and .003mm for the 0.2mm height so these would be considered negligable Edited By JasonB on 29/04/2015 14:38:46 |
paul 1950 | 29/04/2015 14:37:08 |
143 forum posts 32 photos | Posted by Dinosaur Engineer on 29/04/2015 14:21:07:
lathe manufacturers purposely apply the tailstock height tolerance so that it may be a little high . This is to allow for wear. A small height error will have an almost negligible effect on the diameter being turned. so that is why my 50 year old lathe is spot on then |
Speedy Builder5 | 29/04/2015 15:07:00 |
2878 forum posts 248 photos | Tailstock too high or headstock too low ??? Or do they even have parallel axis (axes ?) Are you making the test with the tailstockclamp tightened to take out any play there. Is there any scarf / burrs inside the morse tapers of both tail and head stocks ? How accurate are your centres ? And as Paul says, height error is less important than horizontal error. I think I would turn a steel bar (about 30 mm diameter) between centres and see what runout you had over its length and check this with the tolerances as stated on the acceptance test certificate. |
FMES | 29/04/2015 17:50:55 |
608 forum posts 2 photos | Posted by David Cambridge on 29/04/2015 12:57:13:
Just by eye I can see it’s just a tiny fraction of a mm out in both the horizontal and vertical. David How about checking it properly rather than by eye? The eye can see light through a virtually immeasureable gap so it would be better to get a between centers parallel and check it with a DTI over a set distance. Might not be out as much as you think. |
David Cambridge | 29/04/2015 22:06:56 |
252 forum posts 68 photos | I’ve always had a slight miss-alignment since I bought the lathe new last August, but its only with a bit more knowledge and curiosity that I’ve started to worry about such things. I tried taking a photo to show you all, but the camera exaggerates the problem and makes it look far worse than that it actually is – suffice to say the tailstock seems to be fractionally higher than the headstock. I’ve cleaned things down , so I don’t think it’s a problem with swarf. It could of course be the centre as I don’t have another one to try. There does seem to be a school of thought that it’s by accident rather than design that the tail stock is higher so maybe all is well? Regardless, and as suggested, this weekend I’ll try and measure it and compare with different extensions of the tailstock. Do you think I’m OK using a silver steel bar as I don’t have a test bar ? David |
Hopper | 30/04/2015 06:39:41 |
![]() 7881 forum posts 397 photos | Back in the days of yore, many lathes were made with the tailstock a few thousandths of an inch higher than the spindle centre, to allow for wear on the tailstock and base and bed over the years. You really need to measure up everything carefully with a good dial indicator etc as mentioned already before you start ripping into things. One quick test is to turn a cylinder between centres using a very fine finishing cut and measure if it is tapered one end to the other. If it is not too bad, there is not much to worry about. If it is tapered too much, first thing is to adjust the horizontal position of the tailstock until it turns a nice true cylinder without taper. If you can;t get it to do that, then it might be time to look at further adjustments etc. |
JasonB | 30/04/2015 07:39:44 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by David Cambridge on 29/04/2015 22:06:56:
Just try them in a few different positions and see if you get the same error. Edited By JasonB on 30/04/2015 07:39:58 |
Neil Wyatt | 30/04/2015 08:07:35 |
![]() 19226 forum posts 749 photos 86 articles | Fit a DTI in the toolpost and extend the tailstock barrel fully and lock it. Move the saddle so you can take readings along the top of the barrel. this will show if it is tilted up or down. If you get an MT blank that will fit the tailstock, try this: Fit the blank in the headstock (using a sleeve if required). Test it for concentricity with the DTI. If its OK then take a dti reading off the top of it, pop it in the tailstock and take another reading off the top of it. Bear in mind there could be added error from having to use a sleeve. These are Dr Schelsinger's tests for the tailstock for finish turning lathes (brackets is direction of permissible error): Parallel with bed in vertical plane (front end rising) 0 to 0.02 per 100mm Ditto in horizontal plane (towards tool pressure) 0 to 0.01 per 100mm Cone of sleeve parallel with bed in vertical plane (i.e. test bar in tailstock) (free end rising) 0 to 0.03 per 300mm Ditto in horizontal plane (towards tool pressure) 0 to 0.02 per 300mm Axis of centres (mandrel between centres) parallel with bed in vertical plane (mandrel rising towards tailstock) 0 to 0.02 The final one of these is the main one we are looking at, and 0.02mm (0.001" Neil
Les Jones 1 | 30/04/2015 08:31:11 |
2292 forum posts 159 photos | Hi David, Les. |
David Cambridge | 30/04/2015 22:53:53 |
252 forum posts 68 photos | One evening of obsessive measuring later, and it’s all very interesting. Using a dial indicator and either of my cheap ebay live centres and mounting them in the tail stock, and using the Warco supplied dead centre in the head stock, I get over a 25 cm length of 14 mm diameter silver steel: In the horizontal: 0.03 mm Using a dial indicator and the Warco supplied dead centre in the tail stock, and using the Warco supplied dead centre in the head stock, I get over a 25 cm length of 14 mm diameter silver steel: In the horizontal: too small to measure I think that adds weight to the thought ‘measure it as it might not be as bad as you think’ as it looks massively worse by eye. I then drew myself a diagram to figure out what difference does 0.1mm vertical error mean to turning a 5mm diameter. The black line represents centre height. The red line represents the bar at the headstock end, the green line represents the bar at the tailstock end and displaced down by 0.1mm. Much to my surprise, but kind of obvious when you draw it, the 0.1 mm height difference at the vertical extremes accounts for a 0.002 mm difference at the horizontal extremes (where the cutting tool is). In short, unless anyone thinks I’ve missed something (entirely possible!), then I’m inclined not to give it any more thought ? David
David |
Ed Duffner | 01/05/2015 06:21:23 |
863 forum posts 104 photos | Hi David, I have the same lathe. Have you turned a length of material and measured the diameter at each end ? Personally I wouldn't trust that the tailstock quill remains on centre when fully extended and hope that it centre's a work piece. I'd keep the quill as short (un-extended) as possible when used as a centre support. Ed. |
Michael Gilligan | 01/05/2015 07:27:22 |
![]() 23121 forum posts 1360 photos | David, It looks good enough for 'real world' machining ! Your thorough inspection has highlighted the fact [well known to Dr Schlesinger] that a solid bar sags considerably under its own weight. Schlesinger used test bars cored-out in steps, to reduce the effect. MichaelG. |
