Rolling Road
Exmoor30920/04/2015 20:36:08
25 forum posts
5 photos
Hi all,
I'm looking to make a rolling road for my 7 1/4" gauge Tich. Are there any published designs for such a thing? I tried a search, but it came up with nothing unfortunately!
Exmoor
Ady121/04/2015 00:23:55
6137 forum posts
893 photos
I found nothing. Engineering in Miniature 25-1(July 2003) has one at a show, but I can find no plans
Edited By Ady1 on 21/04/2015 00:35:25
neville rigg 121/04/2015 01:53:53
24 forum posts
ahi, I am in the process of making one myself, two pieces of angle iron with holes in each about one and a quarter inches apart bearings out of a pair of roller blade skates, thjese are five sixteenth bore and about one inch o,d. useing threaded rod as spacers come axles, this allows you to adjust tracking for whatever gauge required, the roller blades came from a thrift shop, five dollars for sixteen bearings and eight rubber wheels for saving, and some aluminium for melting down.
Neville
Neil Wyatt21/04/2015 08:10:21
19226 forum posts
749 photos
86 articles
I'm sure I've seen at least two designs in ME.
Clive India21/04/2015 09:11:10
277 forum posts
You can buy here **LINK**
If not wishing to buy, it should not be difficult to work out dimensions
Edited By Clive India on 21/04/2015 09:12:41
Exmoor30921/04/2015 20:40:04
25 forum posts
5 photos
Thanks for all your replies chaps. I'm going to follow suit with you Neville and go down the lines of angle with ball bearings bolted on, although not out of roller blade skates!
Thanks again!
Exmoor
Bazyle22/04/2015 00:30:22
6956 forum posts
229 photos
Do yourself a favour (well your friends) and make 3 axles worth. laugh
Referring to clive's link photo. Instead of the axle between rollers just bolt them to the angle iron, but turn the angle inwards. Then bolt the angle to a plate to seatablish width. The plate is drilled for multiple guages. this keeps the centre section free to drop the grate more easily on some designs.
