Member postings for neville rigg 1
Here is a list of all the postings neville rigg 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Oscillating saws
11/03/2017 13:06:53
Hi Ady,
Had one of those for couple of years, well worth the money, not done a lot of metalwork, cut rusty nails etc. with a diamond cutter/
regards neville
Thread: Wanted: Plan for loco screw regulator
05/03/2017 21:59:25
Hi Greg
Try the one in LBSC's Princess Marina construction book, it may give you some food for thought.
Regards Neville.
Thread: What Did You Do Today (2016)
30/12/2016 09:45:42
Hi Brian
I seem to remember a similar situation about 50 years ago with a KSS Velo, may be wrong but it rings a bell,
surprising what pops out of the memory.
Neville
Thread: Taps and Files
24/10/2016 15:37:13
Hi Clive
I have a couple of files by Nicholson one stamped black diamond made in U S A about thirty years old and one I bought maybe three years ago but stamped Nicholson Made in Mexico, no complaints about either but maybe the second one won't last that length of time, progress and globalisation?
Neville.
Thread: Postage zones in the UK.
02/08/2016 02:23:17
Dod, They probably think they will use less energy as it is down hill
16/07/2016 20:34:41
Get used to it if you can, I get asked for I.D. in the local store in the U.S. and I'm 76.
Edited By JasonB on 16/07/2016 20:38:53
Thread: Knocked out big end bearing repair , Alf Francis?
01/07/2016 02:57:42
Hi, hacksaw,
You are correct, it is in his autobiography, a good read, must find it on the shelves and re-read it.
Neville
Thread: Might be time to change the car blues
01/07/2016 02:54:27
Hi Martin,
Would think twice about a freelander, reliability could be a problem, maybe they have cured this with the mark,2.
would check on the web in the land rover forums, including the U S ones, seen quotes for ten to fifteen dollars to rebuild engines in discovery to make it reliable over 100k milage,
best of luck Neville
Thread: Acids
01/09/2015 21:33:18
JA In my days as a photographer I used to dip pennies into the exhausted fixer for a few minutes they came out silver plated, we also had to mix the used fixer with sawdust and send it off to reclaim the silver.re"> Neville.
Thread: Rolling Road
21/04/2015 01:53:53
ahi, I am in the process of making one myself, two pieces of angle iron with holes in each about one and a quarter inches apart bearings out of a pair of roller blade skates, thjese are five sixteenth bore and about one inch o,d. useing threaded rod as spacers come axles, this allows you to adjust tracking for whatever gauge required, the roller blades came from a thrift shop, five dollars for sixteen bearings and eight rubber wheels for saving, and some aluminium for melting down.
Neville
Thread: Choice of Steel Grade?
12/03/2015 15:01:54
Hi Graham, We used to rally an Imp in Northern Ireland in the late sixties where you could close the roads and have mixed stages, your remark about the forward radiator brought back even more memories, our Imp was an ex-works with twin DCOE's , forward petrol tank complete with brush handle to dip it as no fuel gauge, with the front radiator as well as the rear the only way to bleed the system was to raise the front up about three feet, wish I still had it. Heard about ten years ago it was still being used oin the south of Ireland for auto tests.Oh happy days.
Neville
Thread: Where to buy quick release nuts?
01/01/2015 17:50:30
Chris, One of the problems with shipping from yhe U.S.A is the method that most or the companies employ, a few years ago my son ordered a computer and had it shipped to my address in Atlanta for me to forward on to him, I explained to him that the easiest way was by U.S postal service, a method I had used a number of times with presents etc. However he insisted on using UPS, we had an account with them so it was no problem.
The next call we had from him was to inform us that he had a call from cutoms and excise for a sum of money for import duty. When shipping international via UPS the details are automatically sent to customs and thus the request, when sending by post it is not done automatically, so many times the parcel is not entered into the system.This was the only time I havehad troubles with customs when shipping from U.S.A
Neville.
Thread: Quit while you are ahead!
19/10/2014 15:59:34
Hi all, I worked on the installation of a extrusion press for use with magnesium a d the safety lecture was go nowhere near it with water, only sand in case of a fire and call the fire service.
Neville
Thread: CovMac Lathes
01/10/2014 06:08:48
Chris, the trouble with chains is there is no warning before they go, I would never use them on any machinery, O.K. for steelwork and pipework.
Neville.
01/10/2014 04:02:37
Hi Chris, I trust that you are not going to use the shakle on the rope as the pic suggests, Get two slings and put the eyes on the ends on thee hook of the lift, the way you have it the rope is very likely to slip if the load is not evenly balanced, looking at the machine I get the impression that it is going to be heavier at the headstock end you would be much better with slings, these are available in various lengths and it may be easier to have two of different lengths in order to balance it better.
A engineer supply company would be your best bet to obtain them and if you grovel you might be able to return them if they have not been used, check it out first, they may have skates for hire if your lucky.I used to remove and re-install ali extrusion presses which are a little bit heavier but the basic peinciples are the same, just take it slowly.
Neville.
Thread: Strange colour change in aluminium.
28/04/2014 20:48:22
Chris, you need to find an extrusion plant that uses a piercer press for tube, these presses punch a hole right t
hrough the billet before it is extruded through the die, not many in U.K. now I'm afraid Neville.
Thread: The Glory Days of British Motorbikes
03/04/2014 03:55:02
Gordon, If I remember the chain line did not cause a great problem, turn the teeth off the Norton brake drum and sprocket and fasten the velo sprocket on the outer face, the differance in chain width came out O.K. up to 3/8 from 1/4, never broke a chain, maybe just lucky, can't remember if I had to put spacers on the frame/engine bolts. neville
02/04/2014 02:15:32
Featherbed frames, happy days, the last one I owned I put a ohc Velo in it, superb.
Neville
Thread: from the back cover of MEW 214
12/03/2014 03:34:51
Neil, you surprise me that the worm is worn and not the gear, usually the worm is steel and the gear brass or bronze and it is the gear that wears. I have had no experience of this box but of the ones I have done on tube mills and roll formers this has always been the case. As regards the colour of the oil in the box I remember one mill that we opened to change the bearings that was the colour of oil, the mill manager when showed this said that was the colour whenit was filled, I cannot remember the name of the oil it is a number of years since I worked on roll formers etc but boy was it sticky, the gears etc were in perfect condition.
Neville.
Thread: Delay in availability of SIEG machines from ARC
15/11/2013 03:01:25
Stuffing containors is not all that bad if the stuff is palletised and one has a weighscale in the plant, it becomes alittle harder if the machine weighs maybe 18 or 20 tons and is heavier at one end with brackets and things sticking out so it cannot be placed centrally in the containor, we used to ask every one on site for a weight and take the average but it might be a case of shipping a lot of fresh air. If the waggon had not come back after a couple of hours at least you were not over weight, I could write a book about the joys of removing and shipping extrusion presses in various parts of the world. Neville.
