kevin large | 08/04/2015 19:23:50 |
143 forum posts 3 photos | I have a warco 220 at some point its had anew motor fitted and not been wired up properly if I cut threads do I need the reverse or is it OK to move the tool back manually I've had a couple of people look at the wiring but don't seem to fathem how it should work . |
Capstan Speaking | 08/04/2015 19:44:57 |
![]() 177 forum posts 14 photos | In a word . . . maybe It depends on the pitch being cut and whether you have an indicator dial. Do you have a manual? |
jann west | 08/04/2015 20:28:43 |
106 forum posts | reverse makes thread cutting a hellofalot easier ... also unwinding your tie when it gets caught in your workpiece |
Chris Hembry | 08/04/2015 20:52:50 |
52 forum posts 1 photos | Hi Kevin, In short, yes you do. Warco 220s do not have an indicator dial as the leadscrew is permanently engaged on the carriage handwheel. For all threading, the lathe must be reversed to run back. If the engagement lever is lifted, you stand no chance of picking up the thread again. I have the wiring diagram for the lathe and it is fairly simple to arrange the motor to run in reverse if it is the same type as the original.
Regards, Chris |
Bob Brown 1 | 08/04/2015 21:02:04 |
![]() 1022 forum posts 127 photos | It is also possible to turn the chuck backwards by hand, needs must when the devil drives. Bob |
Les Jones 1 | 08/04/2015 22:27:47 |
2292 forum posts 159 photos | Hi Kevin, Les.
Edited By Les Jones 1 on 08/04/2015 22:37:25 |
kevin large | 09/04/2015 07:11:08 |
143 forum posts 3 photos | Hi I don't know if the motor is the same as original but its a 3 phase wired as a single phase it has 2 capacitators its been wired as is shown in the lid and uses 2 bridges 2 of the wires from the motor have been cut off I have a diagram from a CD but not sure if its applicable to my machine and it doesn't show what wire is what and what goes to z1 z2 etc or where the caps connect Oh it does have the panic button but no red and green button in box on the end and no micro switches it looks like 4 wires and earth coming from the forward and reverse switch Chris if you could email your wiring diagram I could see if it makes sense to me |
Les Jones 1 | 09/04/2015 08:40:57 |
2292 forum posts 159 photos | Hi Kevin, Les. |
kevin large | 09/04/2015 09:57:33 |
143 forum posts 3 photos | Hi les I am only going by what I was told about the motor the plate is very difficult to see its on the inside I will try and see what it says kevin |
Nicholas Farr | 09/04/2015 10:31:14 |
![]() 3988 forum posts 1799 photos | Hi Kevin, there is a wiring diagram for both single phase and three phase, both should have a contactor box with a start and stop button. This box should be connected in line with the forward/reverse lever. The contactor box is a NVR which will stop the lathe from restarting automatically in the event of a power failure, it can be seen in the scan below, attached to the right hand end of the splash back. I have a PDF of the user manual with both circuits in, if you would like a copy PM me with an e-mail address. Regards Nick. |
Ian S C | 09/04/2015 11:06:01 |
![]() 7468 forum posts 230 photos | I think you'll find it's single phase, 110V/230V. My Taiwanese lathe is wired this way as a dual voltage motor, and the circuit diagram Is on the LH end of the bed, it also has the diagram of the 3 phase option. Ian S C |
