John Millis | 19/03/2015 16:28:20 |
16 forum posts 6 photos | I have purchased the kit from Brunell and at long last received most of it and about to start manufacture. As the kit uses castings in lieu of fabrication which is the basis of the original ME article which come as build instructions. I am looking for any advice that anybody who has built the engine can give me also where can one obtain the square nuts and bolts as the supplier in the article does not do them any more All suggestions and advice would be appreciated as this is my first attempt into building a working model since my apprenticeship 50 years ago |
JasonB | 19/03/2015 17:36:52 |
![]() 25215 forum posts 3105 photos 1 articles | Welcome John, I've not built one myself though quite fancy doing it at a larger size. I was talking with a chap who has a very nice one and he said there is a problem with the valve gear as drawn but I'm not sure what. As for square fixings its really a case of making them yourself. One of the German ME suppliers does do square ones but I'm not over keen on the size of the chamfers and they will also be metric not BA as per the drawings.
EDIT, these look OK but no photo
J Edited By JasonB on 19/03/2015 18:39:54 |
Saxalby | 19/03/2015 19:34:52 |
![]() 187 forum posts 33 photos | I built mine from the original ME article. It turned out a nice little engine. I do not remember any problem with the valve gear. The only problem I had was in getting the two crosshead columns parallel. Once that was sorted out it ran very smoothly. I made all my own square nuts and bolts from a suitable square bar. Drill and tap as deep as I could and then chamfer and part off the nuts. Did not take long. Like Jason, have always fancied doing a larger (2X) version. |
steamdave | 19/03/2015 22:29:58 |
526 forum posts 45 photos | Posted by JasonB on 19/03/2015 17:36:52:
Welcome John, I've not built one myself though quite fancy doing it at a larger size. I was talking with a chap who has a very nice one and he said there is a problem with the valve gear as drawn but I'm not sure what. As for square fixings its really a case of making them yourself. One of the German ME suppliers does do square ones but I'm not over keen on the size of the chamfers and they will also be metric not BA as per the drawings. EDIT, these look OK but no photo J The 1/8 boiler is a fair ol' lump. (part of THE list you know about, JB) Dave |
Paul Horth | 23/01/2016 19:20:44 |
69 forum posts 18 photos | Hello, I haven't used the forum for a while, just found this thread. I thought I would mention that I have nearly completed a Trevithick engine, it has been running well on air for some months now, there is no problem with the valve gear. I fabricated the boiler and the crosshead as decribed by Tubal Cain. I bought a range of square nuts from the German supplier, with matching metric bolts, I have made square headed bolts by silver soldering the nuts on the other ends. I also have made various square nuts in BA sizes as needed so I have a mixture, I have to keep notes to remember where they all go. I have made a working water pump, piping and check valve, and I am approaching making a gas burner. I am making a functioning level gauge, I imagine this to have been retrofitted by an engine room foreman in the 1820s. I am perhaps over optimistic that all these little bits will function in steam under pressure. Paul |
OldMetaller | 24/01/2016 07:34:40 |
![]() 208 forum posts 25 photos | Paul, I'd love to see some pictures. I've got the build article somewhere, I've always fancied doing one of these. Regards, John. |
Paul Horth | 24/01/2016 21:39:25 |
69 forum posts 18 photos | John, Thanks for your interest. I have tried to upload some photos but they won't go, the connection keeps timing out. So I have an album which is empty. I will try again later. Paul |
Neil Wyatt | 24/01/2016 22:21:02 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Paul Horth on 24/01/2016 21:39:25:
John, Thanks for your interest. I have tried to upload some photos but they won't go, the connection keeps timing out. So I have an album which is empty. I will try again later. Paul That probably means the total size is too great Try uploading one at a time. Neil |
Paul Horth | 25/01/2016 10:23:59 |
69 forum posts 18 photos | Thanks for the tip, Neil - it worked. I have now uploaded some photos into the album titled "Paul's Trevithick Engine". I resized my photos down from about 2 MB to about 300kB, and then I could upload them one at a time. As you can tell, I am new to this photo uploading game, being stranded in the technology of 200 years ago. Paul
Neil Wyatt | 25/01/2016 14:02:12 |
![]() 19226 forum posts 749 photos 86 articles | You can upload 2 meg photos one at a time - they will be resized to 1024 pixels along the longest edge. You could upload 5 300kb images, but 5 2megs at once will be bigger than the maximum uploiad. Neil |
OldMetaller | 26/01/2016 08:31:32 |
![]() 208 forum posts 25 photos | Thanks for uploading the photos Paul, that looks like a very nice engine. I think I especially like the Trevithick engine as I have a very early memory of being taken to the Science Museum in London and seeing this engine in profile as we entered the gallery where it was kept- it was the first historical engine I'd ever seen and I still get a frisson every time I see it! Regards, John. |
Paul Horth | 26/01/2016 21:01:32 |
69 forum posts 18 photos | Hello John, I am retired, and live only a half hour tube ride from the Science Museum, so I visit there often, usually staying on the ground floor. I have looked carefully at the Trevithick engine there, and have a lot of photos, unfortunately they are not very good because the engine is black,and is poorly illuminated. To see the works on top, you have to go up to a balcony where a couple of spotlights are aimed directly into the camera, making the details come out dark. In the model series, Tubal Cain said that when the engine was rescued from a Victorian scrapyard, various mistakes were made in the restoration. Over 100 engines were built under licence, and I'm sure that each was slightly different,according to the builder's judgment and what the client specified, so I'm relaxed about making a few changes of my own. The Science Museum is for me a wonderful temple of engineering and design, so much to see there. Regards Paul |
OldMetaller | 27/01/2016 12:50:37 |
![]() 208 forum posts 25 photos | I sometimes get an hour or two in London: last year I managed a whopping 14 minutes in the Science Museum! Time enough to walk round the Trevithick engine, watch them start the big mill engine and pay my respects to the Rocket- I even managed a surreptitious touch on the left hand cylinder as the security guards were distracted by the thousands of children milling about! I don't remember being allowed to run about screaming when I was taken there as a child..? At least, I think I'd have remembered the resultant thick ear that I would have collected! Regards, John. |
Paul Horth | 15/02/2016 14:11:57 |
69 forum posts 18 photos | I have now fitted a level gauge to the boiler, see my photo album. I hope that it will eventually function. The tube is 3 mm biro tube - very readily available and unbreakable, but it is rather cloudy. If I can find some 3mm glass I will use that. I discovered to my surprise that not all biro tube is the same size! Seems to range from 0.125 down to 0.109 or so. I have reamed the firttings to take 0.117 (3mm) with end seals. Paul |
John Millis | 13/03/2016 19:36:02 |
16 forum posts 6 photos | Just an update to my original post. Progress is slow but 2 months in Australia don't help. I'm currently machining the boiler end casting and having to invent ways to hold the casting on my mini lathe and mill. Picking up on a comment in the posts I believe Brunnel are considering a X2 version of the kit. John
Paul Horth | 29/04/2017 19:59:17 |
69 forum posts 18 photos | Hello all, A year later - and at last I have raised steam on the Trevithick engine. Progress was slowed down by various factors including medical ones. I had two goes at making a burner, then a little fan to keep it alight inside the boiler tube. I spent a lot of time fiddling with the pump valves to get reliable pumping, with only partial success. But now it has run on steam, in a frantic burst of about two minutes, Difficult to throttle between rhe clappers and stop. There now follows a period of debugging, and making the finished deck to go on the plinth, with all the piping and water tank below the deck. I've put up a few new photos in my album. Paul |
Neil Wyatt | 29/04/2017 20:38:12 |
![]() 19226 forum posts 749 photos 86 articles | Excellent news! I look forward to seeing it on wheels. Neil
Paul Horth | 29/04/2017 20:50:53 |
69 forum posts 18 photos | Yeah right.........that sounds like what Mrs Trevithick would have said to Richard. then he did it - and the result was totally bonkers! |
Neil Wyatt | 29/04/2017 22:23:38 |
![]() 19226 forum posts 749 photos 86 articles | Doh! Apologies - I have the Airfix model of Trevethick's Pen-y-Darren loco and of course the engine part is almost identical! Neil |
Paul Horth | 30/04/2017 09:53:42 |
69 forum posts 18 photos | Hi Neil, I had forgotten about Pen-y-Darren, I was thinking of the "Puffing Devil" , the crazy road engine which Trevithick drove up Camborne Hill in about 1801. It's basically just the dredger engine on wheels, vertical connecting rods linked directly to a pair of wooden cartwheels. A replica has been built which is run on Trevithick Day, with operaors desperately clinging on while trying to steer and avoid being burnt by the chimney or pulped by the moving parts. I've put up a photo of it, but no. I'm not going to build that. Paul |
