Which Loctite
Howard Lyne01/03/2015 11:14:42
29 forum posts
In "Model Steam Locomotives" by Tim Coles he suggests using Loctite to construct the water tanks of a tank engine. This seems an admirable suggestion to lessen the labour involved but which Loctite should be used? I imagine it would have to be gap-filling otherwise leaks would be difficult to avoid. Can anyone help? Is this such a good idea?
Thanks in anticipation
Mark C01/03/2015 11:24:43
707 forum posts
Howard,
I know nothing of building trains etc. but I would take a guess that you are asking for Locktite 330. It is a two part (spray an activator on one surface, glue on the other) product and sticks like nothing else if you do the prep correctly. It is very expensive - not much change out of 20 quid but it is worth the money.
Mark
Russell Eberhardt01/03/2015 11:25:02
2785 forum posts
87 photos
I would think one of the two part polyurethane adhesives would be best. They are waterproof (used on boats) and have slight flexibility so won't crack.
Russell.
Michael Gilligan01/03/2015 12:48:12
23121 forum posts
1360 photos
Posted by Howard Lyne on 01/03/2015 11:14:42:
Howard,
As will be obvious from the other replies ... The suggestion my Mr Coles is not sufficiently detailed.
Loctite is a brand name, not a specific product.
Howard Lyne01/03/2015 13:04:10
29 forum posts
Thanks everyone. My own researches on Google suggest Loctite 3090 may also be suitable but there are so many of them out there (including alternative brands) it is difficult to choose between them all. 330 sounds interesting and if it saves a lot of rivetting and/or soldering would be worth the expense.
Gordon W01/03/2015 13:45:21
2011 forum posts
I have never built a loco tank, but I would guess that soft solder may be easier than trying to glue the joints . Solder will last forever and is easy on clean metal.
Ian Parkin01/03/2015 13:47:35
1174 forum posts
303 photos
Loctite 303 is great
I was advised to use this by a salesman to repair some stainless steel water trays that held a mild acid solution ..they had sprung open on a joint.
It was expensive but a little goes a long way
its a tube of glue like uhu consistency and a spray activator
Before i started I tried it on some stainless sheet scrap
2 pieces 3 x 3 " and glued them overlaping about 1/2" they did not want to come apart when cured
even with one side in a vice the material bent rather than the joint failed...it took serious effort to break the joint with a chisel down the joint
Ian
Mark C01/03/2015 14:04:27
707 forum posts
Ian,
The 303 sounds very similar to 330 - they are both acrylic based and the physical descriptions sound about the same (I have used the 330). The 303 is aimed at composite materials I think looking at the spec. I spoke to the Loctite tech support as I need to bond aluminium (not the easiest thing in the world) and they advised 330 with a special surface treatment to convert the oxide layer (not an acid etch). The 303 has a tensile rating of about 24 Nmm2 if I remember correctly putting it at close to half the tensile for the Aluminium alloy I am using!
The 303 looks to be aimed at fast UV cure rather as well, I don't know if that applies to 330 but I imagine it would be hard to do uv cure on a metal joint?
Mark
stan pearson 101/03/2015 22:22:37
135 forum posts
Hi Howard
If you go to Loctite.co.uk you can search there full range of products or you can email them as I did and they will answer your question.
Howard Lyne02/03/2015 19:37:04
29 forum posts
I e-mailed Loctite and was impressed by the speed of their reply. They suggested Teroson MS939 or, as a cheaper alternative, Unibond FT101. I'm not sure about these as they appear to be more like sealants. However, I shall see how their speciofications match up against 330/303, which appears to be the consensus here, and then decide whether to try one or go down the more traditional route of soldering.
Thanks for your help
Mark C02/03/2015 20:23:51
707 forum posts
Howard,
I might take the advice from Locktite - the stuff they suggest is very elastic and the 330 (and probably the 303) is not. I can see why they would recommend it.
Mark
andrew winks03/03/2015 22:12:15
117 forum posts
Just my 2 c worth. Tim Coles book is a great read but I've learned to take some of the comments in the book with a grain of salt!
For my tender construction, I used 306 stainless sheet, brass angle screwed with a few brass screws in a few places and soft soldered to seal it all up. I love using Loctite for retaining nuts and screws and the unbeatable thread sealing compound but can't get comfortable using the sealant range. (yet)
Cheers, Andrew
