ian j | 01/02/2015 13:59:53 |
![]() 337 forum posts 371 photos | Hi. I have a small (1/8HP) capacitor start capacitor run motor which I have fitted to my (nearly) completed Bonelle T & C grinder. At the moment I have it wired through two DPST switches, one for CW/CCW and the other for ON/OFF. What I really want to do is to have just one DPDT ( centre off ) switch wired to the motor. Below is the connections shown on the terminal lid Thank you Ian
Les Jones 1 | 01/02/2015 14:11:24 |
2292 forum posts 159 photos | Hi Ian, Les. |
frank brown | 01/02/2015 14:17:15 |
436 forum posts 5 photos | No connection diagram. I do not think you have enough connections for what you want. To reverse the motor, you have to reverse the L and N connections to the start circuit (motor winding plus start capacitor in series), so this will use 2 poles (L&N) to start circuit (say R & B and B & R). But you have not got another pole to break the L to the run winding . One way of doing it would be to get a relay with a coil that works on the mains voltage and wire it across the start circuit. and wire its contacts between the L and the run coil of the motor. So when the CW/CWW switch is in the centre, no supply to the start, relay is then off and no supply to run windings. If the CW/CWW switch is moved , mains goes on start winding and relay coil, relay pulls in and mains goes on the run winding. Frank |
ian j | 01/02/2015 14:37:57 |
![]() 337 forum posts 371 photos | Hi. Sorry about the missing picture. Here it is ? Les. Yes both switches are DPST . I can't remember how I did !! I will go & have a look now.
ian j | 01/02/2015 14:48:13 |
![]() 337 forum posts 371 photos | Les. Your dead right the ON/OFF switch is DPST and the CW/CCW is DPDT ( not centre off). Sorry for the confusion. Ian |
Les Jones 1 | 01/02/2015 15:08:54 |
Gray62 | 01/02/2015 15:13:16 |
1058 forum posts 16 photos | Hemingway kits sell a suitable rotary switch for reversing this type of motor, used on their Worden Grinder. Not cheap at £36 but does the job very well. |
Les Jones 1 | 01/02/2015 15:39:26 |
ian j | 01/02/2015 17:39:01 |
![]() 337 forum posts 371 photos | Thanks all for your replies. I've managed to find a source of 3PDT toggle switches:- based in Scotland ( you can get 5 of the same off eBay for £10 free postage. but I don't need 5 !!) :- **LINK** This seems to me to be the uncomplicated and cheapest way to go. Having said that. Les how would I connect the switch to the motor? Any way it's passed a cold Sunday afternoon. is it an age thing that I use to be in the workshop on colder days than today?
Regards Ian |
Johnboy25 | 01/02/2015 17:40:16 |
![]() 260 forum posts 3 photos | Ian... If you want a three pole toggle switch take look at the Arrow switch website. **LINK**# John Edited By Johnboy25 on 01/02/2015 17:42:50 |
Les Jones 1 | 01/02/2015 18:35:03 |
2292 forum posts 159 photos | Hi Ian, When I first looked at the connection picture I assumed the incoming power was the two vertical arrows at the bottom of the picture and they connected to U1 and Z1 but that did not make sense as in the CCW configuration the capacitor is straight across the mains. I think Z1 and Z2 are the main winding and U1 and U2 the auxiliary winding. (It could be the other way around.) IF I am correct the power would connect to Z1 and Z2 If you have a drawing of how it is connected at present it should identify which is the main winding. An alternative is to measure the resistance of the two windings. The one with the lowest resistance will be the main winding. I expect wth the present wiring that one end of the capacitor goes to the switches. When you provide this information I will draw out how to connect the new switch. Les. |
Neil Wyatt | 01/02/2015 18:59:28 |
![]() 19226 forum posts 749 photos 86 articles | Mini-lathes use a multi-pole (4 pole) high-current centre off switch that would be ideal for this purpose. Arc Euro sell them: www.arceurotrade.co.uk/Catalogue/Machine-Spares/C2-Mini-Lathe-Spares Neil |
ian j | 01/02/2015 19:25:27 |
![]() 337 forum posts 371 photos | Les. Just been and checked. My original diagram is incorrect. The mains IN for the CCW direction is across U1 & U2. You are right in that the cap. is disconnected from U2 & is switched to U2 (CW) or U1(CCW) U1-U2 20 ohms Z1-Z2 55 ohms Ian |
Swarf, Mostly! | 01/02/2015 20:29:53 |
753 forum posts 80 photos | Hi there, For some reason (which I can't justify after all these years) I included a forward-off-reverse facility in the control box for my Tauco bench drill. This was achieved using a four-pole toggle switch with a centre off position. These toggle switches were common on the government surplus market back in the 70s and can be recognised by the luminous tip to the operating dolly. (The control box also includes a MEMDOL single phase direct on-line starter.) Best regards, Swarf, Mostly!
Les Jones 1 | 01/02/2015 20:50:21 |
2292 forum posts 159 photos | Hi Ian, The diagram of the back of the switch is with the lever moving horizontaly. The letters are just to tie up with the schematic. They will not tie up with any labeling that may be on the switch. (It does not matter if the switch is turned through 180 Deg. If you decide to use the 4 pole swtch from Arc Euro you could also switch the neutral to the main windin with the extra set of contacts. Neil, Les. |
ian j | 01/02/2015 21:00:34 |
![]() 337 forum posts 371 photos | Thanks for that Les. I've ordered two switches from Proto-pic for less than £7 inclusive of postage. Ian |
ian j | 03/02/2015 17:13:38 |
Just thought I would update you. The switches arrived this lunch time. I wired one up as to Les's diagram & it works just fine. Thanks Les very much for your help & others for their suggestions.
PS Looking at the photo I need to level the ON OFF ON plate!! Edited By ian j on 03/02/2015 17:22:04 |
John Haine | 03/02/2015 19:28:14 |
5563 forum posts 322 photos | Looks nice. Just as a matter of interest, which vacuum cleaner brand hose are you using to protect the front rail, and what sort of expansion ratio do you get please? Interested in using similar for when I fit a ballscrew to my lathe. |
ian j | 03/02/2015 19:53:00 |
![]() 337 forum posts 371 photos | John. I spent a lot of time looking for suitable bellows with out much success, I did get one quote of over £80 for two bespoke 6" extended length latex rubber ones. But !! So for the time been I'm using the hose off a Dyson vac. It's 1.75 " o/s diameter, 12" extended compresses down to 2.75". I got mine free from a local vac. repair shop or you see loads down the council recycling centres. |
Les Jones 1 | 03/02/2015 20:15:46 |
