petro1head | 16/12/2014 21:19:07 |
![]() 984 forum posts 207 photos | Typed this out then the bloody site timed out so here we go again grrrrrrrrrrr What option do I have for a 3 axis dro for this milling machine:
Some else on this forum has a similar machine Emco I believe who fitted a DRO, would be interested in speaking to his to see how easy it was to fit PS Photo was before I bought it Edited By petro1head on 16/12/2014 21:20:16 |
JasonB | 17/12/2014 07:23:55 |
![]() 25215 forum posts 3105 photos 1 articles | It would help to know your budget. Will you be able to stretch to glass/magnetic scales and a full function didplay or are you limited to the calliper type scales with separate readouts and no fancy functions. X&Y should not be too hard, the Z scale will need a bit more thinking about. |
Les Jones 1 | 17/12/2014 08:21:24 |
2292 forum posts 159 photos | Hi petro1head, Les. |
mr-m | 17/12/2014 08:48:00 |
1 forum posts | hi all, first posting here, the x & y axis is straight forward but I don't see how you could fit the z axis to the swivel head ??, unless you of course just have it fixed as for scales I would buy glass scales, that's my preference, when you do fit the scales, fit the scales at the front, on the table, will give you more room either way enjoy fitting them, and don't bother using the hardware supplied, make your own, its easier and quicker "good luck" keith
Trevor Wright | 17/12/2014 13:26:19 |
![]() 139 forum posts 36 photos | Love the Yuriy's tablet DRO but do not have the time or patience to figure out the magic box that connects the scales to the tablet. Does anyone sell the adaptor ready to plug in? Trevor |
Stephen Benson | 17/12/2014 13:45:30 |
![]() 203 forum posts 69 photos | Cheap DRO's do not like cold damp garages first the battery connect ions go green an easy fix but the soon after they just play up intermittently. I ended up taking mine off and refitting the ruler and pointer system much more reliable. Steve |
Les Jones 1 | 17/12/2014 14:37:58 |
2292 forum posts 159 photos | Hi Trevor, Les. |
petro1head | 17/12/2014 14:48:59 |
![]() 984 forum posts 207 photos | Posted by Stephen Benson on 17/12/2014 13:45:30:
Cheap DRO's do not like cold damp garages first the battery connect ions go green an easy fix but the soon after they just play up intermittently. I ended up taking mine off and refitting the ruler and pointer system much more reliable. Steve Good advice as mine is in a wooden workshop Edited By petro1head on 17/12/2014 14:49:18 |
petro1head | 17/12/2014 15:03:10 |
![]() 984 forum posts 207 photos | I also contacted Machine Dro and they suggested Magnetic scales |
JasonB | 17/12/2014 15:33:30 |
![]() 25215 forum posts 3105 photos 1 articles | There is a similar Emco machine with X&Y scales fitted half way down this US suppliers site to give an idea of how to fix them I would suggest keeping the Y axis at the back so you can still easily use the stops on the front of the table provided the is room when the table is fully away from you J Edited By JasonB on 17/12/2014 15:34:23 |
petro1head | 17/12/2014 15:51:19 |
![]() 984 forum posts 207 photos | A guy on here has also done it http://www.model-engineer.co.uk/forums/postings.asp?th=72913 Edited By petro1head on 17/12/2014 15:52:02 |
steamdave | 17/12/2014 21:49:09 |
526 forum posts 45 photos | You can mount the Z axis quite easily. Did this years ago with an Ortec DRO system on the FB2. Remove the top and bottom column key bolts. Replace them with home made studs with extended heads to act as stand offs so that the scale when fitted to these will clear the column clamp. The top of the stand offs will need to be tapped for the scale securing screws. If you have a scale protector, this can be drilled for the correct spacing of the modified bolts. The read head can be fitted to the column clamp plate using an adapter plate and using the existing holes in the machine. Dave |
ronan walsh | 17/12/2014 21:56:17 |
546 forum posts 32 photos | Cost aside , which are better and why, the glass scales or the magnetic ? |
petro1head | 17/12/2014 22:24:33 |
![]() 984 forum posts 207 photos | I had considered the cheap type like these as I use the mill a lot less than the lathe
Paul Lousick | 18/12/2014 06:17:32 |
2276 forum posts 801 photos | The cheap types are just that, Cheap. I have replaced 3 sets in the last 2 years because of failures. (2 different types of scales) They would lose their reference point or display random numbers. This does not make them cheap, just a waste of money. I have now replaced them with glass scales. Don't waste your money. Buy quality scales. I bought an Eason display with 0.001mm scales (only because they were on sale). 0.005mm scales are all you need for a mill or lathe. The display unit on glass scales has a lot of additional features for calculating the centre point, PCD, milling a curve, memory points, etc. Makes calculations easier. Magnetic scales are more compact but cost more. Paul. Edited By Paul Lousick on 18/12/2014 06:21:19 |
