Design Ideas invited -
Michael Gilligan | 31/10/2013 11:51:15 |
![]() 23121 forum posts 1360 photos | Posted by John Olsen on 31/10/2013 09:59:44:
A four inch shaper is not really all that small ... But actually I wonder how important it is for the shaper to be that small anyway? I have a 6 inch Ammco machine that I think would do the sort of work required. John Olsen . John, Thanks for your thoughts ... This may not be entirely clear from my opening post, but: I am not so much looking for "a very small machine" as a machine which "typically working within a small envelope [say, 100mm cube] can do very small work". I am thinking in terms of 10 micron increments for the "feed" [maybe less, if I use a Stepper Motor], and some of the shapes cut would be smaller than the thickness of the swarf from some large Shapers. Whilst is is possible to make a large machine which is very precise ... it is usually also very difficult and very expensive. This is my main reason for assuming a small machine. Very happy to be proved wrong ... but I hope you see the logic. MichaelG.
Bazyle | 31/10/2013 12:50:38 |
![]() 6956 forum posts 229 photos | In many respects you might need to be bigger to work smaller. Take for example the saddle on a cheap 4in lathe. It is probably about 6 inches long on the bed. A good toolroom lathe, also just 5in centre height will have a saddle 18 in long. The extra length provides the necessary alignment and rigidity to work to tenths. So I think the Adept and Drummond hand shapers are the size of structure you would want to get to your target so perhaps you could fabricate a sort of copy, but using ball slides for precision. |
North Western | 31/10/2013 13:13:05 |
10 forum posts |
Michael Gilligan | 31/10/2013 13:22:46 |
![]() 23121 forum posts 1360 photos | Bazyle and Dave, Very fair points ... My thinking is spiralling at present, but eventually might settle to something that works for me. Please keep the ideas coming. Thanks everyone ! MichaelG.
jason udall | 31/10/2013 15:39:22 |
2032 forum posts 41 photos | Scraper vs shaper.... |
dcosta | 31/10/2013 16:56:17 |
496 forum posts 207 photos | Hello Michael, good afternoon. |
Michael Gilligan | 31/10/2013 18:19:29 |
![]() 23121 forum posts 1360 photos | Posted by jason udall on 31/10/2013 15:39:22:
Scraper vs shaper.... . Call it what you will, Jason If it works like a Shaper, and clacks like a Shaper; then I would say it's a Shaper. MichaelG. Edited By Michael Gilligan on 31/10/2013 18:20:18 |
Stub Mandrel | 31/10/2013 21:48:47 |
![]() 4318 forum posts 291 photos 1 articles | Random musings... I've been thinking about this. For a shaper to work, it needs a number of things: Great rigidity of the central structure with the ram and sideways movement on top and the table with its vertical movement on the front. This suggests a box structure, a large, thick piece of angle reinforced with webs or even a great big chunk of epoxy-based stuff. The ram slide should be as long as possible. It seems a sliding bearing on a rod can be as effective as a dovetail in this role. All the forces in a shaper act to pull (or push) the slides apart. This is the opposite of most sliding surfaces on a lathe and means dovetail slides may not be the best or only solution (as they will only bear the load on the angled surfaces, and maximising the bearing area), however, any solution needs to be adjustable to absolutely minimise play. Some alternative designs shown in my old copy of Machinery's Handbook might prove suitable. Fixed slideway lengths needs to be a minimum of the size of the moving part plus the travel. How big should the moving parts be? A 1mm pitch leadscrew from studding with a 40-tooth ratchet would give feed down to 1 thou, with pawl with varying gathering. This is probably too fine. Neil
jason udall | 31/10/2013 21:57:35 |
2032 forum posts 41 photos | Mickael.. I don't know either subject well enough to pass judgment ..I suspect that it is as you say the result is the all... |
Howard Lewis | 31/10/2013 22:05:02 |
7227 forum posts 21 photos | Good evening Michael, You are planning to make feed increments of 10 microns? Or did I misread your post?
The tools will need to be ABSOLUTELY sharp, to cut. This is the realm of precision grinding. Some comparisons with the accuracy to which you aspire. In old money, 10 microns is just under 4/10 of a thou, about 25% more than a tenth of the thickness of a blonde human hair, (darker hair is thicker). Sorry to be a wet blanket, but you are going to have to do some REAL precision engineering to be able to advance, consistently, by that amount. I would imagine that you are approaching the realms of the type of machinery used in a Standards Room to check and calibrate the shopfloor measuring equipment used in a fairly precise factory. (Slip gauges are check measured to an accuracy of millionths of an inch under conditions of controlled temperature and humidity, after at least 24 hours to soak to the 20 degrees C ambient condition). I have seen a Height Gauge with an error of 0.002 inches over 18 inches ( 0.00011/inch or 2.8 microns/ mm) condemned. An Imperial Verdict finger clock has one division equal to 1/10 thou or 2.54 microns). The backlash in a good leadscrew / nut assembly is going to be much greater than that, unless some special backlash elimination is included! A pair of components, such as the Head and Rotor in a distributor type Fuel Injection Pump, or Injector Needle and Nozzle Body, which have been lapped together, (and therefore not interchangeable with other supposedly identical components), have a clearance of 1 to 2 microns, MAXIMUM. Your design should include space for micrometer dials at least 100mm in diameter, with a 1mm pitch leadscrew., if you are to have divisions which allow a resolution of the order of 10 microns. And, if you want to achieve that degree of accuracy, consistently, start thinking in terms of a very closely controlled temperature in your workshop. As I said, I don't want to be negative, but you do need to think realistically about the degree of accuracy that you WANT versus what you can actually ACHIEVE. Howard |
Michael Gilligan | 01/11/2013 06:10:45 |
![]() 23121 forum posts 1360 photos | Posted by Howard Lewis on 31/10/2013 22:05:02:
Good evening Michael, You are planning to make feed increments of 10 microns? Or did I misread your post? The tools will need to be ABSOLUTELY sharp, to cut. This is the realm of precision grinding. The backlash in a good leadscrew / nut assembly is going to be much greater than that, unless some special backlash elimination is included! Howard . Good morning Howard I have woken rather too early, and popped down for coffee before going back to bed; so this is just a brief response to your three main points:
At the risk of labouring the point ... I want to build something that works like a workshop Shaper, but on a scale that allows me to cut very small details. The main perceived benefit of a Shaper is that it uses a simple cutter ... which is very convenient, and cost-effective, for repair/restoration work. Thanks for your "Sanity Check" MichaelG.
jason udall | 01/11/2013 09:28:14 |
2032 forum posts 41 photos | Michael..from memory ..some microtomes use a rocking arm heated using temp. control to extend the specimen to the "knife"..a control system from a 3d printer springs to mind..you have heater control ( three channels) micro stepper drives ( 200*16 steps) 5 channels. ... free..control software.. potential for stand alone ( pc less) use... And fairly cheap. .... |
jason udall | 01/11/2013 09:36:46 |
2032 forum posts 41 photos | Another thought....micrometer screws..how do they deal with backlash..? ....I think its because they operate one direction (as one does to null out backlash)..and that might work in this context. .tool carrier motion dead..work advances to tool one direction... Btw height gauge at work 0.1 micron..achived using strain gauges measuring the contact force..at the point of recording value...very consistant..as one would expect from the land of cuckoo clocks and chocolate |
Stub Mandrel | 01/11/2013 10:51:19 |
![]() 4318 forum posts 291 photos 1 articles | > some microtomes use a rocking arm heated using temp. control to extend the specimen to the "knife" Alternatively just wait for the tide to go out Neil |
John McNamara | 01/11/2013 11:01:44 |
![]() 1377 forum posts 133 photos | Hi Jason Beware of micro stepping, Just because your software divides by 16 does not increase the resolution by a similar amount. Micro stepping works by tweaking the phase angle of the electronics driving the normally 200 step motor. There is significant non linearity. Or a more general search:**LINK** Chasing microns is not just a matter of cranking up the gearing. One of the reasons most industrial machines use glass scales attached to the sliding member allowing the software to know where the slide and tool is regardless of mechanical backlash and any non linearity in the drive system. coupled to a servo. (Although some better end stepper drivers allow the use of a reference scale or encoder). That has the additional benefit of closing the loop, the driver will compensate for lost steps using the scale or encoder as a reference. However even glass slides do not allow the system to absolutely position the tool in relation to the part, due to geometric errors and temperature effects on the frame and slide assembly. Micron accuracy is an elusive prey. Regards
Edited By John McNamara on 01/11/2013 11:19:21 |
Ian P | 01/11/2013 11:04:58 |
![]() 2747 forum posts 123 photos | Posted by jason udall on 01/11/2013 09:36:46:
Another thought....micrometer screws..how do they deal with backlash..? ....I think its because they operate one direction (as one does to null out backlash)..and that might work in this context. .tool carrier motion dead..work advances to tool one direction... Micrometers rely on very accurate close fitting threads, triangular/trapezoidal thread usually adjusted by closing reducing the 'nut' female thread diameter. As you say they only need to be free of backlash in one direction only but in practice any free movement is too small to be of consequence. A leadscrew and nut is capable of very high precision but the key to achieving it is to have extremely long engagement between the screw and nut so that any errors are averaged out. Ian P
jason udall | 01/11/2013 16:38:09 |
2032 forum posts 41 photos | s to micro stepping..I to never really convinced... ( open loop control of any type for that matter ) What a shame waldo s don't really work.. As to long engagment leadscrew..I think thats how it was originally done...one leadscrew clamped between two blocks of wood..which averaged the pitch...then this was used to screw cut another..more accurate ls..and so on...whitworth needed to start somewhere ( ) |
jason udall | 01/11/2013 16:47:03 |
2032 forum posts 41 photos | Just remembered On the infeed of our centerless grinders ( 1/10 thou)...the feed works by a hydraulic ram moving a cam ( may be ramp is a better description ) past the end of the infeed slide... with 20 inches of cam for as near parallel as you chose ( say 20 thou ) and seting stops to again say 20 thou.. this gives 20 micro inch ...but yes non linearity is present...just how straight / flat is the cam.. |
Michael Gilligan | 01/11/2013 16:59:40 |
![]() 23121 forum posts 1360 photos | Posted by John McNamara on 01/11/2013 11:01:44:
Hi Jason Beware of micro stepping, Just because your software divides by 16 does not increase the resolution by a similar amount. Micro stepping works by tweaking the phase angle of the electronics driving the normally 200 step motor. There is significant non linearity. Regards . Very true, John That's why I settled on 2mm pitch leadscrews to achieve my 10 micron feed increment. I do have a couple of 800 steps per rev. motors, but I'm saving those for something really special. They are NEMA 17 size ... Precision engineering in mass production. MichaelG. |
John McNamara | 02/11/2013 00:18:14 |
![]() 1377 forum posts 133 photos | Hi All There is a very fine set of shaper drawings (4 pages) Here:
You have to register I had no problems.
