Neil Wyatt | 04/07/2015 13:22:35 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Bowber on 04/07/2015 11:44:33:
I'll add mine to my photo's later. I kind of get the impression that it's kidology though, I don't even really believe they have really done the test at the factory and just write random figures down though I've not done my own tests to confirm Steve That's quite a statement to make if you haven't made any tests.
Neil |
Neil Wyatt | 04/07/2015 13:36:48 |
![]() 19226 forum posts 749 photos 86 articles | OK, for the record, I'm going to make as many of the Schlesinger tests as I practically can on my mini-lathe. It's a Clarke CL300M the supplied chuck has the date of 1998, although I bought it in 1999. It is my only lathe and has had 15 years of moderate hobby use. The bearings have been changed to taper rollers. It is free standing, so bed levelling checks are not possible and I haven't got an MT test bar, but I can do the 'turn round' check for spindle alignment instead. I will be using an East-German DTI which is graduated to 0.0005" and easily estimated to 0.0001". Neil
JasonB | 04/07/2015 13:38:35 |
![]() 25215 forum posts 3105 photos 1 articles | here you go, This is for one of the first WM280-VF lathes that warco did dating from March 2008, will be interesting to compare with the new one in MEW. I've not checked any of these things, I seem to be able to make reasonable engine son it so can't be bothered looking for tenths if teh engines run and look OK. Click for larger image. |
Bowber | 04/07/2015 13:52:48 |
169 forum posts 24 photos | Posted by Neil Wyatt on 04/07/2015 13:22:35:
Neil Not really, it's just what what I believe and I'm happy to be corrected. Steve |
Bowber | 04/07/2015 14:59:18 |
169 forum posts 24 photos | Firstly, I'm more than happy with my WM280V so please don't get the impression from my comment that I'm not. I've checked item 6 on the test sheet "Parallelism of tailstock quill to carriage movement" and I got similar results to the test sheet. a - Sheet 0.02mm mine - 0.022mm so the same with rounding down (0.0009" I'll upload my test sheet to my album - I got the impression that these tests are done at the factory in China and not by Warco in the UK I used an imperial dti and guestimated the movement due to it being less than one division. Non of which helps the OP in his quest for better accuracy on his machine. Steve |
Michael Gilligan | 04/07/2015 15:32:54 |
![]() 23121 forum posts 1360 photos | Posted by Bowber on 04/07/2015 14:59:18:
I got the impression that these tests are done at the factory in China and not by Warco in the UK . Steve, Just out of curiosity, I had a look at Warco's site For the WM 280V they make the following statement:
As 'Contracts' man, I find this ambiguous regarding 'location of test' , but at least it does seem clear that the lathes are individually tested for accuracy. Although this is [to me] of academic interest only: It may be useful if Warco could clarify the point at which the 'individual accuracy test report' is generated. MichaelG.
Edited By Michael Gilligan on 04/07/2015 15:34:18 |
Ajohnw | 04/07/2015 15:47:29 |
3631 forum posts 160 photos | My understanding is that Warco do the tests not the manufacturer. Those figure look pretty good really and I would hope that they are always generally within limits. Me - if done in the factory or what ever and they didn't seem to be correct - send it back, supplier to pay return costs. Actual turning is the final test on any lathe. In real terms that is the one that counts but some reassurance via a dti does indicate what the lathe is likely to do. Then it's a case of the user making sure that they always take play out of the lead screws when setting cuts and and also to set sensible amounts of drag on the gibs. That can be important on some lathes even rather large ones. Personally if any doubt I do feel that it's worth the minimal amount of effort needed to make a between centres test bar and or just to do a few very simple turning tests. John - |
Neil Wyatt | 04/07/2015 17:07:56 |
![]() 19226 forum posts 749 photos 86 articles | I've given up for now. it's too damn hot. My tailstock was about 0.004"high and I've ignored my own advice and skimmed the tailstock adjustment joining faces on the mill and got it to about a thou which I will now ignore. The PITA is that my home made lever lock has got out of adjustment and I can't find the sweet spot What else have I done: test - target - actual (all converted to thou) Work spindle centre point for true running 0.0004 0.00025 Centring sleeve (chuck register?) for true running 0.0004 <0.0001 Work spindle axial slip measured at 2 points displaced by 180 degrees 0.0004 0.0002 Lead screw axial slip 0.004 none detectable Lathe turns round within 0.0004 no out of round detectable
I know it failed the faces concave by no more than 0.008 in 12" test as supplied (there was a batch of early machines that suffered from this) but I cured this some time ago by skimming the cross slide dovetails.
The rest can wait... Neil
Enough! | 04/07/2015 18:36:50 |
1719 forum posts 1 photos | Posted by JasonB on 04/07/2015 07:23:15:
David as you have shown its not so bad when turning. Now put a 3mm reamer in the tailstock chuck and see what happens, the top edge of the reamer will be high by 0.15mm so in effect acting like a boriong bar taking a 0.15mm cut as it tries to straighten itself so your hole will be double that at 3.3mm which is certainly more of a problem than the O.009mm on dia whan turning. floating reamer holder perhaps? |
Nitai Levi | 06/07/2015 14:00:00 |
97 forum posts 5 photos | I've done a bit more scraping and definitely see the tail is lower... but still high. so some improvement. I found something strange and need to do more tests. When I put two dead centers and adjust by eye and something thin between them, then I get a really bad side to side alignment if checking with a puppitast and vise versa if I adjust using the puppitast and then look at two dead centers (they are very obviously off). The main difference is the distance of the test. With the dead centers the head and tail are very close (as close as they can be). With the puppitast the tail is probably about half way on the bed, though I have a shorter puppitast holder that I didn't yet use for this test (I will). So I suspect a significant bed alignment problem... |
Nitai Levi | 08/07/2015 18:16:53 |
97 forum posts 5 photos | OK, I'm not sure how I missed it before, but I just found that there is a gross sideways misalignment between the spindle and bed. This is what causes the tail to seem aligned with the spindle only close or far. I'm considering contacting the store and asking about replacing the lathe, but after all the work I've done on it which I'll have to redo... |
Michael Gilligan | 08/07/2015 20:47:05 |
![]() 23121 forum posts 1360 photos | Posted by Nitai Levi on 08/07/2015 18:16:53:
OK, I'm not sure how I missed it before, but I just found that there is a gross sideways misalignment between the spindle and bed. ... . I hope it goes well. MichaelG. |
Nitai Levi | 12/07/2015 21:04:15 |
97 forum posts 5 photos | Thanks. After disassembling everything I see that it would have been a good idea anyway, to clean, remove any extra paint, grit, burs, etc. I'll check alignment after this and go from there. For now I installed the new angular contact bearings. |
Nitai Levi | 26/07/2015 10:35:55 |
97 forum posts 5 photos | Thanks again everyone. In the end I found a few issues that I missed before and had to disassemble the head to fix them. It took a while but in the end it was good so worth it and the alignment of the head and tail is good. |
