Warco Super - Major Vario inaccuracy
Robert Askew15/02/2019 20:23:18
32 forum posts
2 photos
I bought the mill for making parts for my motorcycles
and yes I have to except it’s not industrial quality but warco claim .0015” on there accuracy reports so I guess someone has not checked correctly
and I would like it to bore holes vertical
and the errors I have the deeper you bore or drill the worse the errors will get
JasonB15/02/2019 20:28:00
25215 forum posts
3105 photos
1 articles
Michael,  without rotating the spindle you cannot get a true measure of the axis it rotates on to tell if it is square to anything. The results could have been obtained by mounting the DTI on any stationary part of the machine.
Agreed it's not an easy fix.
Edited By JasonB on 15/02/2019 20:28:44
Robert Askew15/02/2019 20:30:57
32 forum posts
2 photos
has got what I am on about
FMES15/02/2019 20:35:15
608 forum posts
2 photos
Robert, are you holding your dial gauge in a collet or the supplied chuck?
Former Member15/02/2019 20:38:21
Robert Askew15/02/2019 20:42:22
32 forum posts
2 photos
Robert Askew15/02/2019 20:46:10
32 forum posts
2 photos
Would send pics but they don’t want to up load
JasonB15/02/2019 20:50:58
25215 forum posts
3105 photos
1 articles
How to add photos here
Robert Askew15/02/2019 20:56:58
32 forum posts
2 photos
Does this work with an I pad
Tony Pratt 115/02/2019 21:01:31
2319 forum posts
13 photos
Try a PC.
Tony
Michael Gilligan15/02/2019 21:05:35
23121 forum posts
1360 photos
Posted by Robert Askew 1 on 15/02/2019 20:56:58:
Yes [unless it's one of the very early ones]
But do be aware that you can't upload .png or .pdf files
Edit: The photos are in your album, now just select the little black 'camera' icon and follow your nose.
Edited By Michael Gilligan on 15/02/2019 21:13:21
Bob n About15/02/2019 21:15:52
60 forum posts
1 photos
I have the same mill purchased beginning of last year. How are you measuring front to back, I ask as my DRO scale and power feed switch box limit travel to just under 8" If I rotate the head willy nilly and tighten it up any old how I can get bad readings. However if I clock the spindle as I am tightening the head and balance the loads on the fasteners I can achieve ± 0.0015" front to back, till I lean on the head or do some work on it, then those figures are irrelevant. I assembled and set the mill up here on my own, I needed to loosen the column bolts and shim under the rear of the column to get the mill spot on (strip of beer can did the job). I'm not machining exotic alloys so left it at that, otherwise I would add levelling epoxy to gap fill. My column moves the same as it did when the surfaces were mated, so for me it's not an issue. I might also add that all my measurements are taken off the base of large precision Vee blocks, so the key slots don't interrupt measurement.
Overall I am very happy with the mill, I can achieve the precision I need in alloy and plastics. I have done some steel and cast iron work using a 50mm face mill (conservatively) holding a tolerance within ±0.001" in 6" I have had some issues with the mill, but resolved them myself.
Robert Askew15/02/2019 21:22:02
32 forum posts
2 photos
Edited By Robert Askew 1 on 15/02/2019 21:24:08
Michael Gilligan15/02/2019 21:29:47
23121 forum posts
1360 photos
Item No. 3 is "interesting"
MichaelG. angel
Robert Askew15/02/2019 21:39:33
32 forum posts
2 photos
06ed62bc-e8ef-477f-ab50-17a4e9143f95.jpeg401784fe-3417-4439-8c51-794d08a1c662.jpeg677f5f92-e374-4c5c-8bcc-e6f036b1b5cf.jpegHere is my clock readings
Edited By Robert Askew 1 on 15/02/2019 21:45:57
FMES15/02/2019 21:53:59
608 forum posts
2 photos
Robert, if you are holding that DTI in a chuck and not a collet that is probably where a lot of your error lies.
Unfortunately we can't see wht you are doing.
Robert Askew15/02/2019 21:57:22
32 forum posts
2 photos
it’s held in an er32 collet
Former Member15/02/2019 21:58:22
JasonB16/02/2019 07:00:54
25215 forum posts
3105 photos
1 articles
Posted by FMES on 15/02/2019 21:53:59:
As the dti is not being revolved it makes no difference how it is held or on what part of the machine it is fixed to.
Your first photo shows the DTI on something laid across the table but the last seems to show it directly on the table but there is 0.008" difference between first and last reading.
Michael Gilligan16/02/2019 07:25:51
23121 forum posts
1360 photos
Posted by JasonB on 16/02/2019 07:00:54:
I think you will find that the slip is still there, Jason
... its edge is the diagonal line just to our right of the DTI probe
... and there is a reflection in the surface.
