Here is a list of all the postings Robert Askew has made in our forums. Click on a thread name to jump to the thread.
Thread: Economy hit and miss engine |
08/11/2020 14:07:19 |
anyone one on here bought the economy engine from the engineers emporium recently mine turned up last week the castings are diabolical they don’t even meet size before machining and I know castings very but these are awful full of sand and inclusions anyone else had this problem and a way round it before I send the lot back |
Thread: Economy Engine from Engineers Emporium |
31/10/2020 19:26:41 |
Just received my castings for my economy engine they all look to bad apart from the water hopper it looks like I might struggle to clean it up miss match from one side of casting of about 2mm anyone got any pics of there’s all the ones I have seen on Internet look far better than mine |
Thread: Warco Rotary Table - Can anybody give feedback please? |
25/09/2020 11:11:58 |
The table has tight spots when rotate it with hand wheel disengaged the shaft the hand wheel is on is bent the chuck that came with it takes 2 hands to turn chuck key and supplied chuck mounting plate holes only 2 of the 4 line up and along with nothing been deburred apart from that it’s ok for a door stop |
25/09/2020 09:49:57 |
Just had my warco hv6 rotary table and chuck delivered am in possess of boxing it up to send back utter rubbish |
Thread: Axminster cq6230 lathe |
15/04/2020 19:38:26 |
Thanks for that makes sense now and I have found the gears must have had a senile moment |
15/04/2020 19:10:27 |
This is the lathe |
15/04/2020 18:03:42 |
anyone on here got an Axminster CQ6230 lathe having trouble screw cutting i normally only cut metric threads no problem but today wanted to cut imperial but come unstuck as looking on chart on machine I don’t have a gear Z or position Z on gearbox |
Thread: Bengs 'Karl' Hit & Miss engine. |
22/04/2019 17:45:58 |
Just finished my bengs hit and miss Karl cant get it to run checked timing got spark and loads of compression so much I can hardly spin it past tdc any suggestions |
Thread: Warco Super - Major Vario inaccuracy |
21/02/2019 22:22:56 |
Yes they did it’s definitely the column is out |
21/02/2019 21:53:29 |
Latest on my warco super major vario the machine by my company’s maintenance department using there test equipment and the results are and the main column is 5 minutes of angle out does not sound much but over 300mm that’s .012 mm warco are coming to fix it Monday i guess they are going to unbolt the column and shim it, not happy about that but short on options |
16/02/2019 10:10:58 |
Well I will know for sure this afternoon the maintenance guys from where I work are coming this afternoon with all there test equipment to tell me how far it’s out and before I get comments on how good they are we work for a well known helicopter manufacturer |
15/02/2019 21:57:22 |
it’s held in an er32 collet |
15/02/2019 21:39:33 |
Edited By Robert Askew 1 on 15/02/2019 21:45:57 |
15/02/2019 21:22:02 |
Edited By Robert Askew 1 on 15/02/2019 21:24:08 |
15/02/2019 20:56:58 |
Does this work with an I pad |
15/02/2019 20:46:10 |
W
15/02/2019 20:42:22 |
15/02/2019 20:30:57 |
MichaelG. has got what I am on about
15/02/2019 20:23:18 |
I bought the mill for making parts for my motorcycles and yes I have to except it’s not industrial quality but warco claim .0015” on there accuracy reports so I guess someone has not checked correctly and I would like it to bore holes vertical and the errors I have the deeper you bore or drill the worse the errors will get |
15/02/2019 19:58:24 |
that’s what I saiid table slopes |
