Michael Gilligan | 11/08/2020 22:17:41 |
![]() 23121 forum posts 1360 photos | Posted by Alan Crawley on 11/08/2020 19:35:38:
[…] . That would depend upon what performance you are seeking Seconds per day ... probably not Tens of seconds per year ... almost certainly MichaelG. |
Russell Eberhardt | 12/08/2020 11:22:06 |
![]() 2785 forum posts 87 photos | Posted by Alan Crawley on 11/08/2020 19:35:38:
I’m beginning to realise my IQ is too low for this conversation!! Surely not. Sorry if I have assumed too much. To simplify things; Q is just a measure of how much energy is lost on each cycle of the pendulum and how much energy must be given back to it on each tick of the clock to maintain it. The higher the Q the smaller the energy is needed to keep it going and the less disturbance that it causes to the regularity of the clock. Hope that helps. Russell |
Alan Crawley | 25/08/2020 14:09:49 |
26 forum posts | I fitted the carbon fibre rod as advised and all is well! I recently used the term "amazingly accurate" when running on a length of 6mm EN3B. This was meant to be a relative term as it is amazing to me, my first ever clock in my ninth decade. It cost well over £300 for materials, and is not as accurate as a £4 clock from Aldi! Another question, I learned that the term "Regulator" was used as it was the accurate clock in the clockmaker/repairers workshop to adjust other projects. What did they set the Regulator to? Or did it set standard time for the area it was in? I recall reading that railways had problems where different companies ran to different time. Much like today, it seems! Many thanks for the help and guidance. |
Martin Kyte | 25/08/2020 14:41:08 |
![]() 3445 forum posts 62 photos | Posted by Alan Crawley on 25/08/2020 14:09:49:
The regulator was important not so much for aboslute time but for 'rate'. If you have a clock that runs at a consistant rate say gains two seconds per day you have a time standard available to 'regulate'other time pieces particularly is you are attempting to 'prove' their temperature compensation. Absolute time really can only be determined by astronomical observation. In essence it is defined as such. Regarding the railways, the need to produce timetables created the need to establish a counry wide 'universal' time rather than having each parish set its local time by sundial or local noon. That way you didn't have Bristol 20 mins different from London. I am told that French railways as late as 1970 relied on large sundials to set the station clocks which could be achieved to within a few seconds. Many early longcase clocks were also delivered with a sundial for setting (how else would you do it) and some even showed sundial time on a separate dial to make for easier setting. regards Martin
SillyOldDuffer | 25/08/2020 14:44:46 |
10668 forum posts 2415 photos | Posted by Alan Crawley on 25/08/2020 14:09:49:
I fitted the carbon fibre rod as advised and all is well! ... Another question, I learned that the term "Regulator" was used as it was the accurate clock in the clockmaker/repairers workshop to adjust other projects. What did they set the Regulator to? Or did it set standard time for the area it was in? I recall reading that railways had problems where different companies ran to different time. Much like today, it seems! Many thanks for the help and guidance. Congratulations, always good to hear of successes. Standard time was originally local, ie Noon. So regulator clocks would be checked regularly against a superior sun-dial. Problem with this is Noon depends on longitude, making Bristol time about 10 minutes later than London. No good for marine navigation or railways. A 10 minute navigational error is out by roughly 100 miles, and timetabling trains was a nightmare! Next step was to measure time with a transit observatory rather than a sundial. A telescope aligned rigidly with true North-South, ie on a Meridian, was used to detect exactly when stars pass directly overhead. The movement of the heavens is extremely accurate and knowing the observatory's longitude meant its time relative to Greenwich was also precisely known. Astronomical time was used to set and constantly measure the rate of a good mechanical clock in the observatory. If observations were missed due to clouds, the mechanical clock could still be read accurately by correcting it's rate error. The observatory would also set and measure the rate of other clocks, some of which would travel as necessary to set local regulators, often owned by clockmakers. When telegraphs became available, Greenwich used the system to broadcast time signals to all major towns, making it easier to keep local clocks in step. Then by radio and now by satellite. Not all Regulators were regulators; the term seems to have come to mean any accurate clock in that style. Fascinating subject. Dave
Tim Stevens | 25/08/2020 15:05:39 |
![]() 1779 forum posts 1 photos | two further points: The time set by a sundial will include errors due to the wobble of the earth's axis as it rotates - about 15 minutes (from memory) either way so it would need to be a clever dial or a set of look-up tables to get a universal noon (rather than a seasonal one). I think the term for the wobble is precession - if not I am sure to be bombarded with different corrections. in the 1850-1860 period, as railways spread around the UK, lots of towns were persuaded to erect clock towers, so that locals could set their home clocks and so, catch the trains on time. In mid Wales, places like Rhyader, Dolgelly, Knighton, Kington etc still have these clocks. But the railways are not all there now - shame really. Regards, Tim |
Martin Kyte | 25/08/2020 15:57:40 |
![]() 3445 forum posts 62 photos | Hi Tim time set by a sundial will include errors due to the wobble of the earth's axis Depends on what you consider to be the more fundemental time reference. I would argue that time defined by the position of a location on the earth in it's orbit around the sun is what we define by 'the time'. Unfortunately the orbit is not perfectly circular and the axis has a tilt as Tim has pointed out. This makes it awkward to use as a universal reference for multiple locations. We have got used to Greenwich Mean Time as a time reference but local time in terms of where the sun is at your location on the earth is arguably the more 'fundemental' reference. If one wishes to convert the 'real time' to the artificlal time of GMT one needs to know how far out GMT is from real time on any particular day. So I would say the Sundial is correct and the variation in the timings of the orbit need to be used to calculate how far out GMT is. If you are navigating around the globe by time you need the local noon and the time of the local noon at Greenwich in order to calculate your longitude. If you use GMT and local noon you are going to be in fix. It's very true that we have come to regard clock time as the norm which is understandable, but just because we are used to it doesn't neccessarily mean that it's more fundemental than the actual position of the heavens. Just making a curious point really. regards Martin
Edited By Martin Kyte on 25/08/2020 15:58:27 |
Tim Stevens | 25/08/2020 16:18:08 |
![]() 1779 forum posts 1 photos | Which you regards as 'fundamental' time depends on whether you regard time as passing steadily, or speeding up and slowing down in time with the earth wobbles. I suggest that steady time is the same everywhere in the universe, and so more 'fundamental' Tim. |
John Haine | 25/08/2020 17:23:04 |
5563 forum posts 322 photos | Hmmm... "Problem with this is Noon depends on longitude, making Bristol time about 10 minutes later than London. No good for marine navigation or railways. A 10 minute navigational error is out by roughly 100 miles, and timetabling trains was a nightmare!" - well actually there used to be a clock on Bristol Post Office near Temple Meads with two minute hands showing local time and London time, for the benefit of new arrivals from London. As long as you know about the shift you can allow for it in the timetables. And of course the longitude "error" is the essence of using a clock for navigation, long before railways. Distributed telegraph time was introduced by the Post Office, partly so they could time-stamp telegrams synchronously everywhere, and also later to make sure exchange clocks were accurate for billing. Anyone who could pay could have a 10.00 GMT time pulse down a wire - for example the Robertson Clock at Bristol University used the pulse to phase lock its pendulum by adjusting its rate according to the measured phase difference. Telegraph time wasn't phased out until the 50s I believe. The seasonal variation of solar noon compared to mean time is the "equation of time" and can be corrected by an "analemmatic sundial" or sets of tables. Some clocks incorporate a cam to show the error to make it easier to set them by the sun. There are dials where the shadow of the gnomon falls on an analemmatic curve and you can read off the right time if you know the date - there's one on the terrace outside the cafe at the National Maritime Museum. Time is absolutely not the same everywhere in the universe - relativity shows that it varies with gravity, and every object in motion has its own proper time. This has to be allowed for in GPS to get accurate fixes and time distribution. For a very entertaining demonstration see this. How did we get here from carbon fibre? |
Michael Gilligan | 25/08/2020 18:16:41 |
![]() 23121 forum posts 1360 photos | Posted by Alan Crawley on 25/08/2020 14:09:49:
[…] Another question, I learned that the term "Regulator" was used as it was the accurate clock in the clockmaker/repairers workshop to adjust other projects. What did they set the Regulator to? . Regulators [proper ones] were typically set to Sidereal time I will post a very early description of how it was done, when I can find it in my ‘archive’ MichaelG. . Edit: As promised ... See p91 of this transcription: https://quod.lib.umich.edu/e/eebo/A60473.0001.001?rgn=main;view=fulltext
Edited By Michael Gilligan on 25/08/2020 18:27:25 |
SillyOldDuffer | 25/08/2020 18:22:05 |
10668 forum posts 2415 photos | Posted by John Haine on 25/08/2020 17:23:04:
Hmmm... ... As long as you know about the shift you can allow for it in the timetables. ...
Ah, but how many timetables are needed? Passengers departing Paddington need one in London time while anyone meeting the train at Temple Meads either needs another timetable in Bristol time or does maths on the London one. Same problem in reverse, does the Temple Meads timetable show departures in Bristol time, or in London time? Most mid-Victorians weren't well educated and would have found the maths difficult. Even today many struggle to understand timetables. Worse for anyone carrying on to Fishguard which is nearly 5 degrees West of Greenwich. Much easier to put everyone in the British Isles into the same time zone, and ignore noon being slightly off clock time. I think pairs of timetables would be needed for all journeys with a significant east-west component, like London to Birmingham or Liverpool to York. Think of the work and the mistakes! Dave
Michael Gilligan | 25/08/2020 18:35:18 |
![]() 23121 forum posts 1360 photos | Posted by Tim Stevens on 25/08/2020 16:18:08:
Which you regards as 'fundamental' time depends on whether you regard time as passing steadily, or speeding up and slowing down in time with the earth wobbles. I suggest that steady time is the same everywhere in the universe, and so more 'fundamental' Tim. . But of course ... ‘They’ abandoned all concepts relating to astrophysical behaviours, and Time [or more specifically ‘the Second’] is defined by the apparently simple process of counting. MichaelG. . Ref. The official definition of the second was first given by the BIPM at the 13th General Conference on Weights and Measures in 1967 as: "The second is the duration of 9192631770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium 133 atom." At its 1997 meeting the BIPM added to the previous definition the following specification: "This definition refers to a caesium atom at rest at a temperature of 0 K."[3] Edited By Michael Gilligan on 25/08/2020 18:37:21 |
Neil Wyatt | 25/08/2020 19:49:26 |
![]() 19226 forum posts 749 photos 86 articles | I have finally found out how a Caesium clock works (hint: you won't find out from Wikipedia). Neil |
Martin Kyte | 25/08/2020 19:55:07 |
![]() 3445 forum posts 62 photos | What we mean by time is ultimately an instant of a particular configuration of physical objects and the passage of time can only be perceived by something physically changing configuration wether the oscillation of electron energy states in an atomic clock, the orbit of the planet or the oscillations of a pendulum or qurtz crystal. I quite agree that the access to a 'timebase' of constant period is essential but it can only be artificial. OK so noon exhibits a periodic variation when compared to a constant timebase but noon is noon and he use of the word error for a natural phenomenon seems a little out of place. I feel there is a philosophical difference between the absolute instant of time which is a configuration and a constant period of time which at best a constuction. OK I am being a little pedantic here and maybe a little tongue in cheek too but when you really think about there is real or 'natural time' being the configuration of the universe and man made time contrived to generate a constant timebase in order to to measure the first. As John Haine has already mentioned there is no universal clock as Newton envisaged where any event anywhere in space could be said to take place at a particular time rather with Einsteins spacetime no two spacially distant observers will agree on the timing of any event. As I say it's a bit philosophical but interesting to think about all the same. best regards Martin
duncan webster | 25/08/2020 20:17:03 |
5307 forum posts 83 photos | Posted by SillyOldDuffer on 25/08/2020 18:22:05:
You only need one set of timetables, you depart London (good idea) on London time and arrive in Bristol in Bristol time. It might mean that the timetable time for going one way is 20 minutes longer than the other way, but it works. The chap doing the timetable needs to concentrate, but the guard is very likely to get confused as his watch will only be 'correct' at one end or the other. What speed you are doing is an interesting philosophical debate. Altogether a better idea to have standard time. However, to make things equitable the UK meridian should have been postioned so that the furthest east point of the UK (Ness point Lowestoft 1.75 E) was the same amount early as the most westerly was late. I'm in danger of getting political here, as Eire was part of the UK in the early 1800s, but if we stick to mainland Britain, the most westerly point is Corrachach Mor 6.13 W . On this basis the meridian should pass along what is now 3.94 W, but the arrogant Londoners used Greenwich (so that they didn't need to change their clocks?). Anyway, Swansea Standard Time doesn't have the same ring does it. Perhaps rolls off the tongue better than Blaenau Ffestiniog. A Scottish version could be Wishaw or Nairn This really is getting off topic! |
Alan Crawley | 25/08/2020 20:19:27 |
26 forum posts | All of the above explains how my friend who completed a trip back home from Oz on Concorde from Bahrain arrived here before he left there. Someone mentioned Fisshguard and I frequently stay with friends there and the shift in daylight is very noticeable. A further aside-I think the carbon fibre rod looks nice with the brass bob and weights etc. |
Michael Gilligan | 25/08/2020 20:24:20 |
![]() 23121 forum posts 1360 photos | Posted by Alan Crawley on 25/08/2020 20:19:27:
[…] A further aside-I think the carbon fibre rod looks nice with the brass bob and weights etc. . In reality ... that might be the best bit of the whole adventure MichaelG. |
Michael Gilligan | 25/08/2020 21:39:50 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 25/08/2020 19:49:26:
I have finally found out how a Caesium clock works (hint: you won't find out from Wikipedia). Neil . To be honest, Neil ... I don’t much care how it works The magic of Time, and Timekeeping, disappeared when they adopted it. MichaelG. |
Mason Green | 07/03/2023 22:24:09 |
19 forum posts 1 photos | I found this 1 meter length, threaded carbon fiber rod: A bit expensive, but might make it easier to attached a weight at the bottom and fixtures at the top. No adhesive required? I read somewhere that adhesive is the weak link in regard to stability. --MG
John Haine | 07/03/2023 22:48:14 |
5563 forum posts 322 photos | Interesting! I think that is actually solid carbon? Max temperature is 3630*F which implies there isn't any resin in the mix - also it says "chopped" which if it's referring to fibres would not be very good for a pendulum where you really want full-length longitudinally laid fibres. |
