Roderick Jenkins | 18/09/2023 22:28:27 |
![]() 2376 forum posts 800 photos | Nice work Rod |
Paul Kemp | 18/09/2023 23:05:20 |
798 forum posts 27 photos | Very nice, making a good job of that. Paul. |
Steviegtr | 18/09/2023 23:13:14 |
![]() 2668 forum posts 352 photos | Agree with above. Great work. The con rod looks the busness. Steve. |
Dalboy | 19/09/2023 15:22:24 |
![]() 1009 forum posts 305 photos | Thank you everyone not a lot to show for today just odd bits and pieces that are not worth looking at. I am waiting for some more material to turn up. Got a message that they would be here today, then another saying they would not manage today but "will be here next working day" followed by Oh we have not collected them from your supplier. Lets see what tomorrow brings |
Dalboy | 20/09/2023 21:33:34 |
![]() 1009 forum posts 305 photos | Took a break from the main components today and made a start on the main oiler for the engine as I had some test tubes arrive for some single flower pots I will be turning from wood, before I do them I needed a small length of one of them for the oiler.
Benedict White | 21/09/2023 00:01:19 |
113 forum posts 1 photos | Very nice work Dalboy. I made a swarf collector from some 28mm copper pipe, a stack of 25mm super magnets and some aluminium. Works a treat. Looks a little like a copper bicycle pump with an aluminium ring on it. |
Diogenes | 21/09/2023 07:59:14 |
61 forum posts 6 photos | |
Dalboy | 29/09/2023 18:10:48 |
Been busy with the last part of the con rod and that is a bronze big end split bearing. The small dots are there to make sure that when it is taken apart to assemble the complete model they stay in the correct orientation
Then it is onto the crankshaft assembly, the plans show it mad from a single piece of steel but I have decided to make it up from two small pieces and some silver steel. First was to make the two webs made easy by the use of a small home made stop which worked a treat. Turning the raised sections as well as the curve on both ends I had to do this set up 4 times two for each piece
After the part being deburred I am pleased with the result
All the parts for the crank shaft assembly
A dry fit to check everything was in line. I have left the main shaft in one piece until it is finally fitted together. I will locktite them in and also drill for a tapered pin in each of the joins. The two pieces at the top of the photo are just machined to the correct width for the gap in the middle. Still more to do to this once it is finally fitted together
Dalboy | 01/10/2023 19:54:26 |
![]() 1009 forum posts 305 photos | What with gardening and cooking yesterday, I always cook a special meal on a Saturday for the wife to give her a day off. Nothing got done on the engine. Today started a lot better so I took my time as there is a lot of work to restart the crankshaft if I mess up.
Final job was to cut and machine away the main shaft that passed between the two crank webs. At least that is the crankshaft completed
Dalboy | 02/10/2023 20:41:28 |
![]() 1009 forum posts 305 photos | What with making the crankshaft the next part was drilling and reaming for the main bearing, as well as making the bearings which was not so bad. |
