Member postings for Benedict White
Here is a list of all the postings Benedict White has made in our forums. Click on a thread name to jump to the thread.
Thread: New member
04/10/2023 23:48:47
Welcome Alan. Could I also suggest finding a local model engineering club. As well as having in person advice they are likely to posses tools, books, drawings and magazines that you will be able to borrow as well as possibly materials.
This will greatly speed your path!
Thread: Small (20mm 10mm bore pulley) - source of?
03/10/2023 17:32:32
Fair point Howard.
Ajax, I suspect it does matter though aluminium is easier to cut.
03/10/2023 17:12:37
I have loads of aluminium bar too, purchased from the scrapyard at £2 a kilo, though I don't have a tool with a profile for round belts.
03/10/2023 16:47:48
Ah. Where are you roughly Andy?
Thread: Quick release indicator holder
03/10/2023 16:45:16
You get this:
Where you uploaded to Drive, open a new tab, go to YouTube and publish there. It will be easier. Also people without Google accounts will be able to see it.
03/10/2023 16:05:47
Greg, it is asking me to ask you permission to view that file.
Go to YouTube and publish it as a video, that way everyone will be able to see it.
03/10/2023 15:00:42
Greg, it says the video is unavailable as it is private.
Thread: Help wanted
02/10/2023 09:04:49
Many thanks Nick. When ever I hear people asking for help online as regards information sources I always try to point them to local clubs because there is so much on offer there in terms of information as well as that one piece of equipment they need to use for one operation that they don't have and would otherwise need to buy.
02/10/2023 08:52:03
Posted by Nick Clarke 3 on 02/10/2023 08:32:32:
As Howard has already mentioned the club I am a member of can I suggest you have a look at the website of the Sutton Coldfield MES - we are just off the A38 at Little Hay,
Our website at www.scmes.co.uk has more details including the (members only) workshop classes run in the club workshop.
Nick, I presume your club has a workshop as well which will provide facilities like a larger mill than a home machine shop might have if there is one in the home shop at all? As well as sets of tap, dies etc that club members can use?
Presumably also an extensive library of back issues of Model Engineer and books?
01/10/2023 19:11:51
I forgot to mention they may also have a library to borrow books from at your local model engineering club.
01/10/2023 19:11:14
Good advice Howard, joining a local model engineering club will bring dividends in terms of advice but also borrowing that odd tool you don't have.
30/09/2023 19:23:21
Interesting idea Greg.
Thread: lidl tools 28/09/23
30/09/2023 19:20:48
Mick B1, I have just filmed (editing now) a review. The manual claims accuracy of 0.015mm, and I make it inconsistent to up to 2 divisions so that tallies.
I compared it to my Moore and Wright 10ths micrometer and used gauge blocks to check it.
Given that 0.01mm is 0.00039" I think that is acceptable especially in a tool that costs £6.99.
Thread: Levelling my lathe - a build log
30/09/2023 14:43:02
If it is wider at the tailstock end, try tailstock support. Nothing is so stiff it does not bend.
30/09/2023 14:11:58
Posted by Iain Downs on 30/09/2023 12:59:40:
Both slope inwards towards the headstock...
Iain
I just want to clarify. Is the test bar 2 thou narrower at the headstock end that at the tailstock end? I thought you said in an earlier post that it was 2 thou narrower at the tailstock end but I have just looked at your graphs and if 0 is the headstock it would appear to be narrower there. That would be what I might expect if you are turning something that long out of the headstock without tailstock support.
Have you tried it with tailstock support?
Also are you measuring the deviation by measuring the diameter of the bar with a micrometer? If so are you cleaning the carbide faces between measurements?
30/09/2023 12:24:42
I didn't see the prism in the photos. If your wear is less than a thou I wouldn't worry about wear.
The only question then is, is there any twist. Remind me ho big is the discrepancy along a bit or turning?
30/09/2023 11:55:23
Posted by Iain Downs on 30/09/2023 11:36:31:
Surely if the bed is worn (on one edge) then I will see an angle change with the level regardless of it being on the bed or on the carriage?
Iain
If you have or can borrow a good parallel you can check for wear in flat ways very easily. Here is a video of me doing that on my Atlas 10.
The same technique applies to all lathes with flat ways such as the Myford 7" range.
30/09/2023 09:08:16
YouTube. The channel is here. There are various playlists, including one for all reviews, Lidl reviews etc.
30/09/2023 00:08:49
I have a previous iteration of the Lidl Plasma cutter which requires an external compressor. Works well, though I now have a Simder 10 in 1 which replaces it and in fact all my other welders too.
The Lidl one I have works well. (Did a review on it).
Thread: Upgrading from a Clarke CL300M, where to go?
29/09/2023 22:47:53
If you don't mind old, you could go for an Atlas 10 (I have one), a Southbend (better) or a Boxford.
