What method do you use to find center height for your lathe bit?
Peter Spink29/06/2019 03:08:00
126 forum posts
48 photos
Posted by Peter Spink on 28/06/2019 08:59:11:
Posted by Vic on 27/06/2019 13:00:53:
I made a simple tool.
Vic, nice toolholder - what is it?
Sorry, ignore that - have found the thread. Nice job!
jimmy b29/06/2019 07:42:50
857 forum posts
45 photos
I use a cheap "thickness" gauge.
Works pretty well.
Edited By jimmy b on 29/06/2019 07:43:11
Danny M2Z29/06/2019 08:40:17
963 forum posts
2 photos
For final finishing I have found this tool quite handy, especially on 'difficult' materials. Shear tool
It is not picky regarding height as it is automatically on center due to the design. Indeed, I raise and lower mine with the QCTP to present a fresh edge for the final finishing cut.
Notice that I said "Finishing Cut" - only good for the last 0.001" or so but what a lovely finish.
If I had the time it would be interesting to experiment with the cutting angle for various materials. I have noticed that brass with a finely honed HSS edge can appear as a mist of tiny motes when the light is right.
* Danny M *
Blue Heeler29/06/2019 08:47:00
342 forum posts
Danny thanks mate for the link to the shearing tool.
Nigel McBurney 129/06/2019 10:03:06
1101 forum posts
3 photos
I use a length of aluminium round bar faced off at each end,the length is the centre height of the lathe (bed to Centre) at the top end I have an offset steel penny washer secured with a small screw the washer overhangs the ally bar by about half an inch on one side, To set a cutting tool the top tip of the tool just slides under the washer,I used alloy bar so that if dropped or knocked over it does not damage machined surfaces of the lathe, I got this idea from my first job,a similar tool made from steel was used to set tooling on a Ward capstan, to set the rear toolpost tools the top of the bar just slid under the rear tool . Simple !!!
colin hawes29/06/2019 10:26:02
570 forum posts
18 photos
Estimation followed by adjustment if necessary. Colin
John Rutzen29/06/2019 18:20:53
411 forum posts
22 photos
That shearing tool works on the same principle as a skew chisel in woodturning. Hard to use woodturning to avoid a dig in but that wouldn't happen here. I'll have to make one because I find it difficult to get a good finish. Thanks for the post.
Neil Wyatt29/06/2019 19:30:37
19226 forum posts
749 photos
86 articles
Posted by Danny M2Z on 29/06/2019 08:40:17:
* Danny M *
Thanks Danny, I read about those years ago and still haven't got round to grinding one up.
thaiguzzi30/06/2019 08:59:30
704 forum posts
131 photos
And this is what a shear tool does on a shaper;
Andy Carruthers09/08/2019 11:49:26
317 forum posts
23 photos
Thank you Danny, I've just ground one up and tested on brass, excellent finish with long swarf finer than a hair
old mart09/08/2019 13:57:08
4655 forum posts
304 photos
I just made a height gauge that matches the top of the tool tip which is just the right height to face off perfectly.
