Enough! | 14/07/2018 01:52:05 |
1719 forum posts 1 photos | Posted by Raymond Sanderson 2 on 13/07/2018 07:28:46:
If you mean the forum digital archive of bot ME & MEW accessible only via the forum yes thats the one. Yes and we pay via the Digital subscription to access that only with the digital subscription the main reason for taking that form of subscription as well as printed. You do not get access to he forums archive digital section under Print Only.
In that case, Raymond I'm totally lost. As far as I was aware, the online viewer for the archives was/is a Flash application and needed a Flash viewer to open them. If you've been looking at them for two years without using Flash, then that must be wrong. So why are you trying (unsuccessfully) to use Flash now? |
Raymond Sanderson 2 | 14/07/2018 03:12:55 |
![]() 450 forum posts 127 photos | Posted by Neil Wyatt on 13/07/2018 11:33:24:
So are you sorted or not? If it works under edge and not Firefox, I think we can safely assume it's a setting somewhere in Firefox causing the issue. Neil Neil NOT in Firefox which is preferred browser. I now agree Firefox MAY be part of the issue but not altogether as all other browsers used insisted the latest Flash Player is used therefore the server is demanding an upgrade refusing to use earlier versions. But as stated I haven't had Flash on my machines for some time and still been able to view the mags in the past. |
Raymond Sanderson 2 | 14/07/2018 03:15:19 |
![]() 450 forum posts 127 photos | Posted by Bandersnatch on 14/07/2018 01:52:05:
In that case, Raymond I'm totally lost. As far as I was aware, the online viewer for the archives was/is a Flash application and needed a Flash viewer to open them. If you've been looking at them for two years without using Flash, then that must be wrong. So why are you trying (unsuccessfully) to use Flash now? THAT ANSWER IS SIMPLE i WAS FOLLOWING INSTRUCTIONS OF THE MANY WHO TOLD ME TO INSTALL IT!!! |
Raymond Sanderson 2 | 14/07/2018 03:31:35 |
![]() 450 forum posts 127 photos | Posted by SillyOldDuffer on 13/07/2018 12:29:59:
... If it works under edge and not Firefox, I think we can safely assume it's a setting somewhere in Firefox causing the issue. Neil Not quite a safe assumption, I think it's more likely the Firefox cache is corrupt than a user setting is misconfigured. (Apologies if you meant 'setting' in the broadest sense, which would include cached system settings.) Four possibilities:
Edge, Chrome and Firefox etc. each have their own cache so using a different Browser also uses a different configuration and memory. Depending on the cause, especially if malware is the root, they may become corrupted too. One example how a bad cache causes this sort of problem. When a Browser connects to a server it sends a mass of information about the client, like the browser name, operating system, available plugins and versions thereof. The server uses the information to adapt web pages to the user device, which could be a Mac, or a SmartPhone, or a PC. Either the server or the client can bail out when an inconsistency is found, or results are undefined. (In computer-speak an 'undefined result' can be anything between apparently normal operation and a crash - all bets are off.) Frequently used information is often cached to improve performance. It can be remembered between sessions and reboots. If an upgrade is applied and the cache isn't updated correctly, then the resulting mismatch between client and server is liable to cause peculiar errors. Completely emptying the cache forces the Browser to repopulate it from scratch, with luck fixing the weirdness. In the other thread I provided a link to a site explaining how to clear Firefox's cache. It's worth trying. As is powering off the router for at least 20 minutes, which should force it to refresh as well. Raymond has hinted he may not have a fast Internet Service with no-download limit. As I know to my cost upgrades that misfire due to network problems cause havoc. Dave
Dave all cache are set to clear out on shut down and I had done a full clear out not long ago myself. This leads me to consider if the cach has been cleared at my end the serve is not then recognising what it needs to? Or the updates of all and sundry have caused a hick up as so often happens in one week Microsoft, Firefox, Adobe Reader (Not Flash) a couple of other products.
Neil Wyatt | 14/07/2018 17:20:41 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Raymond Sanderson 2 on 14/07/2018 03:31:35:
I freaked out when I saw my daughter down in Sydney is getting 1000mbps and she's in a rural area I wish is all i can say. In the whole are top speed here is 100mbps and were are a city with in 40 mins of Brisbane.
OK, no more sympathy from me. I have to cope with 2.7 MB/S |
Michael Gilligan | 14/07/2018 18:32:23 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 14/07/2018 17:20:41:
... In the whole are top speed here is 100mbps ... OK, no more sympathy from me. I have to cope with 2.7 MB/S . SI pedant alert !! http://www.ebyte.it/library/educards/siunits/TablesOfSiUnitsAndPrefixes.html
JasonB | 14/07/2018 18:55:30 |
![]() 25215 forum posts 3105 photos 1 articles | Is there also an abbreviation for Mega Pendant? |
Michael Gilligan | 14/07/2018 19:13:20 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 14/07/2018 18:55:30:
... Pendant? .
Raymond Sanderson 2 | 14/07/2018 23:46:47 |
![]() 450 forum posts 127 photos | Posted by Neil Wyatt on 14/07/2018 17:20:41:
