duncan webster | 14/05/2018 18:48:25 |
5307 forum posts 83 photos | I think we're all getting a bit carried away. The figures quoted for the eyebolt will assume it is screwed into something strong enough that the eye bolt gives up first, how else could they test it.
Michael Gilligan | 15/05/2018 08:56:23 |
![]() 23121 forum posts 1360 photos | Posted by Michael Gilligan on 14/05/2018 16:14:33:
... I don't really think I can contribute any more to this discussion. .
We have, I think, established beyond all reasonable doubt that a properly installed M6 eyebolt would comfortably support Peter's 17Kg load. BUT the local quality of the cast iron remains unknown. Although unlikely, it is feasible that Peter has tapped into a casting flaw ... Given the modest load under discussion, it should be a very simple matter to conduct a 'proof test' at [say] 80Kg. MichaelG. |
Zebethyal | 15/05/2018 10:11:51 |
198 forum posts | Posted by Peter G. Shaw on 14/05/2018 15:38:14:
I am aware that numerous people have used gas springs as used on car boot lids, indeed I have a set of plans for using one from a Peugeot 105 series. The article by Phil Dawes that I referred to in my original post states that the force generated by a gas strut is non-linear. I have no way of checking that, so I can only go by what Dawes has said, hence the idea of using a counterbalancing weight which should be a linear force, and which does actually make some sort of sense to me. The basic idea then, is to attach a cycle chain to the top of the milling head, route it over the top of the column via a pair of wheels, and then suspend a weight of, in my case, 18-19kg on the end of the chain. The reason for the extra weight over the actual weight of the head is to provide a permanent up force on the head. So, no connection to garage roofs
As to the potential non-linearity of a gas spring: I have not noticed this myself. With the weight of the head sitting on the spring, it seems pretty linear in both the upwards and downwards directions on my mill, requiring about the same level of force to move throughout the range of motion, regardless of direction of travel. It can be wound up or down using one finger on the rack feed handle albeit with a small level of resistance due to the gas moving in or out of the cylinder on the spring. This maybe down to my choice of spring - I am using a 15Kg gas spring with 210mm of possible movement. The mill head will also stay put without needing to be clamped wherever I choose to stop, due to spring resistance and friction in the rack assembly (obviously I would not think of machining like this), so acting as a pretty good counterbalance I believe. Also because the threads on my spring go in from the side of the mill, I have no worries about them ever pulling out because there is very little tension on the threads, all the force is at right angles to the threads and cast iron is very good at resisting shear forces. Far be it from me to stop you from installing a counterweight and chain - whatever works for you, I am merely suggesting an alternative that was cheap (IMHO), takes up minimal space, took less than 30 minutes to install and would still allow the tilting head to be used on the original installation if required. Edited By Zebethyal on 15/05/2018 10:16:25 |
Michael Gilligan | 15/05/2018 11:02:56 |
![]() 23121 forum posts 1360 photos | Posted by Zebethyal on 15/05/2018 10:11:51:
I am aware that numerous people have used gas springs as used on car boot lids, indeed I have a set of plans for using one from a Peugeot 105 series. The article by Phil Dawes that I referred to in my original post states that the force generated by a gas strut is non-linear. ... As to the potential non-linearity of a gas spring: I have not noticed this myself. ... . This may be of interest: **LINK** http://www.stabilus.com/fileadmin/download/Vehicle_GB_12_12.pdf MichaelG. |
Zebethyal | 15/05/2018 11:30:22 |
198 forum posts | Posted by Michael Gilligan on 15/05/2018 11:02:56:
I am aware that numerous people have used gas springs as used on car boot lids, indeed I have a set of plans for using one from a Peugeot 105 series. The article by Phil Dawes that I referred to in my original post states that the force generated by a gas strut is non-linear. ... As to the potential non-linearity of a gas spring: I have not noticed this myself. ... . This may be of interest: **LINK** http://www.stabilus.com/fileadmin/download/Vehicle_GB_12_12.pdf MichaelG. Thanks Michael, That confirms what I was seeing - the document states that "Unlike mechanical springs, gas springs have an extremely flat, almost linear characteristic curve and therefore allow a uniform comfortable adjustment or pivoting movement", the graph also shows exactly the same force required for both compression and extension. |
Neil Wyatt | 15/05/2018 13:13:28 |
![]() 19226 forum posts 749 photos 86 articles | Just a thought, when I replaced my brake calipers I noted that they were attached with M8 screws into cast iron, I have cast iron chucks/faceplates fitted using M6 studs. I think we are ALL guilty of overthinking this, the simple answer 'M6 will be fine' was all that was needed. Neil |
John Reese | 15/05/2018 16:53:02 |
![]() 1071 forum posts | Posted by richardandtracy on 11/05/2018 21:06:33:
If it is really cast iron, as opposed to cast steel, then the strength will be very much less than expected. At the turn of the 1800's to 1900's, the max tensile strength for cast iron was considered to be 2000 psi, and anything stronger was cast steel. In modern units, this is 13.8 N/mm^2. So, the shear strength is 65% of that at 9 N/mm^2. This goes a long way to explain why Victorian machinery was so huge for its output. Regards Richard.
I would be very surprised if 19th and early 20th century cast iron poured by a reputable foundry would have a tensile strength below 20,000 psi. Even the lower grades if iron used today would have a tensile strength around 40,000 psi. Cast steel is a much different metal having a carbon content probably less than 0.4% where cast iron would have 3.5 to 4.5% carbon. Cast iron contains flakes or nodules of graphite. Steel does not. |
SillyOldDuffer | 15/05/2018 18:26:43 |
10668 forum posts 2415 photos | Posted by John Reese on 15/05/2018 16:53:02:
I would be very surprised if 19th and early 20th century cast iron poured by a reputable foundry would have a tensile strength below 20,000 psi. Even the lower grades if iron used today would have a tensile strength around 40,000 psi. Cast steel is a much different metal having a carbon content probably less than 0.4% where cast iron would have 3.5 to 4.5% carbon. Cast iron contains flakes or nodules of graphite. Steel does not. Apples and oranges I suspect! 20000psi is the breaking point of some well-made cast-irons. But you wouldn't run a machine made of cast iron at anything like that level. In practice there is always a hefty safety factor built in. How big it is depends on the material and conditions of service, but it's unlikely to be less than 4:1, and 8:1 and stronger is likely. As even top quality cast iron is poor in both tension and alternating stress Richard's 2000psi limit is very reasonable.
Edited By SillyOldDuffer on 15/05/2018 18:27:37 |
Tim Stevens | 15/05/2018 20:17:11 |
![]() 1779 forum posts 1 photos | Regarding gas springs and their non-linearity - By the very nature of a gas spring it cannot be linear. The pressure doubles when the volume is halved, and this means that the load doubles when the length is halved. Halve it again (ie half as much further movement) and the load doubles again. The same extra load for half the extra movement = non linear. The length in all this is of course the length of the gas chamber, not the total length (which is longer because of the piston rod, and the end fittings etc.) But the principle is sound - gas springs do not obey Hooke's law, or as you might say, they are non-linear. Sorry Cheers, Tim |
Neil Wyatt | 15/05/2018 21:46:05 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Tim Stevens on 15/05/2018 20:17:11:
Regarding gas springs and their non-linearity - By the very nature of a gas spring it cannot be linear. The pressure doubles when the volume is halved, and this means that the load doubles when the length is halved. Halve it again (ie half as much further movement) and the load doubles again. The same extra load for half the extra movement = non linear. The length in all this is of course the length of the gas chamber, not the total length (which is longer because of the piston rod, and the end fittings etc.) But the principle is sound - gas springs do not obey Hooke's law, or as you might say, they are non-linear. Sorry Cheers, Tim Michael's link describes gas springs with progressive, linear and 'degressive' spring force. This appears to be achieved by a combination of partial liquid fill and the presence of pressurised gas on BOTH sides of the piston. I'm sure we have all had the experience of opening a boot or bonnet where the spring force suddenly INCREASES near maximum extension, which is what I assume they mean by 'degressive'. Here's a patent but I won't pretend to understand it after one look. It would be interesting to read a simpler explanation of how this is done. Neil |
Michael Gilligan | 15/05/2018 21:54:17 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 15/05/2018 21:46:05:
Regarding gas springs and their non-linearity - By the very nature of a gas spring it cannot be linear. The pressure doubles when the volume is halved, < etc > ... It would be interesting to read a simpler explanation of how this is done. Neil . This is one of the better descriptions that I have seen: **LINK** http://www.vapsint.com/en/technology-and-characteristics-of-gas-springs/ Sorry, Tim ... I think your description might be a little over-simplistic. MichaelG. |
Tim Stevens | 15/05/2018 22:36:11 |
![]() 1779 forum posts 1 photos | Simplistic - yes, that's me. I was referring to gas springs, though, not gas-hydraulic combinations, as if you complicate things you can get anything you like. Even then, linearity (which was the original concern I was addressing) is a very complex thing to achieve, and impossible with a gas spring properly so called. Cheers, Tim |
Zebethyal | 16/05/2018 08:28:49 |
198 forum posts | If the gas spring reacted like you mention then it would be like attempting to compress a bicycle pump with the end closed off (thumb over the end) and I would agree with you entirely. if such a spring were used on my mill, it would require increasing force to lower the head, constantly wanting to return to the uppermost position - this is most certainly not the case, it will in fact sit happily at any position throughout the travel without any locking of gibs. The ones used for car boots/bonnets/cupboard doors most definitely do not react like that, they are smooth throught their operational range. Yes, they may require some effort to start compressing if there is no pre-load, but once that load is in place, they do not react like the above mentioned bicycle pump. Maybe they are not true gas springs, but gas struts, or some other name, however that appears to be how they are marketed, and is most definitely the description on the item I bought. |
SillyOldDuffer | 16/05/2018 11:35:12 |
10668 forum posts 2415 photos | Not had time to absorb how the graphs work but this guidance should allow an reasonable estimate (of the bolt in cast iron problem, not gas struts!)
Edited By SillyOldDuffer on 16/05/2018 11:35:56 |
Michael Gilligan | 16/05/2018 11:44:25 |
![]() 23121 forum posts 1360 photos | Posted by David Murray 1 on 11/05/2018 12:26:09:
Unbrako have a good PDF on the subject **LINK** . S.O.D. ... for info. ^^^ MichaelG. |
SillyOldDuffer | 16/05/2018 16:05:42 |
10668 forum posts 2415 photos | Posted by Michael Gilligan on 16/05/2018 11:44:25:
Unbrako have a good PDF on the subject **LINK** . S.O.D. ... for info. ^^^ MichaelG. Doh!!! |
Ian P | 16/05/2018 16:38:39 |
![]() 2747 forum posts 123 photos | Posted by Tim Stevens on 15/05/2018 20:17:11:
Regarding gas springs and their non-linearity - By the very nature of a gas spring it cannot be linear. The pressure doubles when the volume is halved, and this means that the load doubles when the length is halved. Halve it again (ie half as much further movement) and the load doubles again. The same extra load for half the extra movement = non linear. The length in all this is of course the length of the gas chamber, not the total length (which is longer because of the piston rod, and the end fittings etc.) But the principle is sound - gas springs do not obey Hooke's law, or as you might say, they are non-linear. Sorry Cheers, Tim I dont profess to know the technicalities of how gas struts actually work but have a feeling that they are actually 'linear' (within a certain tolerance) over a specified operating range. As you mention, pressure would double if the volume was halved, but with a strut, how do we know the volume has been halved? It may be that there is a dead space in the volume so that the change in volume is only a small fraction of the total. The other big factor is the high initial pressurisation of the Nitrogen which means the pressure change due to volume reduction is only a fraction of the total static pressure. The clever bit I think, are the seals. Judging by the 'Danger, do not dismantle' warnings I presume the internal pressures are quite high, certainly it has discouraged me from pulling one apart! Ian P
Michael Gilligan | 16/05/2018 16:57:25 |
![]() 23121 forum posts 1360 photos | Ian, It's probably worth following the vapsint link that I posted yesterday. ... it gives a concise explanation of the principle. MichaelG. |
Ian P | 16/05/2018 20:31:04 |
![]() 2747 forum posts 123 photos | Posted by Michael Gilligan on 16/05/2018 16:57:25:
Ian, It's probably worth following the vapsint link that I posted yesterday. ... it gives a concise explanation of the principle. MichaelG. Thanks Michael I had read all the posts on this thread and followed most of the links but missed that one. Ian P |
