Is anyone else going to try this model ?
Neil Wyatt | 22/04/2015 19:16:31 |
![]() 19226 forum posts 749 photos 86 articles | Martin, You can safely exchange 'phone numbers using the 'message member' icon below people's posts. This sends a 'private message'. Neil |
martin ranson 2 | 23/04/2015 14:09:58 |
![]() 135 forum posts 2 photos | Thanks Neil ... I did not know that ... have now given my number to Alex ... martin |
Alex Collins | 24/04/2015 18:14:11 |
![]() 147 forum posts 38 photos | All the bushes are made. The end caps are bored for the fire tube. I decided on the thickness of the flange + 1.5mm for the fire tube height. One thing I have learned. Don't solder the copper tube into the Steam bush before you try and fit it. I may have to remake this one. I'll flux it well and drop a ring of solder over the tube so that it as good as solders itself with the bush. Lets hope we don't block the tube in the process ! |
Alex Collins | 26/04/2015 08:31:40 |
![]() 147 forum posts 38 photos | Attempted soldering the end cap and pressure gauge bush yesterday. |
martin ranson 2 | 26/04/2015 10:09:47 |
![]() 135 forum posts 2 photos | Alex from martin ranson ... years ago I bought two ROTHENBERGER blowlamps from the local plumbers merchants ( B and Q also sell them ) ... wonderful creations ... they use the yellow cylinders of MAP gas ... NOT the red cylinders of propane ... now I can melt brass and copper if I try ... be careful where you point it !!! do not set the shed on fire !!! martin |
Alex Collins | 29/04/2015 18:21:58 |
![]() 147 forum posts 38 photos | Been getting on with the Boiler fittings. |
Alex Collins | 03/05/2015 14:29:26 |
![]() 147 forum posts 38 photos | MAP gas torch borrowed. |
Alex Collins | 03/05/2015 14:31:25 |
![]() 147 forum posts 38 photos | The rest of the Boiler fittings are in Pickle at the moment and soldered as expected with Easyflo2.
Boiler Bri | 03/05/2015 17:52:56 |
![]() 856 forum posts 212 photos |
Well done Alex, I am glad someone has taken on this engine from the series currently running in ME. It will be a great reference for everyone and make a change from the slog of larger machines that can be made. Personally I am stuck with building a 4" traction engine a 5" sweetpea and making a boiler for a 4 wheel chub. + domestic chores OH and working ( dull). I keep watching Jason who makes some very interesting models and I just wish I had the spare time. so keep up the good work, I for one enjoy the forum listings that you are posting. Brian |
Alex Collins | 04/05/2015 10:26:16 |
![]() 147 forum posts 38 photos | Today I hope is soldering day for the boiler where this lot could become one..... |
JasonB | 04/05/2015 10:32:50 |
![]() 25215 forum posts 3105 photos 1 articles | The solder should flow enough to fill most of the gap to give a good joint but its always harder to completely fill it as the boiler dia gets smaller. |
Alex Collins | 04/05/2015 18:24:33 |
![]() 147 forum posts 38 photos | It's been a long and busy afternoon. A Sand Blaster made clean up super easy. A brush with the wire wool and we setup to do the 4 Boiler Bushes. |
Alex Collins | 04/05/2015 18:50:20 |
![]() 147 forum posts 38 photos | I have just had one of those "Oh Bother" Moments...... |
JasonB | 04/05/2015 19:05:24 |
![]() 25215 forum posts 3105 photos 1 articles | Probably should have soldered in the top bushes and then finished tapping them before soldering on the side bush with its pipe. Either have to unsolder the side bush or have a go at making a 3/8" tap from silversteel with a hole drilled up the middle to clear the small pipe. Also take it easy with the sand blaster, each use will take away a bit of the coppers thickness. |
Alex Collins | 04/05/2015 20:07:01 |
![]() 147 forum posts 38 photos | Boiler is out of the pickle. |
martin ranson 2 | 05/05/2015 13:28:27 |
![]() 135 forum posts 2 photos | Alex ... your post on 4th. May ... asking how to radius the inside of the2 bushes for the water gauge ... please use bronze not brass ... my method for the task is a large half round file ... I have no separate milling machine ... as regards a hearth I have been using DRY house bricks for decades ... I repeat, DRY bricks, some left intact and some chopped in half ... a question for you ... what sort of acid do you use for a pickle ? I always use 10% sulphuric acid and leave the items in it for 30 minutes ... BLACKGATES sell concentrated acid ... if you could find someone locally to share it with, then you do not end up with storing strong acids in the workshop. If you end up having to fasten the water gauge bushes on after the boiler is complete, be careful drilling the copper as it will be very soft after silver soldering ... a hollow sacrificial bolt may be a useful method to clamp the bush onto the boiler ... when finished the bolt could be drilled through ... hopefully the centre hole wil stop your drill wandering too much. if you try to dismantle a silver soldered boiler it can be dangerous ... it is very easy to have a piece of red-hot metal bouncing round the workshop !! for me I would not do it ever again ( don`t ask ) ... also the copper tube can easily end up getting squashed out of shape. Looking at your lubricator photo ... the piping looks a bit different from mine ... what is the long piece of piping on the right hand side please ? Can you still use the lathe to drill the small communicating hole into the cross-bar ? or have you already drilled it ? martin
Alex Collins | 05/05/2015 17:29:55 |
![]() 147 forum posts 38 photos | Hi Martin. |
Alex Collins | 05/05/2015 18:26:32 |
![]() 147 forum posts 38 photos | I have radiused the inside of the water gauge bushes on the lathe. As for the boiler ends. I call them close to perfic. Your comments and thoughts would be welcome. |
Steven Greenhough | 05/05/2015 18:58:43 |
144 forum posts 54 photos | Nice work Alex. |
JasonB | 05/05/2015 19:02:29 |
![]() 25215 forum posts 3105 photos 1 articles | Looking good, a couple of punch marks throw up enough of a burr to give a nice gap for the solder. |
