BA and MOD D.P. change wheels for modern boxford lathe
Tony Ray13/06/2013 13:00:56
238 forum posts
47 photos
Good idea Mark.
If it helps anyone the M300 M250 spline is 6 off 1/4" straight sided splines major diameter 1" the spline height is about 0.051".
There is plenty of info on metric ISo splines but I could not access any BS standard for imperial splines on the 'net. Does anyone know if the above configuration relates to a standard ?
and if so what ?
Tony
John Stevenson14/06/2013 20:23:16
5068 forum posts
3 photos
Tony,
I have a load of spline data and some old splined gears but think they are Colchester.
Unfortunately I'm stuck in Russia for about another week or so and can't access that data.
John S.
SteveI16/06/2013 20:40:20
248 forum posts
22 photos
Hi,
Based on this drawing of the dimensions of the spline:
I have measured the following:spline-gear-dimensions:
D== 23.10mm
d== 20.00mm
W== some range on this 5.50 through upto 5.55mm
h== hard to accurately measure
From some web research I understand that the parameter dimensions are controlled by the fit for a particular application. I also found a link detailing the relationship between the paraemters and dimension D. I have no idea if this was authoritative. Perhpas a member can educate me?
For six splines W for all fits == 0.250D
For permanent fit: h== 0.050D, d==0.900D
For slide without load fit: h== 0.075D, d==0.850D
For slide under load fit: h== 0.100D, d==0.800D
I'd be interested to learn if and what standard these gears splines are machined to. Any help appreciated.
Thanks,
Steve
Ian S C17/06/2013 13:08:34
7468 forum posts
230 photos
The way I'd do it; shaft dia (d) with a key way cut (W) x (h) or 1/2(W), going by the drawing of Steve's, I'd use this as an alterative if I could not cut the spline. Ian S C
Tony Ray17/06/2013 23:09:57
238 forum posts
47 photos
Steve,
Thaks for the dimensions. There may be other metric standards but it doesn't appear be this one:
BS 5686:1986, ISO 14-1982: Specification for straight-sided splines for cylindrical shaft
an excerpt is here
http://www.roymech.co.uk/Useful_Tables/Keyways/Spline.html
Unfortnately standards in general are not freely available. It would seem a bit crazy if it isn't based on some standard.
I'm seriously considering trying to pull changewheel data together for the most popular lathes & publishing it to the web - perhaps Tony Griffiths would put it on his lathes.co.uk site ?
Tony
Tony Ray17/06/2013 23:11:37
238 forum posts
47 photos
John,
Any spline info you could contribute would be most gratefully received.
Pehaps you'd better get back before Obama & Putin fall out completely !
Tony
Stub Mandrel18/06/2013 14:28:51
4318 forum posts
291 photos
1 articles
Hi Steve1
My Machinery's Handbook has trucklodads of data for involute splines, involute serrations and straight splines, but the latter only in SAE (Society of Amercan Engineer's sizes, all imperial).
It could be an imperial size although it would be a rather sloppy fit on a 7/8" shaft.
SteveI18/06/2013 20:14:36
248 forum posts
22 photos
Neil,
I of course can't be sure if they are imperial. However note that pretty much everything that I can check and measure or find in the manual on this lathe is metric.
Steve
Clive Foster18/06/2013 21:22:54
3630 forum posts
128 photos
Steve
Mystery solved. These are "Straight sided splines, bottom fitting. Shallow." to BS 2905:1953.
I have an electronic copy of that standard if you need it complete with all the fit data but for the dimensions you have measured the lower and upper limits in proper imperial units for a 7/8 inch (nominal) shaft are :-
D = 0.905 / 0.915, d = 0.7880 / 0.7890, W = 0.2180 / 0.2195,
Note that this is a hole refrenced system so the fit is defined by shaft clearance relative to a tightly specified minor diameter d.
The actual major and minor diameters are derived from an acane concept called effective diameter so its not possible to get the nominal size from shaft measurements. Fortunately this standard is said to be simplified compared to earlier versions as "due to the considerable developments in involute splines in recent years it is considered that 6 splines are sufficient for all classes of work requiring straight sided splines". The original standard covered 4, 6, 10 and 16 splines whilst its replacement provided tables covering from 8 to 80 splines on shafts from 1 to 10 inches diameter. Yikes!!
Side comment.
Your metric measurements are what is known as a "soft" conversion so great care is needed to accurately sort the clearances and fits. Funny numbers are likely. Hard conversions adjust the sizes slightly to get sensible numbers for nominal dimensions comprehensible variations for limits and fits. Hard conversions are great in the drawing office and factory but can be a right pain in the field where replacement parts made to hard conversion standards are just different enough to the original not to fit as intended. Something to be wary of where replica parts for old stuff is concerned.
Edited By Clive Foster on 18/06/2013 21:24:11
SteveI18/06/2013 22:27:12
248 forum posts
22 photos
Hi,
Thanks to all the help I am getting somewhere. My hope is that I if I can find some free time I'll calculate the tooth count of the gears I am missing. It will be nice to be able to post the complete specification of what is needed.
Steve
Michael Gilligan18/06/2013 23:09:34
23121 forum posts
1360 photos
Excellent input, Clive !!
