A clock that uses fibre optics to show the time (a work in progress)
magpie | 09/02/2013 10:14:59 |
![]() 508 forum posts 98 photos |
That did the trick, Thanks Keith. Cheers Derek. |
magpie | 09/03/2013 15:51:25 |
Cheers Derek.
Edited By magpie on 09/03/2013 15:55:38 |
Stewart Hart | 09/03/2013 16:39:17 |
![]() 674 forum posts 357 photos | Blimey Dek you are a tease you've got us all with our tonges hanging out you're going to have to write this up. Stew
Springbok | 09/03/2013 19:45:20 |
![]() 879 forum posts 34 photos | Stunning work Bob |
magpie | 10/03/2013 09:07:37 |
Thanks Bob. Stew, have you been talking to Diane ???? Cheers Derek. |
Stovepipe | 10/03/2013 19:52:03 |
196 forum posts | What exemplary craftsmanship ! Dennis |
magpie | 09/05/2013 20:12:16 |
Cheers Derek.
Edited By magpie on 09/05/2013 20:14:23 |
Stub Mandrel | 09/05/2013 21:29:29 |
![]() 4318 forum posts 291 photos 1 articles | Very neat! > 10mm cobalt spot drill 90 degree point used as a milling cutter. Handy tip! Thanks for that1 Neil |
magpie | 17/02/2014 16:29:59 |
![]() 508 forum posts 98 photos | Here we go again ! This is the new base for the clock, drilled and ready for all the bits to be fitted (after they have all been polished that is). The next pic shows the rear of the base with the LED power units on a slide for easy access. The last pic is of the clock face marked out ready for drilling. It is also black Perspex but it has a protective film on at the moment to aid marking out. With a bit of luck I may even finish the whole thing this year. |
magpie | 22/03/2014 21:01:43 |
![]() 508 forum posts 98 photos | It's that man again. Here are a few more photos of work to date. The first four show the fibres being attached to the "sending" ends of the mechanism, and the last two show progress at putting the thing back together. The base is,at present mounted on a jig to enable me to work underneath. When the clock is finished, I hope to get a mate to make a vid, as my little camera does not take the best of photos.
jason udall | 23/03/2014 22:57:49 |
2032 forum posts 41 photos | Beautiful |
jason udall | 23/03/2014 22:59:06 |
2032 forum posts 41 photos | Bits look like an interosioster... ..inter roseter... Edited By jason udall on 23/03/2014 23:00:04 |
Stewart Hart | 24/03/2014 06:39:12 |
![]() 674 forum posts 357 photos | That's stunning Dek:- How many gallons of BRASSO did you use up on it Cheers Stew
magpie | 24/03/2014 18:54:51 |
![]() 508 forum posts 98 photos | Jason, thanks for the compliment and yes it will look even more like an "interrositer" when the face is fitted. Stew, it took best part of a week to polish all the bits, and looking for the ones that the mop threw up the workshop. Not "brasso" but some stuff called "clockshine" which was recommended by some of the other clock makers on this forum. Seems like good stuff, but time will tell !!! Cheers Derek. |
Neil Wyatt | 24/03/2014 20:07:43 |
![]() 19226 forum posts 749 photos 86 articles | Derek this is turning into an amazing piece of steampunkery! Can you give a clue what the display will look like, or is it a surprise? Neil |
jason udall | 24/03/2014 20:31:26 |
2032 forum posts 41 photos | Steampunkery?.... |
Neil Wyatt | 24/03/2014 21:46:41 |
![]() 19226 forum posts 749 photos 86 articles | Steampunk - a movement that blends Victorian sensibilities, materials and technologies with a modern obsession with gadgets. Modern technology in a Victorian style (e.g. brass & mahogany computer keyboard) or modern concepts implemented with Victorian technology (e.g. steam powered tanks). Neil |
magpie | 24/03/2014 22:36:26 |
![]() 508 forum posts 98 photos | Hi Neil, in a previous post on the 17/2/14 (a bit further up this thread), The last of three photos shows the clock face. This is black Perspex but in the photo it is covered in a protective film for marking out. At the top are two concentric squares, the outer one will show the minutes and the inner one the hours. the two curved lines will show the seconds with both rows working simultaneously. (you may have to bring the photo up to full size to see the markings). The clock face will be fixed to the top of the tube showing at the rear of the main unit. I think "steampunk" fits the job rather well, but as I had the idea for the clock in 1979 I don't think the expression was around at the time. Cheers Derek. |
jason udall | 24/03/2014 22:49:13 |
2032 forum posts 41 photos | Neil.. I was aware of the term/genre The area is to me fun. I also got that vibe but in deference to the members here and esp. Magpie choose to avoid that term.. ( don't know why I thought it might offend but was trying to be poilite..). Yes else where I would call this Steampunk. .and grand steampumk too. ..also glad my interroister reference wasn't too obscure either |
Stewart Hart | 25/03/2014 06:36:12 |
![]() 674 forum posts 357 photos | I've had the pleasure of eyeballing this wonderful time machine in the flesh, and I call it a time machine because Jewels Vern's novel came into my mind the moment I saw it, so I recon a better description would be Jewels Vernery That said Deks' machining of the parts is some of the crispest machining I've ever seen:- out of this world. Stew
