Michael Gilligan | 06/04/2023 17:07:00 |
![]() 23121 forum posts 1360 photos | Fair comment, Jelly Presumably David knows how his local council is interpreting it … and for the rest of us ‘a rose is still a rose’ MichaelG. |
Jelly | 06/04/2023 17:32:46 |
![]() 474 forum posts 103 photos | If I was David I wouldn't worry too much about the local council's expectations (which can usually be "shaped" quite easily as long as you articulate things in a way which allow them to say they have met the objectives they've been set)... It's ensuring that the first batch of members are aligned to the agreed interpretation and that as further members join, it remains clear and isn't subject to chinese whispers. I suspect having council oversight will make that less painful than it would otherwise be for volunteers like David, but it's definitely something to go into with your eyes open. Also maintaining control over storage of materials and projects (as well as "Projects" |
Buffer | 06/04/2023 17:39:32 |
430 forum posts 171 photos | John What happened about the epoxy or concrete mill you were making a few years back? |
Jelly | 06/04/2023 17:50:26 |
![]() 474 forum posts 103 photos | Posted by JasonB on 06/04/2023 13:18:16:
Thanks for the post Rod, I just looked and saw the Denford option in F360's post processor which would make it quite usable as the free F360 will do most things needed for thos ewanting to try out CNC even though as you say it's a light duty machine. Just looking at the Denford spec and it only has the standard 2500rpm Sherline spindle rather than the high 7000rpm option which would certainly lead to long run times given the small cuts that would also have to be taken. Not a problem in the Home workshop as you can do other things but may need to take a sleeping bag to the local makerspace and hope you are not in a que waiting to use it. It appears things have improved somewhat in the current iteration then, as this definitely wasn't my experience of Denford's older machines (which credit to them are extremely well built, just with awful control units). Ultimately if there's now independent and commercial support available for their products it does make them much less limited, and removes a lot of my objections. I would still be a bit concerned about service support and planned obselecence though, as compared to a home workshop or school DT department setting, I would expect a machine in a Makerspace to get comparatively heavy (and sometimes clumsy) use, a bit like how hire cars and company vans get a very hard life compared to personal vehicles. . I would also still agree with the initial thrust of David's argument that the specific model of mill proposed is a bit on the limited side though... Moving up to the Denford VMC1300 (if the supplier is a sticking point, or an equivalent Haas, Syil or a secondhand industrial machine) would be an excellent "anchor tool" to draw in However without knowing the full scope of the councils budget and ambitions, we can't know if they haven't planned for other such "anchors" with their initial group of organisers which are seen as relevant to know local demand. Edited By Jelly on 06/04/2023 17:55:16 |
David George 1 | 06/04/2023 18:26:01 |
![]() 2110 forum posts 565 photos | The person in charge of setting up the Makerspace has little practical experience in workshops and has formed a group to help to find what is needed and the building has had a design done by a company which I believe is involved in school workshops. He has asked us what we think of the layout and equipment that they have proposed as the building is going to be gutted and new spaces for each area are to be formed in the shell of the building and any room sizes changed by the architect before the end of this month. There are to be textiles including sewing, machine embroidery and printing. Woodwork including power saw, planner and shaper and CNC router. Metalwork pillar drill, bench top lathe, larger floor lathe, bench top milling machine and CNC milling machine. Electronics section and a CAD drawing section. 4 seats of software etc. There will be a small charge to use the unit on a monthly basis. There is a substantial amount of money available for the whole prodject but I am not able to say the amount but it is part of a government Grant for the area which can only be spent in such local prodjects and if not used would have to be returned. |
