Joseph Noci 1 | 09/04/2022 13:12:09 |
1323 forum posts 1431 photos | |
Tim Stevens | 11/04/2022 17:44:46 |
![]() 1779 forum posts 1 photos | There is a serious corrosion problem with almost all the motorcycle-bullet sleeves currently on the market. The ones sized just over 4mm diameter, not the Japanese sizes. The originals had a tinned brass sleeve, but for some years they seem to be tinned steel. OK when new, but in the damp, the sleeve rusts inside. Nothing to do with flux, just the weather and the space - damp gets in, with salt in the winter, and the mixture of brass bullet and steel sleeve causes electrolytic corrosion. This creates resistance in the joint, and then the corrosion really gets going. There are some bronze-coloured sleeves which are not double-ended, the sleeve has a crimp or solder fitting at one end. They seem much better. Personally, I do not have a professional factory crimping machine, so I do the best I can with hand crimpers, and then fill the joint with solder. It works for me. Any theory about heat shrink keeping the water out does not fit with my experience, and the idea that copper wire will harden with heat is contrary to the science - honest! Regards - Tim (ex BSA, ex Norton, ex Hesketh) |
Oven Man | 11/04/2022 17:59:05 |
![]() 204 forum posts 37 photos | Posted by SillyOldDuffer on 09/04/2022 11:02:26:
Posted by Mike Poole on 08/04/2022 22:50:02:
... crimping and soldering are both effective but I believe a good crimped connection is many times more reliable than soldering. ... That's what years of industrial experience confirm. Solder is excellent unless vibration is present. Two causes: solder temperatures tend to harden copper, making it more vulnerable to fatigue failure. The effect is tiny, but shows up when long leads are vibrated over long periods; worse, solder tends to wick between the strands of flexible copper wire, creating in stress concentrators that break the strands one by one. Again, vibration is required. Crimping avoids both problems, plus dry-joints, and flux corrosion. In electronics, soldered joints are the best way to fix small components to a printed circuit board. Nothing moves much even if the board is vibrated, and it's not difficult to stiffen boards with pillars and fit foam pads. However, wires often aren't soldered to plugs and sockets. It's partly because long wires tend to flap and break at the connection. Old school reduced the problem by lacing wires into bundles and clamping them to the chassis, but this isn't practical with ribbon. As always, the need to apply best practice increases with time, volume and circumstances. A soldered joint on a classic bike kept for display rather than ridden regularly would probably last forever. Doing the same on a production run of a few hundred thousand bikes sold to hard riding customers would cause avoidable breakdowns and a reputation for poor reliability. Dave Absolutely Correct. Back in the 1970s we thought we were being clever crimping and then soldering connectors on rally cars. It proved to be a disaster, the crimped and soldered joints failed very quickly with the vibrations. The crimped only joints never gave any trouble. Peter |
bernard towers | 11/04/2022 20:09:57 |
1221 forum posts 161 photos | Temperature does not harden copper its movement (vibration) that does |
Clive Hartland | 11/04/2022 22:02:13 |
![]() 2929 forum posts 41 photos | I have worked on mains electric kit that had to be used in a wet environment, I used adhesive heat shrink and had no leakage. |
SillyOldDuffer | 11/04/2022 22:16:35 |
10668 forum posts 2415 photos | Posted by bernard towers on 11/04/2022 20:09:57:
Temperature does not harden copper its movement (vibration) that does Very likely vibration causes work hardening too, but I was referring to a form of Age Hardening where the application of heat below annealing temperature causes precipitation within the grain structure. Apparently it can happen at room temperature! The Copper's purity makes a difference, and solder compromises that by mingling Lead, Tin and whatever else in the Solder with Copper near the surface. Not the same as annealing, in which Copper is softened by heating well above soldering temperature and then quench cooling. The effect is small. If work hardening due to vibration was the major cause of failure, crimped and solder joint would behave the same. They don't: vibrated soldered joints are more likely to fail than vibrated crimps. Dave |
Michael Gilligan | 12/04/2022 07:03:26 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 11/04/2022 22:16:35: […] If work hardening due to vibration was the major cause of failure, crimped and solder joint would behave the same. They don't: vibrated soldered joints are more likely to fail than vibrated crimps. . Not quite true, Dave … Your closing statement is valid, but the preceding sentence is not. Peter’s explanation is good … at a micro level, vibration fatigue failure has a lot to do with the ‘stress-raiser’ created by filling the crimp with solder. [stated from memory … If I can find corroboration, I will report back] MichaelG. |
Michael Gilligan | 12/04/2022 07:14:56 |
![]() 23121 forum posts 1360 photos | This paper doesn’t actually address the specific issue under discussion here … BUT it is very informative, and I think the final image nicely illustates my point. **LINK** : https://www.osti.gov/pages/servlets/purl/1356221 MichaeG. . On the other hand … here’s some evidence of ineffective crimping: https://www.osti.gov/servlets/purl/1288669 Edited By Michael Gilligan on 12/04/2022 07:27:07 |
martin haysom | 12/04/2022 08:42:22 |
![]() 165 forum posts | it all comes down to the skill of the person doing the job soldering requires some. any fool can squeeze a pair of pliers |
noel shelley | 12/04/2022 09:35:15 |
2308 forum posts 33 photos | Multi strand wire and fluids are never happy bed fellows ! Ask any one who had a Landrover TD5 engine ! engine oil would cappiliary from the engine to the computer under the seat along about 8' of wire. Noel. |
Tim Stevens | 12/04/2022 10:57:55 |
![]() 1779 forum posts 1 photos | A further factor is the attachment of the bullet (etc) to the insulation itself, and the nature of the insulation. Decent solder-type connectors (including bullets) include a clamp around the insulation of the wire. This is more effective if the clamping is done after the soldering has cooled - otherwise any clamp is filled with melted insulation which can be cut through. Yes, this does slow down the attachment process, but adds the stiffness of the insulation to that of the wire in vibration cases. In my mind, doing this sort of connection 'properly' is part of the discipline - it used to be called craftsmanship. Modern harness wire for vehicles tends to be insulated with a stiff version of PVC - with less, or different, plasticiser. This results in a stiffer wire, and one of smaller diameter - easier to feed through small spaces. The behaviour of rubber insulation is quite different from this more-rigid PVC. Regards, Tim |
