KWIL | 23/05/2020 12:36:45 |
3681 forum posts 70 photos | Lee, The block was held in a very substantial vice, initial 45 degree set by angle guage, then checked using contact probe at two points in vertical and horizontal plane. As said above, 45 degrees is 1 in 1 slope, so with zeroed probe you should get an equal vertical movement for each horizontal movement. If not you just have to tap adjust until you do, tighten and try again. Only suitable for one off making not mass production. |
Lee Jones 6 | 24/05/2020 19:00:46 |
258 forum posts 125 photos | Posted by KWIL on 23/05/2020 12:36:45:
The block was held in a very substantial vice, initial 45 degree set by angle guage, then checked using contact probe at two points in vertical and horizontal plane. As said above, 45 degrees is 1 in 1 slope, so with zeroed probe you should get an equal vertical movement for each horizontal movement. If not you just have to tap adjust until you do, tighten and try again. Only suitable for one off making not mass production. Ah yes, I see. Thanks for getting back to me. I'll add the 1:1 technique to my toolbox. |
Lee Jones 6 | 24/05/2020 19:05:03 |
258 forum posts 125 photos | Posted by Martin Connelly on 22/05/2020 18:58:38:
Lee, did you see this by John Baron on the Cutting a 45 degree V thread page 1? There was also a suggestion somewhere to cut a narrow slot first then cut the vee. This is how some of the purchased ones I have had their vees cut (the slot that is, not the 45 degree cutter part). Martin C Hi Lee, Guys, Whilst your picture shows one way of getting a 45 degree angle, its not a good way of holding work for milling. My recommendation would be to buy a proper inverted cutter and secure the work to the mill table properly. At a pinch you could use a 45 degree HSS or carbide countersink and take it easy with the cut. I did see both of those posts, thank you. Not overly keen on using a countersink for this. Seen some 45 degree side cutters and was considering something like THIS. I think I'm going to go for a sine plate, 'cos why not (and I think I'll get use out of it beyond this project).
Lee Jones 6 | 24/05/2020 19:25:47 |
258 forum posts 125 photos | Detour: [Project 4] Sine plate |
JasonB | 24/05/2020 19:26:47 |
![]() 25215 forum posts 3105 photos 1 articles | Those insert cutters won't work as you need to get down into the bottom of the Vee, you need something that goes almost to a point if using an angled cutter. A few suggested a shaper for these types of jobs, this popped up on my Youtube today which you may enjoy. Edited By JasonB on 24/05/2020 19:29:13 |
Lee Jones 6 | 24/05/2020 19:52:19 |
258 forum posts 125 photos | Actually the bottom of the 'v's are quite blunt: That cutter with those inserts was just a quickly Googled example. I'm sure you can pick-up sharper cutters. |
JasonB | 24/05/2020 20:10:37 |
![]() 25215 forum posts 3105 photos 1 articles | Lee that cutter will swing an inverted flat ended cone about 25mm across, So when used to cut the larger side of the Vee it will completely remove the smaller side, you need something that will cut like the red line, maybe 1mm at the bottom. |
Lee Jones 6 | 24/05/2020 20:36:57 |
258 forum posts 125 photos | Turn the work 45 degrees - put it on its side. |
John Baron | 24/05/2020 20:39:05 |
![]() 520 forum posts 194 photos | Hi Lee, Guys, A 90 degree HSS or Carbide countersink will easily cut those "V" slots. The reason I said to take it easy with the cut, is that the shaft size on some of the counter sink bits may only be 1/4" diameter. As are some of mine. I have a nice six flute one that would do the job at full depth because it is on a 20 mm shank and is only 25 mm diameter. I've got that one in a plastic handle and use it for deburring holes.
Lee Jones 6 | 26/09/2020 07:46:57 |
258 forum posts 125 photos | Posted by JasonB on 22/05/2020 12:43:18:
Posted by Lee Jones 6 on 22/05/2020 08:21:14:
How does 0.1mm over 480mm sound? As nobody else has answered from last night I get about 1/10th of that in X&Y eg 0.003mm in 140mm on a Chinese machine. What do you measure with to gain that level of accuracy? I tried to use a 10ths/inch indicator which measures 6 10ths/inch over 480mm. Although it's hard with my setup as it's not 100% rigid. Might end up making something else. |
JasonB | 26/09/2020 07:53:00 |
![]() 25215 forum posts 3105 photos 1 articles | I swing a lever DTI in a collet chuck at 70mm radius only a 0.01mm one but easy to see that the needle only moves part of a division |
Lee Jones 6 | 26/09/2020 07:55:15 |
258 forum posts 125 photos | Ha, that's cheating. Do you have a picture of your setup/shaft (no, I will not rephrase |
JasonB | 26/09/2020 08:06:30 |
![]() 25215 forum posts 3105 photos 1 articles | |
Michael Gilligan | 26/09/2020 08:09:13 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 24/05/2020 19:26:47:
. A few suggested a shaper for these types of jobs, this popped up on my Youtube today which you may enjoy. . Missed that, yesterday, Jason The opening ‘titles’ are sheer joy ... I shall watch it with due reverence, later. MichaelG. |
Lee Jones 6 | 26/09/2020 08:28:02 |
258 forum posts 125 photos | Ah, so you have a bought holder. Maybe that'll work better than my janky Heath Robinson setup. |
Meunier | 26/09/2020 16:02:40 |
448 forum posts 8 photos | Following on from Jason's shaper video which I found most interesting was this automotive manufacturing video from 2008. Particularly liked the crankshaft forging part starting at 8:08 (can you guess yet what this lump will become ? ) The interesting parts start at 2:00 in Edited By Meunier on 26/09/2020 16:04:33 |
Meunier | 26/09/2020 17:28:37 |
448 forum posts 8 photos | Complete fail ! here is the missing link to the video mentioned... https://www.youtube.com/watch?v=Uv30kAL2D1c DaveD |
Lee Jones 6 | 29/09/2020 14:27:06 |
258 forum posts 125 photos | Posted by Lee Jones 6 on 26/09/2020 08:28:02:
Ah, so you have a bought holder. Maybe that'll work better than my janky Heath Robinson setup. Received mine today from 'you know who'. It's soooo tiny! |
