Adam Harris | 09/03/2019 21:02:45 |
533 forum posts 26 photos | Yes well thanks for the advice and I agree the route of 15mm HSS bar seems way too expensive and I will make a mild steel bar to take small HSS inserts. For the 7/16" I like the idea of soldering (ordinary electric solder?) on old carbide tips but you must have a very large soldering iron or do you heat it up with a gas torch beforehand? |
duncan webster | 09/03/2019 21:31:40 |
5307 forum posts 83 photos | How about one of these, loctite a sleeve on for the 15mm, turn it down a tad for the 7/16 |
Andrew Johnston | 09/03/2019 21:47:15 |
![]() 7061 forum posts 719 photos | Posted by Adam Harris on 09/03/2019 21:02:45:
For the 7/16" I like the idea of soldering (ordinary electric solder?) on old carbide tips Normally brazed or sliver soldered. Andrew |
Adam Harris | 09/03/2019 22:04:07 |
533 forum posts 26 photos | Duncan £100 is well outside my target! |
Adam Harris | 09/03/2019 22:05:49 |
533 forum posts 26 photos | Andrew I think the MIG welder will come out from the bottom shelf for this then |
Paul Lousick | 09/03/2019 22:18:45 |
2276 forum posts 801 photos | Brazing and silver soldering would be difficult with a MIG welder. You only need a gas torch to silver solder. Paul |
JohnF | 09/03/2019 23:26:13 |
![]() 1243 forum posts 202 photos | Adam, Mild steel is not a particularly good material to make your boring bars from, better to choose something tougher say EN8, EN19 or EN24T. Silver steel is OK but not great either IMO, personally I use EN24T and it works well. John |
Adam Harris | 10/03/2019 00:53:23 |
533 forum posts 26 photos | Not bad Duncan. Thanks |
Adam Harris | 10/03/2019 01:02:55 |
533 forum posts 26 photos | Andrew/Paul, when talking Silver Soldering do you mean the cheap Aluminium Alloy rods used with a gas canister blow torch? Or are you talking about Silver-Flo and if so which one? |
JasonB | 10/03/2019 07:08:52 |
![]() 25215 forum posts 3105 photos 1 articles | I use this set of indexable holders made for boring heads 90% of the time. Some Banggood can be questionable but most of our suppliers have something between the two extreams that Duncan has shown. |
Paul Kemp | 10/03/2019 19:21:52 |
798 forum posts 27 photos | Posted by Adam Harris on 10/03/2019 01:02:55:
Andrew/Paul, when talking Silver Soldering do you mean the cheap Aluminium Alloy rods used with a gas canister blow torch? Or are you talking about Silver-Flo and if so which one? Adam, No not aluminium, silver solder. I have various grades kicking around the shed, a fair bit of the old easy flo No2 which apparently you are not supposed to use these days because of the Cadmium content. Also have some Cup alloys 434 and Johnson Mathey silver flo. Any of them will do pretty well. Use a high temp flux like Tenacity No 5 or I would think Cup HT5. For small jobs you can get away with the hand held DIY self contained torch with integral cylinder if you can arrange some fire bricks to concentrate / conserve the heat. Paul. |
John Rudd | 10/03/2019 19:35:13 |
1479 forum posts 1 photos | Posted by Pete White on 09/03/2019 20:31:16:
Posted by Paul Kemp on 09/03/2019 20:06:12:
First rate common sense to me, work just the same. As mentioned noring away at a 15mm chunk of hss doesnt appeal to me either
Apart from wearing away the grinding stone... |
John Paton 1 | 10/03/2019 23:06:23 |
![]() 327 forum posts 20 photos | Adam - I have sent you a PM John |
