Michael Gilligan | 28/01/2019 19:48:26 |
![]() 23121 forum posts 1360 photos | Fair enough, Jason ... You win MichaelG. . Edit: Thanks for posting the photo ... Funny way to design a lathe, methinks.
Edited By Michael Gilligan on 28/01/2019 19:59:22 |
Bazyle | 28/01/2019 20:53:51 |
![]() 6956 forum posts 229 photos | I have a Hobbymat. The bar is non-essential and non-structural. It is a strange design really being an overgrown watchmakers bar bed lathe. In practice although the bed forms the guide some of the cutting force is taken by the hefty leadscrew which is far thicker than on normal minilathes. I often think it would be nice to rebuild it with only the tailstock on the original bed and a new saddle on say two ground bars. |
Nicholas Farr | 28/01/2019 22:44:40 |
![]() 3988 forum posts 1799 photos | Hi, Bazyle is correct and it does not make any contact with the saddle or the tail stock. It's only purpose is to stop swarf dropping straight onto the lead screw. If I had the same problem, I would lay a washer that has a hole the same size as the dowel, on the end of the bar and then carefully build up the end of the dowel with TIG weld enough to get a pair of grips to pull it out. The washer will help to stop you welding it to the end of the bar. Regards Nick. |
John Haine | 28/01/2019 23:11:37 |
5563 forum posts 322 photos | Maybe the bar is there to help take the longitudinal reaction force of the leadscrew ? |
John Reese | 29/01/2019 02:34:51 |
![]() 1071 forum posts | It might be simpler to make a new bar. |
FMES | 29/01/2019 06:24:51 |
608 forum posts 2 photos | Just mig/tig a piece of studding on to the pin and screw it out using washers and a nut. Regards |
Nicholas Farr | 29/01/2019 06:43:27 |
![]() 3988 forum posts 1799 photos | Posted by John Haine on 28/01/2019 23:11:37:
Maybe the bar is there to help take the longitudinal reaction force of the leadscrew ? Hi John, the bar is only held in place by three dowel pins, which will not restrain any longitudinal forces of any sort and it is described as a spindle guard in the parts list. Regards Nick. |
Phil Pemberton | 29/01/2019 23:44:48 |
12 forum posts 2 photos | Wow, this thread went on a bit! Have to confess I stepped back last night to let you get your suggestions in In no particular order... Welding - the pin was about 3mm behind the panel so no chance of that. It's a 4mm diameter pin. Also, I don't have a welder (though this is tempting me to buy one!) Drill - this worked, once I ditched the HSS bit and went for a 4mm carbide bit. I ended up wrecking one of these when the drill skipped. A 4mm endmill split the side of the pin and finished the job, fell right out. The bar, incidentally, is mild steel, and so are the pins. 4mm dia, 15mm long. I've got some replacements on order. The pin was in there ludicrously tight, which explains why it wouldn't push out. From the bits of metal which came out, it looks like it had rusted in... which explains why the previous owner left it alone. I'm quite surprised how short it was, only 10mm when it's supposed to be 15. Yet another bodge done to this machine by its previous owner, one of several sadly. Thanks for all your help! Edited By Phil Pemberton on 29/01/2019 23:49:25 |
Mike Poole | 30/01/2019 03:42:22 |
![]() 3676 forum posts 82 photos | Use tapped pins if possible to make life easy in the future. Mike |
Ian S C | 30/01/2019 11:02:21 |
![]() 7468 forum posts 230 photos | I wonder if the previous owner had not been able to get it out, so cut 5 mm off, leaving you to work out how to get it out. Ian S C |
Bazyle | 30/01/2019 13:11:45 |
![]() 6956 forum posts 229 photos | I just went to have a look at mine. I hadn't realised the pins go into blind holes in the main support at the RHS end of the bed. I had assumed they were through holes. I think I would either drill through so I could use say M5 screws or make a little bracket on top. Anything other than what it is. edit: went and had another look. I'd ditch the bar and use a larger piece of Al angle as it could come further forward and down completely hiding the leadscrew. Edited By Bazyle on 30/01/2019 13:16:03 |
Former Member | 30/01/2019 16:46:51 |
[This posting has been removed] | |
Phil Pemberton | 04/02/2019 02:46:28 |
12 forum posts 2 photos | Alas, Barrie, it's cost me a couple of good carbide drill bits! Still, she's fixed now. I did find out why the pin wasn't embedded in the support when I tried to fit the replacement earlier. Looks like the previous owner cracked the support (which is made of plastic, seems to be Bakelite or similar) then "repaired" it with glue, filling the back with it in the process. I drilled out the hole to clean it and the repair gave way... Regardless, a bit of drilling and some JB Weld later, and the pin is back where it should be! |
Nicholas Farr | 04/02/2019 07:54:58 |
![]() 3988 forum posts 1799 photos | Posted by Phil Pemberton on 04/02/2019 02:46:28:
Looks like the previous owner cracked the support (which is made of plastic, seems to be Bakelite or similar) then "repaired" it with glue, filling the back with it in the process. I drilled out the hole to clean it and the repair gave way... Hi Phil, yes the support is similar to bakelite, the one on my Hobbymat was broken into a few bits **LINK** when I bought it, so I made a new one from a scrap piece of bearing housing **LINK** Regards Nick. |
