Boxford Model A stopping on slow speeds...?
JP Santos29/10/2018 20:01:26
49 forum posts
9 photos
thanks for the replies gents! I actually have that book "know your lathe" somewhere, was given to me a few years ago by the old boy who sold me my south bend lathe...
I have a big plastic container with lathe oil that I bought years ago and still going that's how big that thing is..at the time didn't know how much i'd need so bought I think 4L or something...
Need to buy a oil gun then, haven't looked in detail how are the fittings but from the top of my head i think they are that ball bearing type, but probably can find something on ebay.
thanks for the detail on the back of the headstock, who would have known there was something in there!
JP Santos30/10/2018 22:04:56
49 forum posts
9 photos
interesting.. just had a look on my lathe, and most of the nipples dont like for oil? they just look like normal grease nipples? although a tad smaller than the normal grease ones?
and did find that one tucked away!
Edited By JP Santos on 30/10/2018 22:06:40
thaiguzzi31/10/2018 05:23:08
704 forum posts
131 photos
Yes, pull them all out, measure them and replace with proper ball oilers as per original spec. Not expensive. RDG do imperial ones, Arc do metric ones. Generally either 1/4" or 6mm.
Speedy Builder531/10/2018 06:55:41
2878 forum posts
248 photos
DO NOT overgrase the headstock bearings. If you do, it will dramatically slow down the spindle speed especially at the higher rev range. If you do overgrease, remove the grease nipples and run lathe until excess has oozed out.
It happened to me !!
BobH
Hopper31/10/2018 07:44:10
7881 forum posts
397 photos
Posted by Speedy Builder5 on 31/10/2018 06:55:41:
BobH
^^^ True, that. Roller and ball bearings need only be half full (or even a bit less) of grease to operate correctly. There needs to be room for the grease to be pumped about inside the bearing by the rotating balls/rollers. Damage to the bearings can occur in extreme cases of over-greasing.
Bazyle31/10/2018 09:53:16
6956 forum posts
229 photos
The grease nipples for use with oil will be original. Just fill a grease gun with oil. Sure it leaks but it's a workshop not a delicatessen. Don't worry about the excess grease causing damage. Although this can happen to a car bearing or big machine your puny Boxford motor just doesn't have the strength. You will notice the reluctance to run in top gear on cold days though sad just like the owner.
Mick B131/10/2018 10:04:01
2444 forum posts
139 photos
Posted by Ady1 on 24/10/2018 10:06:50:
If you're a total newbie and working on your own then drive slip is actually a good thing
It's miles safer plus it forces you to acquire the skills of cutting successfully on low power
Once you can do good cuts on low power you can ramp things up bigtime later on
EDIT
I cursed my drive slip in the beginning but it really helped me as my ability improved, took about 12 months
to get the basics, working a few hours every couple of days
You will never get the same skills on a big powerful machine because they drive the cut right through every error you make and you never notice any minor but relevant issues
Edited By Ady1 on 24/10/2018 10:12:00
'Ang on a minute! It's not just newbies that get saved by spindles stalling under power!
I've been machining since the mid '70s, and I've still been saved more times than I can readily count in the last few years by my Warco stalling when asked to do something needing too much force.
Part of that is because I don't have a mill so I end up doing ops on the lathe that - shall we say - rather push the envelope of its capabilities... laugh
Ian S C31/10/2018 13:00:51
7468 forum posts
230 photos
Quoting from "Know your lathe" page 17. *1. Headstock Spindle Bearings. These are grease packed and require a small amount (1 cc approx) of new grease every three to six months, introduced through scew cap greasers at the front of the headstock.
There are about 30 recommended greases and oils, then Alternatively: Grease - Any good quality bearing grease as used in garages.
: Oil Any light machine oil S.A.E. 20 grade or similar.
Muzzer31/10/2018 16:53:51
2904 forum posts
448 photos
Klueber who specialise in bearing lubricants recommend 1/3 - 1/2 of the free volume but it depends on the speed too.
Useful Klueber reference here.
Murray
JP Santos02/11/2018 17:07:56
49 forum posts
9 photos
Wow! thanks gents... you guys are like encyclopedia of information!!
Been a bit too cold to venture out in the garage, but do need to get some bits done, so want to make sure everything is in tiptop condition before using the lathe more.
