Dangerous Ultrasonic Cleaner Electrical Failure
Russell Eberhardt28/07/2018 15:37:33
2785 forum posts
87 photos
Thanks for posting that Clive. I have the same model so I have just had a look inside. It doesn't have the same fault but I noticed that the aluminium foil sticker holding the thermocouple in place was coming loose and in danger of landing on the circuit board!
Russell
JohnF28/07/2018 17:18:19
1243 forum posts
202 photos
Hmm! think the moral here is buy from a known domestic supplier for electrical tools at least you would expect that supplier to ensure the appliance conforms to UK / CE standards. Very cheap if it won't kill you ??
I have to admit I was tempted by the offerings on the web but decided to buy from Machine -DRO instead because of the above rational. We had some Ultrasonic cleaners purchased probably some 12/15 years back from a German supplier, at the time they were price prohibitive in the UK and we saw these at an exhibition in Nurnberg at a very acceptable price, one failed which they fixed it without any problem and they have been in continuous use -- several days a week ever since, Recently 2 of the 3 have failed hence our replacement with new ones.
Looked inside and way beyond my understanding of things electrical, possibly not a great deal wrong but no idea how to figure what so closed the box and acquired new ones.
Reading Clive's findings I reckon it was the right decision ! What price is life worth ?
Russell Eberhardt29/07/2018 09:05:54
2785 forum posts
87 photos
Posted by JohnF on 28/07/2018 17:18:19:
At least the earth connection in these units is sound so, provided your electrical installation is sound, the plug fuse will blow if a short circuit to the case develops thus rendering it safe if inoperative.
Russell
Colin Heseltine15/03/2020 17:11:00
744 forum posts
375 photos
Reviving an old thread. My Ultrasonic cleaner has died. It powers on okay, heats up okay, appears to start on the timer and switches off again after appropriate time but I do not get the ZiZiZi noise it used to emit. No bubbles or cleaning.
I came across this thread whilst searching for repairing said item. Took the bottom of to check for problems and can see no issues. Checked all 6 fuses are okay, can see no melted or blown bits, all wires connected and good. It is model with 4 transducers.
See picture below of board.
Any ideas on what to look at, check next, or do I just scrap it and buy another.
Colin
PAOLO PISTIS17/05/2020 20:19:39
1 forum posts
Posted by Colin Heseltine on 15/03/2020 17:11:00:
I also had the same problem on my PS 30A (the version with 3 transducers) and I'm trying to solve the problem. At the moment I have found some problems in the secondary pcb
fuse F1 blown and transistor Q1 defective.
Moreover I also found damage on one of the three piezolectric transducers
However I think there may be some other problem because I tried to disconnect the secondary IPC (which only controls the damaged transducer) but it doesn't work either.
someone suggested to me to test the resistances of the piezoelectric transducers
Neil Wyatt17/05/2020 21:42:07
19226 forum posts
749 photos
86 articles
Don't scrap it...
MEW 295 will ('subject to change' have an article by Mark Noel on building the MEWSonic ultrasonic cleaning tank so you can either use most of the old one in a new build or learn enough to repair the old won with spares (Allendale sell spares and some of the parts use in MEWSonic).
Colin Heseltine17/05/2020 22:01:47
744 forum posts
375 photos
Neil,
You should have posted this yesterday. I bought a replacement several weeks ago from Machine-DRO but the local tat man came round today and I he had it along with a load of other stuff. Damn site easier than queuing at the local tip at present. Still need to go but not quite so urgent now.
Colin
J BENNETT 117/05/2020 23:16:05
55 forum posts
I bought one a few years ago and from the start had the feeling that it didn't work very well, if at all. It was quite cheap and is fairly small so just assumed it was a gimmick. So stuck it in the cupboard where it's been ever since. I will fish it out and see if I can find anything wrong.
David Sparling23/02/2022 22:22:30
1 forum posts
Reviving a dead thread!
Can anyone tell me what voltage the heating element runs at (on a PS-10A)? Mines dead but there are no specs on the element and my electronics knowledge is somewhat lacking...
not done it yet24/02/2022 10:25:48
7517 forum posts
20 photos
If you know the Wattage or Resistance, you can work out the Voltage required. You only need
Ohm’s LawV = I R
Edited By not done it yet on 24/02/2022 10:26:36
