Sam Longley 1 | 13/10/2017 14:48:13 |
965 forum posts 34 photos | Posted by not done it yet on 12/10/2017 16:40:37:
Going back to origins - are these instruments turning off ( losing power feed) or going into sleep mode or just losing a signal? Subtle differences when looking for a fault. Signal loss can be poor screening, parallel power cables with signal wires, or even heavy current on crossing wires, producing either magnetic fields or capacitive effects. The average multimeter is no good for this type of fault. Nor do you give any history - a recent fault, after running OK for some time, or a new installation not working from commissioning. All very relevant information before one even starts poking around the system. An experienced electrical engineer would be askiing lots of pertinent questions, to narrow down the random nature of the suggestions above, before even stsrting to investigate physically. - (s)he would try to sort out whether a signal tester or multimeter was relevant for the investigation. Maplin quality parts might be a good starting point for checking out! Worked Ok for the first season but then the control panel would display " autopilot stopped working" This would only take a power failure for a split second & trip the control. System then needs resetting. It is very dangerous if it turns off & i am below deck & do not realise that I have changed course. No wiring shows signs of corrosion. The autopilot is designed for a much larger yacht so I am not overloading it but it happens in rough weather after 2-3 hours & I can sometimes reset immediately & sometimes I leave it for half an hour before it starts again. Then it will fail after a much shorter hour. I am beginning to suspect a switch because since posting I noticed that one of them seems warm (does have a light in it though) after a while even though rated for 10 amps as per the instructions. Can a switch break down in use temporarily then work again later? One other problem with autopilots can be under sizing wires so I have ensured that the wires are larger than specified. |
Sam Longley 1 | 13/10/2017 14:51:51 |
965 forum posts 34 photos | Nick & Dave Thanks for the links on meters They are not expensive & I will buy both as I quite like analogue & the auto feature on the other is handy regards Sam L |
Martin Kyte | 13/10/2017 14:57:56 |
![]() 3445 forum posts 62 photos | A usefull way to aproach these problems is sometimes to eliminate what it isn't. If you rig up an alternative supply and the problem remains then the fault isn't in the supply but in the unit. "Can a switch break down in use temporarily then work again later?" All contacts can be intermittant. "rough weather after 2-3 hours & I can sometimes reset immediately & sometimes I leave it for half an hour before it starts again." it would be handy to know if it was getting power when it doesn't want to restart. (indicator lamp maybe). If it will not reset and there is power to the unit then it's the unit at fault. You just have to eliminate stuff. regards Martin |
Jeff Dayman | 13/10/2017 15:47:07 |
2356 forum posts 47 photos | If a switch is suspect, jumper it with a short cable fitted with soldered alligator clips for a while and see if the unit stays on. Or just change it out with a new switch (with precious metal contacts if possible). Running a new wire from source to unit is also a good idea. Have you disconnected or unscrewed, then re-connected or re-screwed every termination in the circuit? Have you done the same for all ground connections? This is a fundamental troubleshooting step on vehicles and boats. I've fixed a lot of problems caused just by bad grounds and poor connections (loose or oxidized, needing a re-seating). Good luck with your troubleshooting. One further thought - is it possible to power your critical nav equipment with a second dedicated battery close to the nav unit? might be more reliable to do that and charge that battery from the boat supply. Same sort of thinking as using an uninterruptible power supply for a computer. |
Clive Hartland | 13/10/2017 17:28:26 |
![]() 2929 forum posts 41 photos | This is just a thought, maybe the wiring is not compatable with the requirements of the loads applied. I would consider a complete rewire with good size cable and water proof enclosures, new switches etc.. Peace of mind as a hot part of a circuit on a boat is a danger and fire afloat is not good. Permanent connections to equipment to eliminate bad joins, plugs and sockets etc. Just a thought. Clive |
SteveW | 13/10/2017 18:55:11 |
![]() 140 forum posts 11 photos | I would second the idea of a dedicated battery for anything critical. Short leads, few connections, wiring easy to check or replace, just one switch. Fewer components = more reliable. Steve |
Sam Longley 1 | 13/10/2017 20:37:44 |
965 forum posts 34 photos | Posted by SteveW on 13/10/2017 18:55:11:
I would second the idea of a dedicated battery for anything critical. Short leads, few connections, wiring easy to check or replace, just one switch. Fewer components = more reliable. Steve I have a pair of AGM domestic batteries 800mm from the electric cupboard with a red flash starter battery. the AGM's normally sit between 12.8 & 13 V in operation & 14.4V when under charge. I do not believe that they are faulty as they are fairly new & hold the charges for weeks in the winter without topping up the charge. This is the cupboard from where the autopilot wiring starts it then goes down behind ducts & panels to the stern of the boat via a tortuous route !! 90% of the wiring is manufacturer installed-- without any wiring diagrams I might add. I have only installed the AIS, & renewed the compass, Echo sounder & log & supply to autopilot & log - that is why they kick off from junction boxes & a plotter reserve plug- top right in picture
Edited By Sam Longley 1 on 13/10/2017 20:51:07 Edited By Sam Longley 1 on 13/10/2017 20:55:09 |
George Clarihew | 13/10/2017 21:18:52 |
80 forum posts | There is enough good advice on equipment needed and what to look for. May be a bit late but using the half and half tracing method often speeds isolating the faulty half of the circuit then halfway up or back the dead part and so on in ever decreasing halves till - -- -- -- - BINGO !! Edited By George Clarihew on 13/10/2017 21:20:56 |
Mike Poole | 13/10/2017 22:45:21 |
![]() 3676 forum posts 82 photos | Sam, your photo illustrates exactly why you need to know your enemy before you embark on a fault finding process, most of that wiring will not be involved in the relevant circuit but you need to know what is. As George mentions the half split method is a sound fault finding process but it is essential to know the circuit completely or how do you pick a midpoint? and make meaningful tests. Mike |
Phil Whitley | 14/10/2017 15:03:51 |
![]() 1533 forum posts 147 photos | Posted by John Haine on 13/10/2017 09:23:46:
Posted by Phil Whitley on 12/10/2017 21:53:45:
Get yourself an old fashioned DC buzzer or doorbell. the type that uses a vibrating arm and a pair of contacts. This is so it will draw a reasonable amount of current, as if you use an electronic one, it will not draw sufficient current to make the fault occur. attach the bell/buzzer to the supply for each instrument in turn, then go through the circuit working your way back towards the batteries till you hear the bell/buzzer falter or stop. You have found the fault. be especially suspicious of fuse boards or breaker panels. I think that this might be a bit dodgy with modern electronics as bells/buzzers can create high voltage spikes as the contacts break which can get through to the terminals if the contacts arc. This could damage the equipment. An equivalent but safer alternative is to use the meter to measure volts, with a shunt resistor of say 100 ohms to draw current, then look at the volts at the power input to each device whilst wiggling wires. And as someone else said, gather as much evidence as you can of what exactly happens. My experience of fault finding is that I spend most of the time staring into empty space forming theories of what the trouble could be and experiments to test them, but little time actually measuring or testing.
I would expect the OP to have the equipment disconnected before he connected the bell/buzzer!! |
