Holding short lengths
Raymond Anderson25/09/2016 12:14:23
785 forum posts
152 photos
Andrew, how short a part do you think you could hold accurately with the B42's
Nick Hulme25/09/2016 12:19:34
750 forum posts
37 photos
Posted by John Stevenson on 24/09/2016 17:25:21:
This post is a spin off from the one posted by Raymond Anderson on ER collets.
In that post Raymond remarked about having to turn short tubs of material up to prevent the inner of the ER collet from collapsing when holding short pieces, which they do.
3-jaw chuck & soft jaws ?
John Stevenson25/09/2016 12:24:33
5068 forum posts
3 photos
Posted by Ady1 on 25/09/2016 11:57:22:
A lathe drive centre can be handy, woodworkers use them a lot.
A JCB is handy at time but also has no relevance on a thread called holding short lengths.
Ady125/09/2016 12:30:20
6137 forum posts
893 photos
It'll hold short lengths for side work John
Feeling a bit Grumpy this morning are we...
Ajohnw25/09/2016 12:32:12
3631 forum posts
160 photos
Posted by Gary Wooding on 25/09/2016 11:03:08:
I use ER32 in my mill and lathe and both chucks have an internal taper that fits precisely the external taper of the collet. I don't see how the "rear" of the collet can close more than the "front" to cause bell-mouthing. Can somebody explain please?
I already explained why the wont do that in another thread. Long, no notice taken so I just sit here laughing saying up yours. I should have added a bit more though.
There is a good reason normal spring collets usually have a grip length of around twice the dia. They will grip less but a problem occurs at some point. Say it was 10% of the dia. That is no where near enough to guarantee that the clamped part is lined up in the collet it could be at an angle. People who feel 1 dia is all that is needed should go talk to the makers, People who think that normal spring collets should be split 4 ways should do the same.
ER collets follow a lightly different grip length rule. Some spring one may too. It's circa 1 1/2 diameters. Going on that comments I have seen about 2/3 of it used should be ok. Below that there will be more risk of not aligning correctly. The ancient venerable 1 dia rule used for many relatively low precision things even guides in an odd way.
All rubbish so why is it so easy to mount bar in a 3 jaw chuck and not have it running as true as the jaws do ? If badly out it will probably work loose as soon a decent cut is put on but there are degrees where it wont do that.
crying It's all common sense really.
Edited By Ajohnw on 25/09/2016 12:33:06
Raymond Anderson25/09/2016 12:49:43
785 forum posts
152 photos
Hi Nick H, I have soft jaws, but I really would prefer a collet system. Even if it comes down to making a shed load of me own blanks I would happily do that. Am still at the mulling over / checking out the options stage. Either way I'm changing, although I'm still keeping me ER'S They won't be getting ditched In fact I will probably end up using them as much as the new system [ whatever that turns out to be ]
cheers
Gary Wooding25/09/2016 13:05:53
1074 forum posts
290 photos
Posted by Ajohnw on 25/09/2016 12:32:12:
Can you supply a link please. I still don't understand. Does hardened steel compress to any noticeable extend when used as the springy jaws of a collet?
Speedy Builder525/09/2016 13:07:32
2878 forum posts
248 photos
What is the used trying to make? Double sided coins ?
Michael Gilligan25/09/2016 13:17:17
23121 forum posts
1360 photos
Posted by Gary Wooding on 25/09/2016 13:05:53:
Gary,
Mark's pictures on this page **LINK** will do more than thousands of words, to explain what's going on.
http://www.model-engineer.co.uk/forums/postings.asp?th=120333&p=9
Raymond Anderson25/09/2016 13:17:58
785 forum posts
152 photos
Hello Speedy Builder, Now there's a thought... make a double sided coin ,comes the toss of a coin.. Heads or tails? Jesus, I could never lose smiley If only I wasn't so honest.
cheers.
MW25/09/2016 16:22:30
2052 forum posts
56 photos
I don't know why, but the rubberflex jacobs system just seems so revolutionary, i honestly can't see why this never caught on with it's combination of materials. It's like the very first "composite collet".
Just not marketed outside the US?
Michael W
Edited By Michael Walters on 25/09/2016 16:29:22
Michael Gilligan25/09/2016 16:56:08
23121 forum posts
1360 photos
Posted by Michael Walters on 25/09/2016 16:22:30:
I don't know why, but the rubberflex jacobs system just seems so revolutionary ...
Here's the manual **LINK**
http://www.tools-n-gizmos.com/info/Jacobs_Rubber_Collet_Chuck.pdf
MW25/09/2016 18:04:14
2052 forum posts
56 photos
Posted by Michael Gilligan on 25/09/2016 16:56:08:
Thanks Michael, Will make for interesting reading, i wonder how the the rubber is treated to ensure a good life, i'd imagine you'd need to take great care when using them.
Michael W
MW25/09/2016 18:08:56
2052 forum posts
56 photos
When you see even the chuck created for the collets, it's a marvelous looking thing.
Jacobs, which pretty much set the standard blueprint for the drill chuck used on alot of machines. Created this to accomodate the need for collet users, they could've done a worse job i say! But it never caught on...?
Michael W
John Stevenson25/09/2016 18:24:16
5068 forum posts
3 photos
They are horrible to use.
Sounds like sour grapes but it's not, I have two complete chuck assemblies here with collets.
To use, you have pull the inner ring out, the one with the angled teeth on then spin the big ring hard until it stops and then repeat this hammering action until the chuck becomes loose, swap the part, then repeat in a reverse order hammering the ring round by hand until it's tight then piss about pushing the locking ring in whilst rotating the outer ring until it locks in.
So what should be open, swap part, close is translated into pulling and spinning highly polished pieces of metal, usually with slippy hands if you are using coolant, many times over.
Sorry after 5 parts you loose the will to live and even a 4 jaw looks tempting.
Why they attract the price they do I'll never know. I got both my sets for different guys who also hated them and were glad to see the back of them.
I only mentioned these initially to put forward the rubber bung idea to be used on ER's but I have a sneaking suspicion that nothing will come of it because Raymond's mind is already made up no matter what's posted.
Nick Hulme25/09/2016 18:44:34
750 forum posts
37 photos
There's space in my ER collet drawers for stepped brass bungs for the back end, I use a small polyurethane insert in a hole on the OD for retention. My bungs see regular re-use and you only have to make a given size once so I don't see 2 minutes of time invested to make them as lost.
- Nick
P.S. I know it's sacrilege of the highest order but I thought I'd also mention here that I've successfully used ER40 collets on tapered work, some with 2 feet hanging out the back of the head and concentricity was good
Raymond Anderson25/09/2016 18:59:48
785 forum posts
152 photos
Hi John, You are correct about me mind being made up. Only thing is to what system? Did you ever get a chance to look at the 2 pics of the B 60 ? I am going to get a price for a set of the 16's up to 42.50 Ø and a price for the B 60's They go up in 0.5mm steps to 60.50 Ø but I will stop at 45 Ø. although I need to be sure that I can use the B60's manually. They will no doubt cost an arm and a leg ,but I don't want to have to sell a kidney aswellsmiley.
What are you're thoughts on me making bigger versions of me test ones ?
cheers
John Stevenson25/09/2016 19:16:08
5068 forum posts
3 photos
Yes I did look and when I went into work today I took some pictures of the manual B whatever they are size.
I also took some pics of how I hold short lengths and thin sections in soft jaws, a method that has been used for 200 odd years so I question why you have to reinvent the wheel but as you say your mind is made up and so I'll just be spending time that could be used far more productive to me.
So I will wish you the best of luck and perhaps one day revisit her to find out just how many angels you got onto the pin head.
Edited By John Stevenson on 25/09/2016 19:16:44
Michael Gilligan25/09/2016 19:19:23
23121 forum posts
1360 photos
Posted by Nick Hulme on 25/09/2016 18:44:34:
... some with 2 feet hanging out the back ...
devil
Mark C25/09/2016 19:19:50
707 forum posts
1 photos
Reading all the buff about the various types, I have one of my machines more or less permanently fitted with a Crawford hydraulic chuck and a set of "C" type multisize collets. They are really good and very easy to use. Tighten the chuck key locks it up solid in a big way and then undo and spin the nose closing nut off to change size. Takes no time at all and works every time. Run out is very good (have never measured it but re-fitting a job will be visually close when you start turning again - perhaps within a thou or so) but I rarely put short lengths in it. I always try to ensure there will be enough material to reach the back of the collet.
I don't have any to try but I think it will take the Jacobs Rubberflex collets? I have a Jacobs manual chuck but I never use it as I never got round to mounting it on a backing plate (my machine takes L00 fittings and the back plates are very expensive to buy)
It is also useful in that it is a "dead length" system which is very handy on a lathe at times.
Mark
