Brian's 1" Minnie Traction Engine
Roger Best21/08/2020 23:13:27
406 forum posts
56 photos
smiley Great thread - you have covered a great many issues over the years.
Fabulous work Brian!
Brian Abbott21/08/2020 23:35:14
523 forum posts
95 photos
Thank you, i didn’t think anyone followed this build,
Progress is slow admittedly, work and family take priority, but it’s getting there.
Jeff Dayman22/08/2020 00:03:36
2356 forum posts
47 photos
It's looking great Brian! I see you are starting the beading around the tender, looks like. Tricky, but looks great when done.
peter hobbs 223/08/2020 09:52:57
8 forum posts
looking good brian i have finally steamed my minnie successfully using charcoal and it steams well .the only thing now is the pump will not work against the boiler pressure,when the engine is cold it works fine.
anyone else had this problem
pete
JasonB23/08/2020 10:19:46
25215 forum posts
3105 photos
1 articles
The pump does not worrk as well when it get shot, some builders mount the pump down on the horn plate or at least space it off of the boiler.
peter hobbs 223/08/2020 11:19:28
8 forum posts
thanks jason for the info i think i will try moving it to the horn plate and also fit a back up hand pump
pete
Brian Abbott02/11/2021 20:14:19
523 forum posts
95 photos
Hello all
Just working on the Minnie water pump,
Anyone know what size hole should be through the check valve seating.
7/64 or 1/8 ?
Harry Wilkes02/11/2021 21:15:11
1613 forum posts
72 photos
Looking very nice Brian
H
Brian Abbott03/11/2021 19:09:04
523 forum posts
95 photos
Thanks Harry.
Richard S205/11/2021 14:52:06
237 forum posts
135 photos
Hi Brian, Sorry for the delay. 7/64" bore for the valve seatings for 5/32" valve balls. Are you changing the pump layout/location ?.
Neil Wyatt05/11/2021 15:21:09
19226 forum posts
749 photos
86 articles
Nice to be reminded of this build!
Brian Abbott09/04/2022 20:17:15
523 forum posts
95 photos
Good afternoon all.
Could I ask any Minnie builders what thickness gasket they used between the cylinder and the boiler?
The reason I ask is when I machined the base of the cylinder I took great care to make sure it matched the boiler, unfortunately, I forgot all about the gasket.
Really, to make things right I should re-machine the base of the cylinder to allow for a gasket,
Thanks,
Brian
Paul Lousick09/04/2022 23:29:43
2276 forum posts
801 photos
If there is no allowance for the thickness of a gasket and the surfaces are flat and mate well with each other, a coating of graphite based sealant will work. (used on the end cover on the steam cylinder of my 6" engine).
Brian Abbott24/10/2022 21:18:23
523 forum posts
95 photos
Hello all
Progress has been very slow of late but thought i’d post a quick update picture
Regulator’s done and the water pump is taking shape.
Still lots to do but the end is in sight 😀
Jeff Dayman25/10/2022 01:08:45
2356 forum posts
47 photos
The engine's looking really good Brian! keep going with the last bits. Did you use sealant under the cylinder or did you machine a bit out for a gasket?
derek blake25/10/2022 17:15:36
586 forum posts
151 photos
Looks great Brian, well done 👍
Brian Abbott26/10/2022 22:23:25
523 forum posts
95 photos
Thanks Derek,
Hello Jeff, never got that far,
Plan now is to write a list of all the half finish bits I need to do then strip the engine and sort all the gaskets so I can get it running,
Im not planning on painting it so just need to clean everything.
Be good to get it finish, I’ve really dragged my feet with this and I’m lucky I have never lost interest.
Brian Abbott06/04/2023 21:04:08
523 forum posts
95 photos
Hello everyone
I am working on the ash pan, damper and hinge arrangements.
I have made the hinge that attaches to the front of the boiler but am having trouble picturing the 2 small hinges that solder to the damper.
Would anyone have a clear picture?
Thank you
JasonB07/04/2023 06:52:24
25215 forum posts
3105 photos
1 articles
Last two in this album of mine
Brian Abbott07/04/2023 16:24:22
523 forum posts
95 photos
Thanks Jason
Did you machine those from solid or bend 1/16 plate?
