Here is a list of all the postings peak4 has made in our forums. Click on a thread name to jump to the thread.
Thread: Surface Grinder refurb |
06/10/2022 23:25:10 |
Albeit on a shorter table, so less overall area to scrape off, but mine were something like 12 thou high at one end and 14 at the other, so I ended up taking nearly 15 thou off each end and one thou in the centre. |
Thread: Clarkson T&C Grinder information |
06/10/2022 22:27:25 |
Yes, it's a screw on extension; I've made several more to quickly swap wheels without having to re-mount them on the spindle. Obviously that doesn't help if you need to use something on a short spindle projection. |
Thread: Can someone in teh uk buy these for me from amazon |
06/10/2022 19:14:52 |
Did the FFX link work; they appear to be UK landed and dispatched from Kent, as well as being cheaper. Edited By peak4 on 06/10/2022 19:15:30 |
Thread: An American with some "small" tools in England... |
06/10/2022 11:05:12 |
Posted by DC31k on 06/10/2022 09:23:09:
There is a huge amount of stuff here (contact website owner for download permission): http://bedroom-workshop.com/index.htm Have you ever tried to contact the owner with any success? |
Thread: How to test a Myford ML7 spindle? |
05/10/2022 23:31:02 |
Posted by Andrew Johnston on 05/10/2022 23:26:14:
Posted by Jon Halland on 05/10/2022 23:19:30: ...which indicate the headstock spindle/bearings has 0.007'' run out.Could be that the spindle is fine but the test bar is not seating properly in the headstock taper. Andrew Not that I'm any expert, but it would be my first point to check. |
Thread: Dore-Westbury Mk1-Milling Machine Construction Drawings |
05/10/2022 23:27:01 |
The zip file containing documentation from the old Dore Westbury Mill Yahoo group has now been sent off to those who've asked for it. Bill |
05/10/2022 21:56:37 |
Just sent you a PM And replied, but unfortunately failed as it doesn't like my address either. Bill Edited By peak4 on 05/10/2022 22:06:09 |
Thread: Number drills? |
05/10/2022 20:23:40 |
Posted by Brian G on 05/10/2022 16:06:25:
Proops offer a number drill gauge with thou equivalents on their own site or via Amazon for £2.40 delivered. ................... Brian G On the other hand, do a search for drill gauge on etsy and it will immediately take you close to the Proops shop on Edited By peak4 on 05/10/2022 20:29:59 |
Thread: Irritated by ebay |
05/10/2022 12:22:10 |
That's an odd one; I wonder if it's some sort of a glitch in the software, with the item coming direct from China. |
Thread: Expanding mandrels. |
04/10/2022 23:43:07 |
Tobler do them, but I suspect the price might be rather higher. So do RC-Machines, but only morse taper arbors, rather than the ARC Eurotrade parallel ones Edited By peak4 on 04/10/2022 23:46:57 |
Thread: Weller TCP soldering iron |
04/10/2022 00:02:42 |
Other info available from Weller's own website, about the W61 as well as the type I use, which is where I found the issue with mine. |
03/10/2022 18:22:53 |
Well after I'm not sure how many years, I think I've sussed it with my iron. The one fitted was non-magnetic, and intended for a non-Magnastat soldering station. |
03/10/2022 17:18:21 |
Tony, Thanks, I'll not hi-jack Steve's thread any further. |
03/10/2022 12:42:29 |
Posted by Tony Ray on 03/10/2022 00:39:48:
I think your scraping is improving, it looks a more consistent on your last image. I hope I didn’t send you down that power scraper rabbit hole; I have been working on mine on and off for months, it’s Makita based as I can get parts for it relatively cheaply. The main issue is balance as the scraping gubbins is heavier that the saw blade & clamp. I have increased the counter weight but need to do more testing. It can produce a nice even pattern so I think it will at least do for initial roughing. There is an alternative design on the Tube base on what looks like a windscreen wiper motor, the design is good but it’s more of a scratch build but I am tempted. .................... Edited By Tony Ray on 03/10/2022 00:42:55 That's interesting, I picked up a Makita one myself, specially for that attempt at a conversion, but haven't started yet, as I was struggling to come up with an easy way to vary the stroke length due to the internal design. |
Thread: DIGITAL CALLIPERS @ LIDL |
02/10/2022 22:29:44 |
Posted by Ady1 on 02/10/2022 18:59:36:
I got one but my battered original is still going strong I got the angle thingy as well Store the angle gauge with the battery out; it drains quite quickly, but other than that, a very handy gizmo. |
02/10/2022 11:30:57 |
Posted by Michael Gilligan on 02/10/2022 09:03:57:
Bill There is a concise description of its action on the page that I linked much earlier in this thread: *................... Edited By Michael Gilligan on 02/10/2022 09:08:29 Thanks, I missed that. |
02/10/2022 00:21:36 |
Posted by Robert Atkinson 2 on 01/10/2022 19:59:02:
John, Robert G8RPI. Is the switch part of the heater element, and thus voltage dependent? Mine has the opposite problem and never heats up unless you shake it for a while, and then only stays hot for a short time. It works when you first power it up, and then cools off immediately. |
01/10/2022 14:13:01 |
If anyone is struggling for info. PM me your real email address and I'll attempt to send a large zip file via one of the free file transfer websites. |
Thread: THE MIDLAND - THE ONLY SHOW IN TOWN ! |
01/10/2022 13:43:32 |
Posted by DC31k on 01/10/2022 13:28:19:
A long time ago John Stevenson wrote about mapping the Brierley cam profiles and publishing them somewhere. Do you know if this ever happened or if the information is available form an alternative source? Thanks. Is this the thread you were remembering? |
Thread: National Trust : free tickets |
01/10/2022 01:10:48 |
Many thanks Michael, just bought one for a bargain price
