Member postings for Ady1
Here is a list of all the postings Ady1 has made in our forums. Click on a thread name to jump to the thread.
Thread: How to tune clock bells
21/02/2012 03:19:36
If the "chiming bells" aren't seen by the viewer perhaps tuning forks would suffice, those metal prong type thingys which emit tinging sounds
2cents
Thread: NEW MAGAZINE FOR MODEL ENGINEERS
19/02/2012 07:06:08
Reminds me of various magazine start ups in the 1960s and 1970s.
Many only ran for a few issues, now highly sought after by collectors because of their rarity.
A new mag startup was never an easy option for anyone, will be interesting to see if this new kid on the block can survive.
Thread: Lathe Refurbishment
18/02/2012 23:10:38
Was semi-scrap when I found her
One dial came up nicely, the other dial was too worn to see after decades of use
I only ever used a soft scrubber, otherwise you will lose any detail remaining on the original lathe.
A wire brush is a definite no-no IMO
edit
lol. I think our new editor is going to have issues with newly uploaded pictures, (it defaults to 1024x768)
Edited By Ady1 on 18/02/2012 23:14:42
18/02/2012 22:49:47
I got a nice finish on some of my old pultra gear by dunking it in a bucket/tray of malt vinegar and scrubbing with a soft metal dishwashing scouring pad every couple of days (not a wire brush though! Too rough!)
Don't forget about it though, or it will eventually get eaten by the mild acidic action of the vinegar
Some stuff was great in a couple of days, other bits took up to 10 days.
Depends on the level of corrosion etc.
Edited By Ady1 on 18/02/2012 22:55:37
Thread: Myford S7 Bronze backgear
18/02/2012 12:51:25
Get the backgear sorted.
Backgear turns a bog standard lathe into a proper machine tool which a VFD couldn't hope to compete with
Thread: New website editor
16/02/2012 20:41:57
Rule 1 for engineering at sea
"if it aint broke don't fix it"
We called people who tried to fix things that alreaky worked "tweekers"
Edited By Ady1 on 16/02/2012 20:43:00
16/02/2012 01:43:22
Just do a google site search
Edited By Ady1 on 16/02/2012 01:45:03
Thread: Opus die filer
16/02/2012 00:40:29
Filing machines are getting like shapers, there actually are probably even fewer of them than shapers.
You have to hunt about for places like this and this and this
Take a few weeks and search, refine your search terms, and you will be rewarded.
I got a ton of shaper stuff off the netty, WW2 stuff, huge manuals, and still relevant for a new user.
Thread: How to check for parallel?
16/02/2012 00:20:52
parallelism? Three words IMO
buy
a
shaper
Thread: Automatically 'closing threads' idea
13/02/2012 20:43:48
Once a thread gets locked it's gone forever, different follow up threads with different titles then add to the disjointed nature of a subject.
In here the stirling engine thread is a good example.
422 posts and counting...
Edited By Ady1 on 13/02/2012 20:44:59
Thread: What cutting tools for mini - lathe (HSS or Carbide Tipped ?)
13/02/2012 20:36:49
In reply to the post above, all you need is reasonable stiffness and you can take advantage of carbide.
A seventy year old 3.5inch Myford Mseries can munch down a concrete reinforcing bar with carbide, this would destroy a HSS tool.
Carbide is just another tool you have to learn to use, it's not some mystery voodoo material.
Once you suss it out it's great.
13/02/2012 20:17:48
I forgot to say.
You can also remove the rough stone on a bench grinder and replace it with a green grit one, so now you can grind both hss and carbide tooling.
Once you get into the habit you only need to tidy up your tooltips
13/02/2012 14:43:53
Try to get both, because sometimes hss won't cut the mustard and a carbide tool saves the day. In other circumstances hss is far more convenient.
It's kinda like having a ratchet set and a spanner set
You can usually do without one or the other but sometimes one is a vastly superior tool for a certain task and you will never regret buying both.
On cast iron, and with the backgear engaged, carbide is superb, and with the tool at the back like a parting tool you can create a neat mound of iron swarf at the back of the lathe bed which is hoovered up in seconds.
Doing cast iron at higher speeds is seriously messy...
...and so on...after a few months get the bigger picture
Thread: Clarke cl300 excessive play in cross slide - is it adjustable
11/02/2012 20:37:33
It should always be less than a single turn shouldn't it?
Next project...priority 1...make a new cross slide nut...
Thread: What lathe to get?
11/02/2012 20:06:17
I'd stick with the old school stuff
Got a drummond/Myford M series but those boxfords and colchesters look the biz
Imperial/metric is irrelevant, DRO eliminates these issues, DRO also eliminates backlash issues.
All the old names...now long gone...God bless 'em...would have used DRO IMHO
The old stuff was built to do amateur AND professional work.
Thread: wind up torch
11/02/2012 10:48:17
Uploading piccies
Thread: Imperial/Metric?
10/02/2012 23:54:17
No one who ever gets DRO ever regrets buying it.
A vernier on your lathe cross slide for a tenner eliminates backlash issues and has excellent repeatability...DRO is a no-brainer IMO
Thread: Metal work at schools
10/02/2012 12:14:10
Anyone who works with the public gets checked now.
Taxi drivers Scout Leaders etc etc
The fines etc for breaking the rules can be pretty hefty
Apparently Queen Elizabeth broke the rules by visiting two different schools within a single month while not being CRB certified
To date she remains at large and has not been arrested and bundled into a police car
Thread: Myford ML7 Turning Between Centers
09/02/2012 15:07:35
There are also "built in" errors.
There was a recent post about flatness when facing a workpiece.
When you face a workpiece a properly made lathe will create a slightly concave facing, something about the headstock alignment with the lathe bed having a slight tweak.
Because a lathe has so many different things it can do I suppose that there will always be a wee bit of compromise.
Edited By Ady1 on 09/02/2012 15:10:15
09/02/2012 15:00:54
Health and safety and child protection stuff and being sued if junior gets hurt means we are de-skilling our youngsters
Our children are going to be the safest best educated zero-practical-skills people in human history
If you want to teach kids useful stuff nowadays you must do it yourself.
Don't rely on those government bods, they're all idiots with weird agendas
