Here is a list of all the postings Bazyle has made in our forums. Click on a thread name to jump to the thread.
Thread: meths feed tube? |
24/04/2023 12:34:26 |
Setting the scene: Issues: Wicks - assuming the problem is a dry sump not just flow up the wick. The wick needs to be quite loose almost falling out not stuffed in as hard as possible as more wick does not equal more flame. Join the gauge 1 forum on Groups.io as there was a discussion last year on wicks and Aster steaming. |
Thread: Major flaw in the world of engineering |
23/04/2023 23:26:47 |
Posted by paul mcquaid on 23/04/2023 10:10:14:
It's just a shame that not everybody knows the things that make engineers roll their eyes up at eh? Not just engineers. Everybody and every thing when we were just apes. Then mankind learned to talk which not only enabled us to transfer each bit of discovered knowledge but revolutionises the way we think by enabling us to create our internal monologue. The transfer of knowledge took a leap forward when we invented BOOKS and actually read them, a skill that seems to have been lost recently. (There was an interesting program on the BBC a couple of years ago that explained that people born deaf and dumb who are not taught sign language have difficulty in progressing mentally beyond a 5yr old because without speech they cannot develop an internal monologue, which develops in children only when they learn to speak) |
Thread: Asset Security Marking |
23/04/2023 21:46:52 |
Posted by Bo'sun on 23/04/2023 18:40:26:
How did the Police know to contact you? Postcodes normally cover multiple properties. p Because you reported the theft to the police so when the item is found in a location that does not match they look it up and find the string of burglaries reported for your area with lists of items. The half ton lathe gone from the area is probably unique to you. |
Thread: Randa b nose thread |
23/04/2023 21:37:18 |
It isn't the thread that defines the fit but the register - the plain parallel bit just behind the thread. And a tap will never be true enough for this job. What you can do is measure it all and practice making a few small threaded bushes in aluminium as it is easy to cut. Make sure the fit is not so tight it can shrink on if you put it on warm. |
Thread: Road bridge weight limits. |
23/04/2023 16:05:41 |
Nowadays you can bet several risk assessments have been made, two committees have discussed it several times and commissioned an in depth report from someone's brother-in-law and the drivers have been on a special 'Safe Bridge Crossing' course. |
Thread: Improved Experimental Pendulum |
23/04/2023 15:57:14 |
You said the external magnet operation was too violent etc. How about making a sort of gravity arm that can nudge the pendulum but is lifted by the manual use of the external magnet, applied out of range of the bob. I notice your impulse is driven by a simple on/off line. Does the sudden application of the force cause the ringing you saw in your FFt. It is rather like being hit by a hammer rather than a gentle perhaps sinusoidal ramp up and down. |
23/04/2023 12:32:04 |
If the only forces on the pendulum were gravity and the force from your electromagnet it must start moving, even if it takes weeks to be visible. However you also have vibrations etc which should average out but then you have the force from the suspension spring. Can the non-movement be used to calculate anything useful about the force from this spring? If you had an induction coil near the metal of the bob (at rest) I assume it would produce an output relating to ambient interference eg from you walking past with a bunch of magnetised keys but also from tiny movements due to vibrations etc. Would this tell you anything useful, particularly would it show peaks relating to its period and other modes? |
Thread: Hand tools - 5” Kingscale Jinty |
23/04/2023 12:14:06 |
Have you found your local Model Engineering club? You are going to need to to have a track to run it unless you build your own and they will be able to help you out, including probably having some members with bits to give/sell you. |
Thread: What did you do today? 2023 |
23/04/2023 00:09:39 |
A little 2 1/2 in vice appeared in the Men's Shed today with an odd mounting which I immediately recognised and could have cried to see such ill-treatment. |
Thread: JCB Digger from PVC |
21/04/2023 20:54:41 |
Funny this should come up. I used some gutter PVC for electrical brackets on the club 08 loco a couple of weeks ago. Flattened with an electric paint stripper. Available at low cost in several colours and thicknesses, mostly black, from a skip near you. |
Thread: Lathe cutting tool height |
20/04/2023 13:53:28 |
I don't recall the over-height being so much because of the affect on tool angles but the reason is to provide a component of force outwards or back onto the feedscrew/nut which takes up backlash, reduces chatter and hopefully snatch or dig-in. The book is aimed at beginners, trainees etc using old worn lathes so relevant and helpful. Not necessary for a big engineering lathe with backlash adjustment and solid structure. |
20/04/2023 12:39:13 |
Solder paste is not a good option as it contains too much 'other stuff'. Since all mating surfaces should be jolly flat tin them and while hot wipe off the solder (dampish cotton cloth). Then hold bits in alignment with a jig / clamp and heat the whole lot up making sure the clamp pushes the joint together firmly. |
Thread: Help Req'd with old issue |
19/04/2023 14:06:07 |
Not quite on topic but I was looking for some issues of ME last week. My collection gets mixed up from time to time making it difficult to find a particular issue. It really emphasises how BAD the front cover designers are. Like the latest issue has the data in tiny print not at the top, but an inch down so in a pile one would have to rummage to see it. MEW latest issue has the number in the top left corner, sensibly large test so can be read without glasses. Clear white text. Only missing a date. |
Thread: Infrastructure Engineering |
19/04/2023 09:40:38 |
Is there a phone app, without being full of spyware, that tracks you movement over a year to give you a profile of usage that then helps you select the most suitable battery size / range? Then we need a car designed for different sizes of battery to match this, with a system of either hiring a different car for occasional long journeys or a battery trailer that you exchange halfway down the motorway. BTW one third of urban households don't own a car, and one third own >2. |
Thread: Cutting teeth in handsaws |
18/04/2023 13:45:52 |
I would make a guide to hold the file in a stable configuration then use some other item like an existing saw or screw thread to index the teeth. The one thing that is recognised as a bad idea, although used extensively in re-sharpening systems like tool and cutter grinders, is to index off a preceding tooth. I remember my final year practical exam (metallurgy & material science) included a junior hacksaw blade and the question 'how is is made'. |
18/04/2023 12:09:45 |
Would it be simpler to mount the containment tube in its own container which is temperature controlled to a tenth of a degree? |
17/04/2023 22:33:18 |
As with recent 'bench design' threads and previous lathe bed ones would the support frame benefit from diagonal bracing and perhaps being based on a great big lump of granite? |
Thread: Easy angle positioning in your vice |
17/04/2023 14:20:48 |
Not quite the same but there is an old system of making a sub-plate where you make a flat on eg a 4in round bar and screw one end of a flat plate to it. Then hold the round bit in the vice at the required angle, preferably with packing under the far end for which certain styles of vice are better than others. Attach workpiece to sub-plate. Not for very heavy cuts. |
Thread: Getting started with 3d printers |
17/04/2023 11:06:23 |
In late 2019 there was a thread on this forum about the Ender 3. It pretty much became the recommended starter point in low cost value for money even if you swap it out later for bigger/fancier/fine-resloultion/faster whizzbangs. They do keep updating it with 'pro', '+' etc names to boost the price. but the original is ok. People are printing wagons from n-gauge to 5in gauge, yes that big is possible. |
Thread: CAD for beginners |
17/04/2023 10:48:14 |
I recommend you at least start by looking at SillyoldDuffer's (SOD) tutorial he linked above as it is free and a gentle introduction. |
