To have a bearing surface for easy djustment
Chris Mate | 16/04/2023 23:04:58 |
325 forum posts 52 photos | I have not seen this, not sure if this method is used: |
DiogenesII | 17/04/2023 07:59:59 |
859 forum posts 268 photos | Sounds useful, maybe use a vice stop to help stop it sliding sideways.. ..or some little n/d magnets to hold it place against the fixed jaw..? Thanks for the idea, I will be investigating further.. |
John Doe 2 | 17/04/2023 13:24:35 |
![]() 441 forum posts 29 photos | Sorry, I think I can visualise it - but any chance of a quick sketch or a photo? Edited By John Doe 2 on 17/04/2023 13:25:10 |
John Haine | 17/04/2023 13:25:24 |
5563 forum posts 322 photos | Or photos? |
Bazyle | 17/04/2023 14:20:48 |
![]() 6956 forum posts 229 photos | Not quite the same but there is an old system of making a sub-plate where you make a flat on eg a 4in round bar and screw one end of a flat plate to it. Then hold the round bit in the vice at the required angle, preferably with packing under the far end for which certain styles of vice are better than others. Attach workpiece to sub-plate. Not for very heavy cuts. |
Chris Mate | 17/04/2023 16:55:24 |
325 forum posts 52 photos | I have taken photos, many power failures will post it as I can. |
old mart | 17/04/2023 21:24:12 |
4655 forum posts 304 photos | Looking forward to seeing the photos. I couldn't resist this little 3" vise as soon as I saw it on ebay, currently in use making special indexable boring bars for the mill boring head. It has two rotational axes, one each side of the tilt which is just right for making small pockets for inserts with sides angled to fit them exactly. Only accurate to about 1/2 degree in any of the three movements, but good enough for my purposes.
Edited By old mart on 17/04/2023 21:25:03 |
Chris Mate | 18/04/2023 16:07:14 |
325 forum posts 52 photos | Adding photos....If you want to achive high precission, it will take more effort, but for me this is mostly good enough. I added fixed blocks I made for comparison. In this case it does not influnce your clamping itself, using lowest point in vice not angled itself.
Edited By Chris Mate on 18/04/2023 16:10:16 |
Tony Pratt 1 | 18/04/2023 16:48:26 |
2319 forum posts 13 photos | Sorry I can't see any advantage to the 'lightly clamp part in vice and tap to suit method' that I use, just my opinion. Tony |
Martin Connelly | 18/04/2023 18:41:32 |
![]() 2549 forum posts 235 photos | I do not have the gap in the base of either of my milling vices, so no good for me. Martin C |
old mart | 18/04/2023 19:26:43 |
4655 forum posts 304 photos | I do like the handles, the thickness of the paint might be troublesome. Being able to support the workpiece as the vise is tightened up is a good idea. Iuse one of those digital inclinometers and find it very useful. Its resolution is 1/20 degree which is not bad for a cheap item from Lidl. Edited By old mart on 18/04/2023 19:28:57 |
Chris Mate | 18/04/2023 23:25:59 |
325 forum posts 52 photos | Posted by old mart on 18/04/2023 19:26:43:
I do like the handles, the thickness of the paint might be troublesome. Being able to support the workpiece as the vise is tightened up is a good idea. Iuse one of those digital inclinometers and find it very useful. Its resolution is 1/20 degree which is not bad for a cheap item from Lidl. Edited By old mart on 18/04/2023 19:28:57 The paint is removed from surfaces that matters, yes about the thickness when you need real thin. |
John Haine | 19/04/2023 06:57:58 |
5563 forum posts 322 photos | Just have a flat plate with a captive pin that projects both sides. Rest the pin on the tops of the vice jaws to support the plate while you tighten the chuck. |
John Haine | 19/04/2023 08:11:35 |
5563 forum posts 322 photos | Hmm, maybe that needs more thought... |
John Doe 2 | 19/04/2023 12:14:35 |
![]() 441 forum posts 29 photos | Posted by Tony Pratt 1 on 18/04/2023 16:48:26:
Sorry I can't see any advantage to the 'lightly clamp part in vice and tap to suit method' that I use, just my opinion. Tony Well presumably the half round piece stops the piece being drilled from being pushed down under the force of a drill or mill bit? |
