Member postings for Tim Chambers
Here is a list of all the postings Tim Chambers has made in our forums. Click on a thread name to jump to the thread.
Thread: My first attempt at a crankcase
08/06/2016 12:18:31
I'm having a go at making a small two stroke glow plug engine, what could possibly go wrong!?laugh
Edited By Tim Chambers on 08/06/2016 12:22:41
Thread: What Did You Do Today (2016)
05/06/2016 07:42:26
Posted by Neil Wyatt on 04/06/2016 19:12:32:
Had to evict a workshop visitor... yep, at least 1 1/2" long!
Found one of those in my bed last night!
Thread: Mercury Transit
11/05/2016 22:44:40
I was hoping to have a look but the weather was socked in all day.frown
Thread: Flying Scotsman's schedule to be kept secret
10/05/2016 17:14:07
You mean like this:
Thread: Has anybody built the flame eater "Nick"?
23/03/2016 16:36:22
"As piston/ cylinder fit are absolutely critical with vacuum / flame lickers."
Well that must make me an absolutely jammy sod then, because my scratch built flame licker runs like a treat and I cannot say that it is built with any great precision.
Thread: Sterling Engined Submarine
02/03/2016 11:03:52
"And then there's fuel cells...fuel and o2 in...co2and water out...plus a little electric. .wonder why no one though of that? ..."
Thread: Honda C90
27/02/2016 11:19:01
This might be why they are at a premium nowadays.
Thread: Fish out of water
12/01/2016 20:31:21
You'll fit in well here.
Thread: What did you do today (2015)
14/11/2015 00:47:23
Quite a few out there.
Thread: Beginner I/C engine
17/09/2015 14:11:46
How about this one?
Should be do-able on a Taig along with plenty of "armstrong" millingwink. On my Taig the biggest problem I had was holding anything firmly enough in the three jaw chuck, the ali soft jaws did'nt grip tightly enough and workpieces were always shifting out of true. Get a four jaw. The Sherline lathe use's the same spindle nose thread if you want a better chuck, but then you think "Shall I spend money on the Taig or would it be better put towards a bigger machine."
I made this on a Taig.
Thread: HELP warco 250vf spindle stalling
10/09/2015 19:06:24
Just a thought, Any grease or oil on the drive belt?
I found that the chain lube I was using on the backgears was getting sprayed on to the belt causing it to slip under load.
Thread: The Interesting Video Thread
05/09/2015 16:39:54
Trouble is, there was rather a lot of grey hair in that filmfrown.
05/09/2015 09:02:17
Barry cant arf weld
22/08/2015 08:30:44
May be a little balance to the media hysteria.
19/08/2015 20:09:07
Beesleyboy has an interesting channel.
11/08/2015 23:59:44
I got my engine back together after painting and making a stand for it.
Thread: Simple burners for steam boilers
05/08/2015 22:44:32
This is a little burner I made recently.
The jet was drilled with a .3mm drill but it could do with being a bit smaller. This is one approach I might try.
04/08/2015 23:02:21
A buzzard is a Big bird that looks more like a kestral to me.
Thread: Model and engineering videos on youtube
31/07/2015 08:08:26
I'm suprised no one has mentioned Clickspring.
Thread: Amadeal screw cutting thingy
20/07/2015 14:14:37
20150720_135015.jpg20150720_134900.jpg2015-07-20 13.47.44.jpgThere should be a M6 threaded hole on the right side of the carriage to take a M6 by 25 bolt.
Edited By Tim Chambers on 20/07/2015 14:15:55
Edited By Tim Chambers on 20/07/2015 14:19:14
Edited By Tim Chambers on 20/07/2015 14:21:20
Edited By Tim Chambers on 20/07/2015 14:37:20
