Here is a list of all the postings Massimo Dalmonte has made in our forums. Click on a thread name to jump to the thread.
Thread: Acceptable runout on drill chuck |
22/03/2022 11:15:01 |
Rohm Supra chucks come in several "flavours" (L, S,...) with different concentricities: Top of Rohm line is the Spiro series (0,05 mm): while Albrecht is given for 0.04 mm. Massimo
Thread: Eclipse 934 magnetic V block |
15/03/2022 08:38:01 |
Hi Mark, nice step by step report, I think this is the best solution for me too; I initially thought I would have used 3 taller cylindrical magnets, but your approach has "more magnet" and is to be preferred. |
Thread: Scribing with verniers |
29/12/2021 09:01:30 |
Hi, I bought one of these a few years ago, was very cheap then, about 10 euros, complete with sheath and spare scriber: it has a couple of advantages versus modified regular verniers, the roller and adjustable scriber "height". Massimo |
12/12/2021 22:34:06 |
Hi Bill, yes, this would be the logical approach, but I live in Italy and the round trip must be costly, it's a rather heavy item (and probably I would have to pay the customs too on the return leg), that's why I hoped about a local solution. I'll try to enquire with Eclipse anyway, to get an idea, thanks. Massimo |
11/12/2021 15:41:01 |
An update: I went to an old school car electrician, a gent in his eighties, who owned an antique remagnetizing contraption and treated my block with it for a few minutes. A nice guy, did it for free, but alas I didn't notice improvements; didn't have the courage to tell him... On the other hand, I read on the net: "don't bother to buy any of the small homemade magnet chargers - they will not saturate an AlNiCo magnet." (as I suspected).
08/12/2021 11:26:28 |
Mark, I think we have the same: the magnet in the "on" position: looking with a gadget which should give an idea of the magnetic field lines, we see that these do not look very "healthy": for a comparison, this is a stack of magnet as found in hard disks the idea of the neodimium magnets stack is good, but I'm afraid that if there is not a complete path of high magnetic permeability material, with the minimum of air gap, but some brass or aluminum, the magnetic effect could be strongly reduced ( anyway I could be wrong Dave, magnets are almost black magic for me Massimo
Thread: Silver solder resist |
07/12/2021 10:13:13 |
A "paint" made with jeweller's rouge and water, applied with a brush, works too. Best regards, Massimo |
04/12/2021 15:57:02 |
Good afternoon everybody, I recently bought an old V block, the magnet was stuck and I managed to have it move again by soaking it in ATF fluid and then hitting the magnet with a wooden dowel alternatively from both sides. Doing this, the major part of it was always in its cavity, protruding about 1.5 cm over the total of 10. I don't know if this was enough to loose magnetism, anyway now it works, but, once set on the milling machine table, I can move it rather easily with my hand. Is it possible to restore the original magnetism and could you tell me which kind of firm I should turn to? Thanks, Massimo |
Thread: Watchmaker's lathe belting advice |
07/06/2021 22:46:33 |
Yes, I see that the smaller UPT motor pulley seems rather bigger than the one on my lathe ( 1-3/4" against 23 mm), giving an advantage in the resultant grip. Apart using a slightly bigger diameter belt, another improvement could be using a leather one, previously soaked in neatsfoot oil, which was the best material available, according to Tubal Cain, if I correctly remember . |
Thread: What is the weight of a Myford ML10? |
05/06/2021 09:37:04 |
To further reduce the weight, you can remove the headstock too (that' s what I did last time I moved it, though, as said, it is very manageable anyway). On reinstalling it, the headstock locates again as precisely as before, thanks to the vee bedways. Massimo |
05/06/2021 07:47:40 |
Thanks everybody for the replies; I'll follow your advice, belt dressing spray and smooth round belt are on the way and I'll check the pulley profile (which looks homemade) again. |
02/06/2021 14:18:22 |
Good afternoon everybody, Edited By Massimo Dalmonte on 02/06/2021 14:18:56 Edited By Massimo Dalmonte on 02/06/2021 14:19:36 |
Thread: SEASONING OF CAST IRON |
27/04/2020 11:35:04 |
I remember reading somewhere that, in a factory, big castings were stress relieved by suspending them and having apprentices hit them with hammers (surely the hammers were small and used in way not to chip the castings); it's on a larger scale what is recommended when stick welding cast iron to avoid cracking the weld. |
Thread: Machine specs aluminum plates |
10/12/2019 14:59:17 |
Thanks everybody, Massimo |
10/12/2019 11:40:51 |
Good afternoon , Massimo Edited By Massimo Dalmonte on 10/12/2019 11:41:42 |
Thread: Bench block for small parts - ice hockey puck |
16/09/2019 08:54:06 |
Hi Robert G8RPI, soon after reading your post, I bought 6 (4 of them will be used to make levelling feet for my milling machine) Cheers, Massimo
Thread: tallow sticks |
06/06/2019 16:31:47 |
If you happen to be traveling in northern France or Belgium, look for "Blanc de boeuf" (it is used to fry Pommes frites), inexpensive (3.99 Eur \1 kg). Massimo Edited By Massimo Dalmonte on 06/06/2019 16:41:43 |
Thread: Electronic Indexers - How Is Cumulative Error Avoided? |
31/05/2019 07:31:45 |
Ten years ago, though I didn't have a specific need, I liked very much the idea of the J.A.Radford headstock indexing attachment and thought of putting a stepper motor on its worm shaft to spin it. The stepper would be driven using an old laptop via the parallel port () and I made a small Visual Basic program, using a DLL (IOPort.dll, I think to recall) to output the signals ( these had to be "strengthened" in some way before sending them to the motor, naturally).
Here is an example of how it worked: the three input data are: - motor steps per revolution: 200 - bullwheel teeth: 65 (I own an ML10) - holes to be drilled\teeth to be cut (9 in this case) Dividing 13000 steps by 9, gives 1444.4 period, so each position will be 1444 steps apart from the previous one, and we will have to spread 4 "orphan" steps on the whole revolution (this is done 3 times, on holes\teeth 3,5 and 7, the 4th step is not added, though now I see that it could be added to the first or the last step...). Hitting the button started the sequence, the 8 outputs to the Data pins of the port were monitored in the Out frame, the DLL provided a choice of the kind of sequence used to drive the motor and it was possible to change the interval between one sequence and the next, to adapt it to the stepper. As with a lot of my projects, I didn't proceed further with the hardware part, due to lack of time, but who knows... (today I think the motor command part is even simpler) Massimo
Edited By Massimo Dalmonte on 31/05/2019 07:35:33 |
Thread: Ferric chloride |
09/04/2019 17:45:44 |
Hi, as others do, I etch pcb boards putting them vertically in a tall and narrow Tupperware container, along with an aquarium heather and a small flexible PVC tube (drilled with a few 1mm holes) coming from an aquarium pump on the bottom, works well. Massimo Edited By Massimo Dalmonte on 09/04/2019 17:49:58 |
Thread: Parting off - front or rear |
06/04/2019 19:07:45 |
Good evening, the name is something like "MGEHR1010-2 Grooving Turning Tool Holder" (there are several sellers, I chose the cheapest one with 10 inserts, around 7 GBP including shipping costs): I set the tool in the front toolpost right with a try square and proceeded in lowest backgear (48 rpm) as the cdiameter was 86mm: the operation completed perfectly, with the proverbial "sizzling bacon" sound, and in the end I could remove the cast iron ring. Admittedly Myford cast iron seems a nice material to machine, but I never had the impression to reach the limits of safe operation and the 2mm insert finished in as good as new conditions, though, when the ring was almost severed, the cut was interrupted each time it met the spokes of the handwheel. Cheers, Massimo |
