Massimo Dalmonte | 02/06/2021 14:18:22 |
33 forum posts 18 photos | Good afternoon everybody, Edited By Massimo Dalmonte on 02/06/2021 14:18:56 Edited By Massimo Dalmonte on 02/06/2021 14:19:36 |
Chris Gunn | 02/06/2021 15:13:45 |
459 forum posts 28 photos | Massimo, you can get special spray on sticky BELT DRESSING, plenty on offer, and they say suitable for any belts, so maybe worth a try? Chris Gunn |
Ian Parkin | 02/06/2021 15:54:09 |
![]() 1174 forum posts 303 photos | Massimo how much tension are you putting on the belt and what diameter is the material? i use a lot of 4,5,6mm habiset material on printing finishing equipment and the pulleys are as you describe with no signs of slipping. On a belt set you measure it loosely on the pulleys and then remove 5% then weld up |
bernard towers | 02/06/2021 23:09:04 |
1221 forum posts 161 photos | Is it possible that your belt is too small a dia and only driving on the inside, if you get a belt a tight fit it will be driving on a larger surface area. Just a thought. I use them on UPT and t&c grinder with no problems. |
Massimo Dalmonte | 05/06/2021 07:47:40 |
33 forum posts 18 photos | Thanks everybody for the replies; I'll follow your advice, belt dressing spray and smooth round belt are on the way and I'll check the pulley profile (which looks homemade) again. |
duncan webster | 05/06/2021 21:56:08 |
5307 forum posts 83 photos | Posted by Massimo Dalmonte on 05/06/2021 07:47:40:
..... try striking a match on jelly. I'll take the dog out! |
HOWARDT | 06/06/2021 08:44:34 |
1081 forum posts 39 photos | Probably not possible but increasing the diameter of the drive and driven pulleys can increase the available grip. |
John Reese | 06/06/2021 22:53:34 |
![]() 1071 forum posts | Bernard Towers has the right idea. Increase the diameter of the belting so it rides on the sides of the V and does not touch the radius at the bottom of the groove. That will give plenty off traction. |
Massimo Dalmonte | 07/06/2021 22:46:33 |
33 forum posts 18 photos | Yes, I see that the smaller UPT motor pulley seems rather bigger than the one on my lathe ( 1-3/4" against 23 mm), giving an advantage in the resultant grip. Apart using a slightly bigger diameter belt, another improvement could be using a leather one, previously soaked in neatsfoot oil, which was the best material available, according to Tubal Cain, if I correctly remember . |
