Here is a list of all the postings Brian G has made in our forums. Click on a thread name to jump to the thread.
Thread: Steam locomotive more technologically advanced than modern airliners for its time? |
14/02/2018 17:17:05 |
I'm not sure I would call an A1 Pacific "advanced" when it was little different from a locomotive built 100 years before. Larger size, different valve gear, higher pressures, piston valves, injectors and mechanical lubrication were all incremental changes to a basic design that went at least as far back as the Planets, if not Rocket itself. The gas turbine, like the steam turbine before it, was a complete technological leap in performance, materials and manufacture away from the reciprocating engines that it replaced. As far as "for its time" goes, the interval between the Pen-y-Darren locomotive and the GWR Iron Duke class is similar to that between the Wright Flyer and the DC-3. Brian Edited By Brian G on 14/02/2018 17:23:52 |
Thread: Australia is not a country??? |
12/02/2018 08:50:38 |
Posted by Bandersnatch on 12/02/2018 00:58:54:
Posted by Danny M2Z on 12/02/2018 00:16:47:
It's just as bad when I sometime hear Britain referred to as a country, usually by people from the U.S of A.
OTOH I imagine that Americans feel equally as bad when they see such statements as (appearing in these forums): "We have x inches to a foot, which is OK if you are familiar with inches and feet. But such folk are dying out, and only ever existed in the Empire" No harm, no foul? Not to mention how Mexicans, Canadians, Argentinians, Chileans and many others feel about being lumped in with citizens of the USA. As far as "in the Empire" is concerned, it depends on the Empire in question. Portugal adopted the metric system before the founding of the Empire of Brazil, whilst the German, Austrian and Ottoman Empires all adopted the metric system in the 19th Century. Brian |
Thread: Advantages of Hackworth Valve gear? |
03/02/2018 08:39:51 |
How important are good valve events when notching up on small industrial narrow gauge locomotives that typically worked slowly and over short distances? I suspect that the answer will be as different for the prototype locomotives and for miniatures as the conditions in which they are operated, and that the manufacturers of industrial locomotives knew what their customers needed when they offered Hackworth valve gear. Brian |
Thread: Steam generator |
27/01/2018 09:15:01 |
Posted by vintagengineer on 27/01/2018 00:43:52:
The Me 163 was powered by Hydrazine, Methanol and water so why did they need to generate steam?
Did it use a steam turbine powered fuel pump like the V2 (which used a sodium permanganate catalyst in its steam generator)? Brian |
Thread: Recommended Shed suppliers |
26/01/2018 19:19:41 |
You could do worse than Tiger Sheds. They offer windowless options on their workshops, and if the pent shed my son bought is anything to go by their quality is pretty good.
Brian |
26/01/2018 19:12:39 |
Takes me back, I remember watching Vanishing Point at Santa Pod **LINK** Brian |
Thread: CE Mark - real and fake |
17/01/2018 11:49:02 |
Posted by Ian S C on 17/01/2018 10:17:35:
And after Brexit, will everything made in UK have to have "Made in England", like back in the good old days. Ian S C The Scots, Welsh and Irish might complain but M&S seem to agree: "Youv'e had your referendum and you're part of England now" **LINK** Brian |
Thread: Ships masts |
17/01/2018 09:47:24 |
Whatever technique was used, it (unfortunately for us) seems to be too commonplace for the Chief Constructor to mention it in the chapter on iron masts in "Shipbuilding in Iron and Steel" (from page 259 & table 7 on page 522) **LINK**. Hard to imagine that any kind of dolly or hydraulic rivet press could be inserted from the end to the full length of a section, especially if there was internal bracing as described in the book. Perhaps the back of the mast was supported so that a jam back could be used to snap the rivet? Brian |
Thread: Spot the fake |
16/01/2018 17:01:15 |
I can't get over how similar the 20 year old one looks to my Kennedy (from Cromwell Tools) of similar age. The only visible difference is the name printed on the casing. It seems to be a very good copy of the Mitutoyo. I don't think it has needed more than 3 or 4 batteries in all that time, although it has been asking for another for the last few months. Brian |
Thread: Arduino lcd display |
14/01/2018 10:13:47 |
Over Christmas we built the "Arduino Rotary Table for Dummies" from HMEM **LINK**. The instructions cover adjusting the contrast and checking the backlight is on before even installing the driver - sounds like the voice of experience Brian |
Thread: Lathe tachometer |
11/01/2018 10:01:34 |
I was quite happy as a lad with a selection of fixed speeds - there wasn't much other choice. After a 30-year gap, I realised I was turning much too slowly on my son's mini lathe, and it was likely that I would teach him the same bad habits, so a cheap Chinese tacho was an early addition. It probably only had a couple of month's use, as neither of us tend to look at it often now we have got the feel for the machine, but it was a useful teaching aid and well worth a tenner (including case) and a few minutes installation. If nothing else, its large red display serves as a reminder that the lathe is still plugged in when the lights are turned out Brian |
10/01/2018 09:48:10 |
Posted by Neil Wyatt on 10/01/2018 09:27:19:
Just to be mischievous... how do you know the right speed before you select it? In my case by a process of elimination Brian |
Thread: Intel PCs to be reduced in speed by up to 30% |
04/01/2018 11:47:00 |
Posted by Neil Wyatt on 04/01/2018 10:21:36:
Bear in mind this affects PCs running Windows, Linux and MacOS... in fact I can's see why it wouldn't affect XP on a modern machine. Time to move to an Rpi? Neil As I (barely) understand it, ARM processors are also affected, whilst although AMD say "There is a near zero risk to AMD products at this time", they may also be affected. Perhaps I should have kept my old Amiga Brian |
Thread: MEW263 - Postal non or late delivery? |
27/12/2017 10:45:49 |
Mine arrived (in Kent) 90 seconds ago, I guess they didn't take priority in the pre-Christmas mail. Brian |
Thread: Security |
22/12/2017 21:36:47 |
Posted by Brian Sweeting on 22/12/2017 21:29:28:
So, yes it is encrypted where it needs to be. It would be safer if the login page was also through a secure connection, as users might (unwisely) use the same user names and passwords elsewhere. Brian |
Thread: How on earth do they calculate electricity and gas bills... |
22/12/2017 12:05:08 |
Posted by the artfull-codger on 22/12/2017 11:46:53:
Smart meters what a load of crap, ... I beg to differ. Without one I would either have to submit readings every month (not easy when you are in a wheelchair and the meters are in a 2' high cupboard under the stairs) or be willing to pay on the basis of wildly inaccurate estimated readings for up to two years between meter readings. Brian |
21/12/2017 19:39:18 |
I think our smart meters use a mobile connection, they certainly aren't on either of my wireless networks, although they must have their own low-power network to provide regular updates to the display. The Hive control box is however on our (wired) network, but communicates with the thermostat and boiler controller using a low-power wireless connection, probably ZigBee. Brian |
Thread: A dongle dingle |
20/12/2017 14:46:49 |
To be honest dongles were a pain in the They aren't quite dead yet though, as the software for my vinyl cutter requires a USB dongle.
Thread: "It" comes to life again |
19/12/2017 09:16:54 |
Posted by Dean da Silva on 19/12/2017 05:18:07:
...Seeing the name Lickham Hall did crack me up a little bit, because instead of reading it as simply Lickham as one word in a state of semi-comical musing it came across as LICK-HAM which totally made me appreciate the name Lifford more. I guess you don't drop your 'aitches Dean Brian |
18/12/2017 21:22:18 |
After hours of searching, here is my AutoCAD R14 Dongle (edited to remove serial numbers). It is a NetSENTINEL manufactured by Rainbow Technologies, supplied to my former employers in 1998 and passed to me when they changed CAD suppliers so that I could maintain their older drawings. Although it has a parallel pass-through, only the computer end is labelled as such. Brian Edit: I could never get the software to run on Vista or later, and kept an old machine running Windows 2000 for AutoCAD until it was no longer needed. Edited By Brian G on 18/12/2017 21:24:38 |
