Windy | 26/01/2018 13:56:24 |
![]() 910 forum posts 197 photos | Looking at various ways of controlling high temperature steam came across this steam generator it's a bit old hat now but would solve many of the problem getting enough steam for record attempt turbine powered vehicles.
Edited By Windy on 26/01/2018 13:59:01 |
Carl Wilson 4 | 26/01/2018 14:05:25 |
![]() 670 forum posts 53 photos | That unit uses hydrogen peroxide. You would need at least 90 percent hydrogen peroxide. Any amount of contamination in this will initiate decomposition with massive heat release. Basically it will burn your house down. I looked into getting strong hydrogen peroxide for rocket engine use some time back. There was a plant making it in Sweden. It exploded taking with it one of the two proprietors hands. You need a home office licence to purchase and possess it. It's kind of more trouble than its worth. Edited By Carl Wilson 4 on 26/01/2018 14:06:48 Edited By Carl Wilson 4 on 26/01/2018 14:08:34 |
Carl Wilson 4 | 26/01/2018 14:12:52 |
![]() 670 forum posts 53 photos | It should be added that the catalyst zeolites are also insanely expensive. |
Windy | 26/01/2018 14:38:43 |
![]() 910 forum posts 197 photos | Full size speed record attempt machines have always a cost involved but there are speed enthusiasts in this country and abroad that have legally obtained hydrogen peroxide of required strength. Rocket mam Brown was using it some years ago. Even the Nitro you use if over a certain percentage for models and drag racing you have to have a license in my drag racing, sprinting days anyone could buy the 90% nitro. Edited By Windy on 26/01/2018 14:39:53 |
Carl Wilson 4 | 26/01/2018 15:06:58 |
![]() 670 forum posts 53 photos | Getting the home office licence to purchase and store is not that big a deal, but the storing of it in anything except a purpose built facility would be problematic in the extreme. It's classed as a hazardous chemical, a fire risk and an explosive ingredient as well as an oxidiser. You'd need proper facilities to contain any spills and to deal with them. So for anything less than a fully funded company with proper well founded premises it's a non starter. |
Windy | 26/01/2018 18:58:43 |
![]() 910 forum posts 197 photos | I understand with terrorist threats and H & S the need to control various chemicals. Wonder where it will all end this control as looking on the internet your supposed to be able to make explosions with house hold chemical products. Edited By Windy on 26/01/2018 19:11:03 |
Brian G | 26/01/2018 19:12:39 |
912 forum posts 40 photos | Takes me back, I remember watching Vanishing Point at Santa Pod **LINK** Brian |
Carl Wilson 4 | 26/01/2018 19:14:12 |
![]() 670 forum posts 53 photos | I know what you mean. However, 90% or high test peroxide ain't no household chemical. It will kill you soon as look at you. |
Samsaranda | 26/01/2018 19:31:29 |
![]() 1688 forum posts 16 photos | HTP, high test peroxide was used as fuel on the Blue Steel nuclear weapons carried by the RAF V Bombers in years gone by, very stringent safety procedures when using it to fuel the weapons, very nasty stuff not something to play around with at home. Dave W |
Windy | 26/01/2018 19:44:14 |
![]() 910 forum posts 197 photos | Carl did you consider using Nitrous Oxide for a liquid fuelled rocket here is a link to a rocket car powered using it and a common fuel Knights Arrow was at Elvington a few years ago I think it was it's owner who took a lot of interest in my steamer when I was doing a demo fire up. You never know there might be a flash steam car going up the drag strip someday.
Edited By Windy on 26/01/2018 19:55:25 Edited By Windy on 26/01/2018 20:05:30 |
Carl Wilson 4 | 26/01/2018 20:36:51 |
![]() 670 forum posts 53 photos | Yes I've looked at Nitrous Oxide as an oxidiser. I've also looked at the possibility of decomposing it over a catalyst to obtain hot oxygen gas. Unfortunately, even with the most active catalysts a lot of energy has to be put in to start the reaction. And the most effective catalyst zeolites are also prohibitively expensive. Nitrous Oxide would still be my oxidiser of choice, combusted in a conventional way. |
Carl Wilson 4 | 27/01/2018 00:36:35 |
![]() 670 forum posts 53 photos | Just as an aside that steam generator is an almost verbatim American copy of the Walter one in the Me 163 Komet rocket aircraft. |
vintagengineer | 27/01/2018 00:43:52 |
![]() 469 forum posts 6 photos | The Me 163 was powered by Hydrazine, Methanol and water so why did they need to generate steam?
Posted by Carl Wilson 4 on 27/01/2018 00:36:35:
Stuart Bridger | 27/01/2018 08:42:44 |
566 forum posts 31 photos | This book is a fascinating read into the history of liquid rocket fuel development. It does get a bit down in the weeds regarding the chemistry at times. Some very interesting engineering challenges, as well as some very hair raising descriptions of when things didn't go quite right. Very sobering when you read of the toxicity and instability of some of the stuff that they were using. https://library.sciencemadness.org/library/books/ignition.pdf
Edited By Stuart Bridger on 27/01/2018 08:43:10 |
Carl Wilson 4 | 27/01/2018 09:09:45 |
![]() 670 forum posts 53 photos | Why did they need to generate steam? To drive the turbo pump that pushed the fuel and oxidiser into the combustion chamber. The V2 also did the same, as did many other German rockets. The fact that it was a steam generator is incidental; it should really be viewed as a gas generator. |
Brian G | 27/01/2018 09:15:01 |
912 forum posts 40 photos | Posted by vintagengineer on 27/01/2018 00:43:52:
Did it use a steam turbine powered fuel pump like the V2 (which used a sodium permanganate catalyst in its steam generator)? Brian |
vintagengineer | 27/01/2018 11:29:00 |
![]() 469 forum posts 6 photos | They could have used silver and the hydrogen peroxide to produce the steam.
Ian S C | 27/01/2018 11:39:36 |
![]() 7468 forum posts 230 photos | Looks like something out of a Whitehead Torpedo. Now that the British government is to down size the armed forces, you might pick one up in a govt surplus store Ian S C |
Carl Wilson 4 | 27/01/2018 14:34:55 |
![]() 670 forum posts 53 photos | Yes vintage engineer they could have used silver. After the war Britain dud just that, not only to produce steam but for the rocket engine itself. The peroxide went through a silver catalyst into the combustion chamber. The oxygen gas and steam was then so hot it would ignite the kerosene that was then injected in. |
Carl Wilson 4 | 27/01/2018 14:35:48 |
![]() 670 forum posts 53 photos | Yes Brian it did. |
