Here is a list of all the postings Thor 🇳🇴 has made in our forums. Click on a thread name to jump to the thread.
Thread: Hello! |
06/09/2022 15:07:16 |
Hi Paul, Welcome to the forum. The mini-lathe should be able to handle larger work than making pens, I know of one who uses a Unimat 3 to make pens. Thor |
Thread: 7/32-40 UNS die needed |
05/09/2022 13:53:27 |
#12-40 is listed on eBay. Thor |
Thread: Professional grandad |
04/09/2022 16:44:17 |
Hi Nigel, Welcome to the forum. Even with the mini lathe you should be able to do much work. Thor |
Thread: Intro |
29/08/2022 13:54:21 |
Hi Jonathan, Welcome to the forum. What are your main interests? Thor |
Thread: new member |
27/08/2022 08:28:27 |
Hi Barrie, Welcome to the forum. You seem to have a well equipped workshop. Thor |
Thread: Rust, CI, Localised corrosion - gaskets ? |
26/08/2022 17:43:55 |
Hi Martin, Welcome to the forum. If the gasket material is porous it may have had some humidity in it when you mounted the gasket, if you used paper as gasket material some papers are slightly acidic. When I use paper gaskets I always impregnate the gasket with oil. Thor (How to post photos here) Edited By Thor 🇳🇴 on 26/08/2022 17:45:07 |
Thread: Hi or Low |
25/08/2022 10:09:03 |
Hi Eric, I too run my small milling machine in the low ratio, you get a bit more torque and as Mike says, less load for the motor. Thor |
Thread: Quick change toolpost |
23/08/2022 16:20:23 |
Hi Chris, Yes, you can as long as the cutting edge can be set at the lathe centre line. There will be a limit to the size of the tool. Thor |
Thread: Gear cutters |
22/08/2022 18:06:28 |
Hi Matt, All the modern gears I have come across are 20 deg. PA. DP or module is up to you, the gears I have made are all module based. The DP (or module) size depends on what the gears will do. I have made extra change gears for my small lathe - module 1 (DP 25.4), a clock would use a smaller size. You can make your own gear cutters if you want to save money. Thor |
Thread: Manufacturers lathe stand v making your own? |
16/08/2022 17:31:32 |
Hi Richard, Welcome to the forum. As you say, buying a stand saves you time, so it depends if you have the tools and time to make your own and save some money. Thor |
Thread: Warco GH1330 Advice |
15/08/2022 13:22:33 |
Hi John, Welcome to the forum. I assume you are familiar with Rollie Dad's method so you know the headstock isn't aligned with the bedways. If the headstock is misaligned there may be some screws that can be adjusted, although I haven't seen a misaligned headstock on a prismatic bed lathe. Thor |
Thread: Warco WM180 or Sieg SC3-400? |
15/08/2022 06:08:13 |
Hi Neil, I don't know why faceplates have such large slots, they make clamping more difficult. I have made a couple of faceplates, and on the first I made the slots much narrower, just over 8mm wide. On the second I made T-slots. Even on the faceplate of my 290 lathe I have never needed M16 bolts for clamping. Thor |
Thread: Meca universal dividing head D3627 |
10/08/2022 06:41:02 |
If you know how many turns of the handle to turn the spindle one revolution, there is a handy calculator here, it has two predefined heads or you can enter custom values. This will at least give you the tables needed for dividing. Thor |
Thread: shaper |
10/08/2022 06:21:12 |
Well done. Thor |
05/08/2022 07:25:23 |
Hi Reginald, Welcome to the forum. Thor |
Thread: Hi all. |
04/08/2022 10:41:07 |
Hi Mike, I have sent you a PM. Thor |
04/08/2022 06:44:16 |
Hi Garr, Welcome to the forum. I agree with Jeff, Elmer's simpler engines should be a good start, I have made one of his oscillators. Stew Hart (a forum member) has designed steam engines that are suitable for befinners. In addition to the link Jeff provided; here are a few other links to free plans: ***Link*** (simple oscillator)
Thor
Edited By Thor 🇳🇴 on 04/08/2022 06:44:56 |
Thread: Engineered fuel prices |
02/08/2022 14:52:25 |
Well Bryan, it is not only in the UK fuel is expensive, our fuel prices this summer are the highest I have seen. As business returned to more normal levels after Covid-19 increased demand has driven the price of crude oil up. I guess the war in Ukraine has had an impact also although prices increased before the war started. Thor |
Thread: Soft jaws |
29/07/2022 11:06:38 |
There is one solution at Mike's workshop, that may be of help. Another here. Thor Edited By Thor 🇳🇴 on 29/07/2022 11:08:38 |
Thread: Coincidences |
28/07/2022 06:23:43 |
Well, coincidences happen I guess, a few weeks ago when I was out for a walk I met my former boss who I hadn't seen in a decade. Thor |
