first post
barrie Williams | 26/08/2022 22:34:25 |
11 forum posts | hi greetings from billericay looking forward to benefitting from the experience i see here. barrie |
barrie Williams | 27/08/2022 07:06:41 |
11 forum posts | workshop machines : harrison m300 lathe XYZ cnc mill with protoTrak
barrie Williams | 27/08/2022 07:08:38 |
11 forum posts | also have 3 axis cnc router with er16 collets high speed spindle (24,000 rpm) |
Thor 🇳🇴 | 27/08/2022 08:28:27 |
![]() 1766 forum posts 46 photos | Hi Barrie, Welcome to the forum. You seem to have a well equipped workshop. Thor |
barrie Williams | 27/08/2022 08:31:54 |
11 forum posts | thank you for the welcome Thor .
yes , i have a very good local machinery dealer who takes into consideration my hobby status when pricing .
cheers. |
Harry Wilkes | 27/08/2022 08:52:45 |
![]() 1613 forum posts 72 photos | Welcome to forrum H |
barrie Williams | 27/08/2022 08:53:42 |
11 forum posts | thank you Harry
barrie |
noel shelley | 27/08/2022 10:27:39 |
2308 forum posts 33 photos | Welcome to the party ! If you have questions then just ask - someone will be able to help you ! Noel. |
barrie Williams | 27/08/2022 10:28:43 |
11 forum posts | thank you noel.
much appreciated
barrie |
Howard Lewis | 27/08/2022 16:51:27 |
7227 forum posts 21 photos | Welcome Barrie You are in good company here, either to help or be helped. Most probably the former, judged by your equipment. Howard |
barrie Williams | 27/08/2022 21:57:20 |
11 forum posts | thank you howard happy to learn and to share . it’s enjoyable and helpful both ways.
barrie |
Graham Williams 12 | 28/08/2022 09:07:58 |
55 forum posts | Posted by barrie Williams on 27/08/2022 08:31:54:
cheers. Welcome Barry, that’s great having a dealer like that near you. I used to use a XYZ with Prototrak (2 and 3 axis) at work - great machines which I sorely miss. Really wanted to get one for my home workshop but in the end it was the added cost of having 3 phase installed that was the deal breaker for me. have fun Graham |
barrie Williams | 28/08/2022 09:36:57 |
11 forum posts | hi graham
i had the same issue with three phase. the company wanted over 12 grand to supply me.
so i went to DrivesDirect and got great service and a reasonable price. i think i paid under £3k.
but unlike small inverters which are “one per machine” this one supplied the entire workshop.
and the xyz is basically a 110v machine so all the controls, the cnc servos work from a 13amp plug top. |
Graham Williams 12 | 28/08/2022 09:54:21 |
55 forum posts | Hi Barry, very interesting. That’s a good solution which I will keep in mind. Thanks Graham |
barrie Williams | 28/08/2022 10:22:52 |
11 forum posts | graham may be you could give me a tip ?
whsts there are no xy locks so i need to run a program to enable and lock the servos to hold position.
thanks |
old mart | 28/08/2022 15:44:29 |
4655 forum posts 304 photos | Welcome Barrie, with your equipment, you will be able to give the rest of us advice as well as benifitting from it. |
Graham Williams 12 | 28/08/2022 16:29:37 |
55 forum posts | Barry I haven’t been in the employ of the company where I used the XYZ,s and no longer have access to them or the manuals. Pity or the would be quite a few “homer’s” going through the work shop. I think you must be referring to the small sequence that you can run every now and again to dial out the backlash in the lead screws. Obviously no clamps so just relying on holding torque of servos and minimal backlash. Graham |
barrie Williams | 28/08/2022 17:33:59 |
11 forum posts | thanks Graham
yes that’s exactly it. just a line of code that tells the servos to “brace themselves” for a heavy cut.
cheers |
barrie Williams | 28/08/2022 17:38:41 |
11 forum posts | thank you ‘old mart’ im in awe of what can be achieved with engineering ingenuity and limitless patience, two qualities which i see in all the model makers i’ve met. |
