Here is a list of all the postings RichardS has made in our forums. Click on a thread name to jump to the thread.
Thread: Boxford AUD Chuck Quandary |
16/02/2022 19:59:21 |
ARC Eurotrade, RDG & Chronos all have offered, at times, Boxford backplates ready for final machining and fitting. Whether they have them when you need one is another matter. College Engineering Supply used to supply unmachined plates in various sizes. The ARC website has a link to an article on how to fit a chuck to a backplate: https://www.arceurotrade.co.uk/reviews/Backplate%20Fitting%20-%20MEW%20141.pdf I agree with Oldiron that the largest you can go with a general purpose chuck on a Boxford is 5" so as the cross slide can pass under. Also I concur with Clive Foster about "A 3 jaw isn't a precision device", I would put it slighty differently ""a 3 jaw is a device to hold a round workpiece approximatly concentrically". My largest chuck is an 8" full fat 4 jaw. The saddle wings clear but the cross slide does not. Also the position of the jaws has to be watched to avoid fouling on the saddle wings. |
Thread: boxford lathe upgrade? |
23/08/2021 15:51:12 |
The leadscrew on a C does not have the drive keyway. You will need to swap out at least the apron as well if you want power feeds. |
Thread: Pop device |
07/07/2021 13:53:09 |
Air cannon Hawkins Bazzar? |
Thread: Boxford Model A |
01/07/2021 20:27:51 |
As suggested by BrianH https://groups.io/g/BoxfordLathe-UserGroup You will have to join the group and login. The file you are looking for is boxford_know_your_lathe.pdf There are parts lists but you will need to try them as thay have multiplied over the years. |
Thread: Model Engineering Website |
08/06/2021 19:26:19 |
Howard beat me to it. They are on the 3rd DVD listed here https://www.modelengineeringwebsite.com/MEWS_DVD.html |
Thread: Boxford C - removing headstock |
15/05/2020 19:42:22 |
Just to a little to Pete Rimmers comment. You will probably need to shorten a spanner to loosen/tighten the clamp bolt at the RHS of the headstock. Before you refit the headstock, clean the bedways where it normally sits, clean the mating faces of the headstock, lubricate both with slideway oil and wipe off the excess. Before you tighten the the clamp bolts check for changewheel alignment. |
Thread: Alum as metal remover. |
07/01/2019 14:11:13 |
A rummage in my bookmarks leads here: https://www.trustleaf.co.uk/aluminium-sulphate---iron-free-503-p.asp Aluminium Sulphate 17% AL2O3 Iron Free Tge concentration I used: 2 table spoons (30 ml) in a 720gm Branston Pickle jar ('cos it's "pickling"). Remember to keep it warm. |
19/12/2018 09:19:41 |
1. Yes it works on HSS 2. Keep it warm (think coffee cup heater) 3. Replenish with water each day to make up for evaporation 4. Have the opening at the top 5. At 8BA you will need to initially encourage circulation in the hole (syringe?) 6. Clear debris from hole daily 7. Use a glass jar so you can see the bubble stream. You should get a fine stream of bubbles rising from the hole (might be very fine or intermittant at 8BA). When that slows clear the debris. If clearing the debris does not result in a stream of bubbles after a couple of hours then replace the solution. If replacing the solution does not result in a stream of bubbles then it is probably done. |
Thread: Backlash Allowances for Gears |
13/09/2018 12:40:26 |
On a Boxford the tumbler gears can be 14 1/2 or 20 deg PA and the changewheel train is 14 1/2 deg PA. The tumbler gears drive the stud gear spindle and thus never come into mesh with the changewheel chain. Edited By RichardS on 13/09/2018 12:41:00 |
Thread: Injector Testing Valve |
23/08/2018 11:39:32 |
Probably get myself banned from the forum for this. Engineering in Miniature December 2011 Page 195 All you need to know about Miniature Ejectors and Injectors Bob Bramson There is a diagram of the principle of the Bill Carter "quasi check valve" but no constructional detail. I think Bob Bramson wrote a book on the subject. |
Thread: Dimensions for Ball bearing Valves |
10/08/2018 12:07:45 |
On the probably mistaken guess you mean a simple ball type check valve, does this help? http://ibls.org/mediawiki/index.php?title=Design,_Care_and_Feeding_of_Check_Valves |
Thread: Boxford CBS screw cutting charts |
17/05/2018 14:21:43 |
Try this thread http://www.model-engineer.co.uk/forums/postings.asp?th=124071 Posting by Robbo at 19/01/2017 23:24:07 Titled: Boxford Model B&C Lathes Also can be found in the Boxford "know your lathe" book. Richard |
17/05/2018 12:52:24 |
Hi Stephen Do you mean a Boxford CSB? If so then the necessary info is available in the Files section of the Boxford Lathe Yahoo group (you will need to join the group and yes, I know the user interface is very poor). However, you say there is no screw-cutting on the lathe. Does it have a leadscrew? If not then what you have is a training lathe and adding screw-cutting means finding, at minimum, a leadscrew with bearings, quadrant, an apron, tumbler set and changewheels. This website will help with identification http://www.lathes.co.uk/boxford/ Richard |
Thread: How to remove a chuck from a Boxford model A |
01/05/2018 12:36:55 |
Ian My guess is that if 3 out of 4 jaw screws are broken then you are down to unbolting the chuck. From there then WD40/paraffin/3-in-one on the end of the thread might loosen the backplate. Alternatively remove headstock from lathe and stand nose down in a tray of diesel. Last ditch, machine the backplate off. To remove the headstock. Remove the right hand layshaft bearing holder, this allows you to get the belt off the layshaft. Remove the changegear cover. Remove the banjo. Release the two headstock clamp bolts that are under the headstock between the ways. The front one will need a _short_ (4" long) spanner. If the belt is currently tight then the belt tensioner is incorrectly setup. You will probably need to take the belt off the layshaft to fix. The mechanism is basically a pin in a spiral groove and the tensioner quick release lever should be pointing straight down when tight. The quick release lever passes through a threaded bush in the front of the bed support that sets the tension. More info about the belt tension mechanism can be found in the boxford parts list pdf in the file section of the Boxford Lathe group on Yahoo groups. Hope that helps. |
Thread: Identifying change wheels |
04/12/2017 20:21:37 |
The ones with a 5/8" bore are used on the banjo and are missing their running bushes. |
Thread: halloween |
31/10/2016 18:45:09 |
A couple of garden irrigation sprinklers, solenoid control valve set to 10 seconds "ON" time, connect to the doorbell. Magic. Especially with a "No Trick or Treat" notice on the door. They push the doorbell _then_ read notice while they get wet. Double magic. |
Thread: UK Boiler regulations |
15/09/2016 11:40:56 |
John Do these links answer your questions. http://www.sevenandaquarter.org/about-us/?/boiler-testing/73 http://www.sevenandaquarter.org/media/documents/boilertestcode2012v12a.pdf |
Thread: Old Boxford Lathe |
14/08/2016 16:52:52 |
Model C from 1950/51/52 (confused numbering during that period). More information available on the Boxford Lathe group on Yahoo, e.g. Parts list, manual, images of things like the missing speed setting plate on the headstock. If your "faceplate" has one open ended slot then it is probably a catch plate for driving work between centres. The face plate has 6 or 8 closed end slots. Regarding the grease points. If "lubricated for life" bearings were fitted then yes, no grease would be needed, however if there are broken remains in the holes then they need to be extracted and new grease points fitted. Be wary of using the belt tensioner as a clutch (we all do it) as the belt can occaisionally catch and spin the chuck just when you don't expect it (guess how I know ![]() |
Thread: Does anyone hire out a portable track |
11/05/2016 10:45:46 |
Needed to amswer the same question a couple of years ago. Try here for a start: http://www.miniaturerailwayworld.co.uk/PortableMiniatureRailways.html Can not make a recommendation as it did not happen in the end. Do bear the comments made by Bazyle in mind. |
Thread: Boxford CUD change gears, feed speeds and levelling. |
31/12/2015 15:15:48 |
The 46T changewheel is only used for 11 1/2, 23, 46, 92, .. The Boxford, Smart Brown, Hercus are all copies of the South Bend see the write up on http://www.lathes.co.uk/boxford/ Bookmark the above URL on the inside of your eyelids. Don't worry too much about what gears came as standard, more important is that you have the gears to cut the threads you need. > should the gears have a washer between them and the nut? On my lathe there is a washer (well more of a short spacer) on the stud, ensures the nut does not come in contact with the gear on the idler. For the end of the leadscrew many use a spare changewheel as a spacer. The idler/compounds have a washer. The only duplicate changewheel needed is 32T, and then only for 8TPI. On a Mk I you can not close the changewheel cover with a 100T on the leadscrew. |
