Identifying change wheels
wolrikm02/12/2017 19:46:19
36 forum posts
A friend has asked if I can identify these gears for him. There came with his ML7 but are obviously not for that lathe. He wants to try to sell them, so any help identifying them would be appreciated.
Hopefully I am attaching a photo, but the gears are as follows:
100/127 compound with 5/8" bore
54/18 compound with 5/8" bore
80 with boss and 5/8" bore.
The rest are all 9/16" bore with 1/8" keyway - 32 (2 gears), 36, 40, 46, 48, 52, 54, 56, 60 (4 gears) gears 2.jpg
Eric Arthrell02/12/2017 20:47:18
47 forum posts
19 photos
What is the overall dia in inches of the 100 tooth gear ?
Regards Eric
wolrikm02/12/2017 20:56:00
36 forum posts
5.665" with my Lidl caliper
Eric Arthrell02/12/2017 22:21:26
47 forum posts
19 photos
Hello wolrikm ,
I make that 18dp ? for the 100 tooth one no good for my Murad.
Eric
wolrikm02/12/2017 22:55:45
36 forum posts
Mystery solved, I think. Looking at the change wheels Tony sells on lathes.co.uk, they are Boxford.
larneyin04/12/2017 19:16:50
17 forum posts
19 photos
Look like Boxford to me
mick7004/12/2017 19:36:32
524 forum posts
38 photos
will they fit southbend 9" model c?
if so could be interested as got one needing restoration when i get new workshop
Clive Foster04/12/2017 19:50:16
3630 forum posts
128 photos
mick70
Size of Boxford change wheels is fine on a SouthBend C but I'm pretty sure the pressure angle is different so you will need to have a whole set. I think my C actually had Boxford gears. About 35 years to late to check tho'.
Clive.
Bazyle04/12/2017 20:01:56
6956 forum posts
229 photos
Regular old Boxford gears have a 9/16 bore. It may be the specials like the 127 are different, or it may be that South Bend are 5/8 bore. Both will be 14.5 pressure angle and 20 DP, The new gear head larger Boxfords are possibly metric module gears wit 20 degree angle.
But there will be other lathes that are similar. We could do with a cross reference table.
Oldiron04/12/2017 20:09:29
1193 forum posts
59 photos
mick70. If you want to fit them on your SB "C" you will also need the 16, 18, 20, 22 & 24 tooth Boxford gears as they are usually first in the drive train on the stud gear. Especially if you want to cut metric gears ( along with the 100/127 conversion gear). Smaller sizes can be picked up on Ebay reasonably priced.
regards
wolrikm04/12/2017 20:20:11
36 forum posts
Posted by mick70 on 04/12/2017 19:36:32:
Someone will know, but I'm afraid that someone isn't me.
edit: oops, I didn't notice the posts after yours
Edited By wolrikm on 04/12/2017 20:22:18
RichardS04/12/2017 20:21:37
33 forum posts
The ones with a 5/8" bore are used on the banjo and are missing their running bushes.
