banjo bob | 21/08/2021 12:29:44 |
1 forum posts | Hi awaiting delivery of a boxford cud , can this be "upgraded" to aud level using parts from a damaged aud? thanks |
Hollowpoint | 21/08/2021 22:45:59 |
550 forum posts 77 photos | Yes and no. I believe most of the parts are interchangeable but IIRC some AUD models are 5" inch centre height while the BUD, CUD etc is 4.5" inch. |
Gavlar | 21/08/2021 23:24:13 |
119 forum posts 1 photos | All the parts are interchangable. MK1 and MK11 Boxfords are 4.5" and the MK111 is 5". It doesn't matter if it is an A, B, or C model. The gearbox is pretty much the same from the earliest rear drive models up to the last of the underdrive models and will be interchangable, regardless of centre height or age. The 5" models have a slightly taller headstock, thicker base to the tail stock and a slightly meatier compound to make up the extra height. Other than that, no real differences. The B and C models even have holes drilled in the bed to mount the gearbox without modification. To upgrade a C to an A you would need the gearbox, leadscrew (you may be able to modify the original leadscrew) and apron. I think the saddle is the same but I'm not sure as the C didn't have power cross feed. It might just need an the cross slide leadscrew swapped over.
Edited By Gavlar on 21/08/2021 23:38:06 |
Bazyle | 22/08/2021 19:59:54 |
![]() 6956 forum posts 229 photos | There are various different bed lengths so the leadscrew RHS end support might not line up but any competent engineer can sort that out. |
Clive Brown 1 | 22/08/2021 20:36:56 |
1050 forum posts 56 photos | I upgraded my 5" ME10 from "B" to "A" spec. by fitting a gearbox from an older 4.5" lathe. No problems, the main job was shortening the leadscrew to connect to the gearbox output shaft. As it will pass through the spindle, machining was straightforward. I assume that the "C" lathes have the necessary drive keyway in the leadscrew even though the longitudinal feed uses the half nuts. |
RichardS | 23/08/2021 15:51:12 |
33 forum posts | The leadscrew on a C does not have the drive keyway. You will need to swap out at least the apron as well if you want power feeds. |
