vintagengineer | 01/09/2023 12:19:11 |
![]() 469 forum posts 6 photos | I am building GN cycle car engine with some OHV heads. I am stuck on how to calculate the valve spring length and poundage? |
HOWARDT | 01/09/2023 12:41:10 |
1081 forum posts 39 photos | Is the force you need for the spring or the spring details? |
Roderick Jenkins | 01/09/2023 13:24:20 |
![]() 2376 forum posts 800 photos | If you are trying to determine the spring force that you need to keep the cam follower in contact with the cam then you need to know the weight of the valve gear being moved and the acceleration due to the cam at the maximum speed of the engine - Force = Mass x Acceleration. If the cam has a flat follower than CamCalc can help give a figure for the theoretical maximum acceleration which will act as a starting point for determining the correct spring size. Rod |
duncan webster | 01/09/2023 15:07:00 |
5307 forum posts 83 photos | Should you add half the mass of the spring as well? Make a guess in the first place as the design isn't fixed |
john halfpenny | 01/09/2023 18:44:18 |
314 forum posts 28 photos | Why not look at similar vintage engines?
