Here is a list of all the postings Phil P has made in our forums. Click on a thread name to jump to the thread.
Thread: What lathe |
22/01/2021 20:07:52 |
I think you may have joined the wrong forum, it is obvious that no one on here is going to be able to help you. Phil |
Thread: Bench Top Honing & Lapping Machine |
20/01/2021 17:21:14 |
Gray That looks very interesting indeed, my late father had a full blown Delapena machine and it was used quite a lot back in the day, the cylinders for my mill engine Agnes were done on it, so I know they are as good as I can get. I will be watching this with interest. Phil |
Thread: Surface/ Marking out plates |
20/01/2021 09:49:16 |
It sounds like you might have a lapping plate. The grooves are so that the lapping compound has somewhere to go. Phil |
Thread: Hello from Yorkshire (another one !) |
13/01/2021 07:08:00 |
You guys from West Yorkshire might like to consider joining a local club, I can highly recommend the Bradford club. https://www.bradfordmes.uk/ We have members from all walks of life with many varied interests, not just railway loco's like a lot of clubs seem to concentrate on. Obviously things are on hold at the moment, but hopefully in a few months we can resume. We have regular monthly meetings during the summer at various outdoor venues, and guest speakers during the winter months, along with a couple of auction nights where you can top up on Phil
Thread: Interest in pictures of models |
12/01/2021 14:01:49 |
Br Is your model Allchin actually 3/4 scale, or is it really 3/4" to the foot ? or 1/16 scale ? Phil Edited By Phil P on 12/01/2021 14:03:41 |
Thread: help identifying gear module or dp |
09/01/2021 10:17:51 |
I have shown a few of my friends in the local model engineering club what can be done very quickly in 3D CAD and they are all totally amazed. I used Autocad 2D for a lot of years before we transferred to Solidworks 3D at work in 2005, every now and then I have to make change on an old Autocad drawing and it beggars belief how we ever managed to produce anything with it. Another 100% thumbs up for 3D from me. Phil |
Thread: Removing powder coating finish from metal. |
08/01/2021 21:04:01 |
Frost Auto restoration used to sell a powder coating dissolver but I cannot see it on the website now, they do have a product called "Tank Strip" that claims to remove any coating from any surface. Phil |
08/01/2021 12:12:18 |
I dont know about anyone else, but I find those drawings with everything crammed onto a couple of sheets are really confusing and unclear. In my job at work I have to produce sets of drawings for complex bespoke machines, and if I issued them in this format I would be shown the door pretty quickly. It is one sheet per part where I work, and that is how I do my own personal drawings as well. I suppose model engineers are more tolerant of this kind of thing than is the case in an industrial background. Phil |
Thread: A finished project - at last! |
05/01/2021 13:44:30 |
Posted by Brian H on 05/01/2021 13:01:16:
When it is open again, there is a working Corlis engine here; ( at least, I think it's a Corlis) Brian Edited By Brian H on 05/01/2021 13:04:14 Brian That one is a Pollitt & Wigzell called "Agnes" and is the very one I am currently building a 1/16 scale model of. Phil |
Thread: GHT Rear Toolpost 8deg milling cutter |
04/01/2021 12:03:00 |
Posted by not done it yet on 04/01/2021 10:33:02:
Just for completeness (from my experience), - my advice would be to avoid those ‘cutters at an angle’ designs like the plague. I have one (bought as part of a set when I bought a QCTP but I only used it a couple of times. I know overhang with parting tools needs to be kept to a minimum. Changing the extension of the blade needs the tool height resetting every time the cutter is moved. No thanks, that type is not for me. I’ll stick to a parallel holder! My rear toolpost is a QC one that has height adjustment so the extension of the tool blade can very easily and quickly be set to the correct height. Phil PS. I just noticed on your profile you are into Moggie Minors, what do you have ?.... I have a 1969 Traveller
Edited By Phil P on 04/01/2021 12:09:33 Edited By Phil P on 04/01/2021 12:10:33 |
03/01/2021 22:19:42 |
Just for completeness here is the information on my other parting tool holder that takes a conventional HSS blade which is retained with a wedge. These have given trouble free service for a few years now. Phil |
Thread: New Member in Yorkshire |
01/01/2021 12:56:35 |
Hi Chris. Welcome to the forum. Phil |
31/12/2020 23:20:11 |
I made a holder for an inserted tip parting blade that fits my QC rear toolpost on the Myford. Here it is along with my drawing if it is of any interest. Phil Edited By Phil P on 31/12/2020 23:22:27 Edited By Phil P on 31/12/2020 23:23:52 |
Thread: Clayton wagon valve gear |
31/12/2020 13:53:49 |
Is Bernard Lundberg still alive ? He came to see me many many years ago, but I have not heard anything about him for a long time now. Phil
Thread: 3 leg hone |
29/12/2020 11:18:34 |
They will not correct any ovality in a bore like a true Delapena type hone would, being spring loaded they just follow what is already there. Phil |
Thread: What air compressor should I buy? |
27/12/2020 14:01:43 |
Clive Just had a read back through this thread and on page 1 you say that you are using your Guyson cabinet to blast at well over 100 psi. I would say that is way too high and you should normally be able to use half that pressure. You may well accelerate the time taken to do the job, but the blast media breakdown rate will be terrible and you will use a lot more of it. You will also be causing a lot of internal wear to the gun and anything in contact with the moving blast media. How do I know this ?.....Well I have been chief design engineer at Guyson's for nearly 33 years and I have picked up a few things along the way. My forte is designing the big automated and robotic stuff for production line work, but the basic principles are exactly the same as on the small hand cabinets. One easy way of getting more from less so to speak, is to get a bigger or additional reservoir on the compressor. I will soon need to get my own blasting facilities sorted out, when I retire I will lose my free access to all the equipment at work. Phil |
Thread: Clarkson Radius Grinding Fixture |
26/12/2020 22:05:04 |
I just checked mine earlier this evening and it is definitely 1.5" bore. It looks to be original but I suppose someone could have bored out before I got it. Phil |
26/12/2020 13:57:34 |
Posted by DC31k on 26/12/2020 13:14:40:
Posted by Phil P on 26/12/2020 11:38:07:
This is the explanatory sketch I did at the time. What the sketch is depicting is true, but is it not mislabelled? Where it says 'initial setup', that should say 'final cut' or 'sparkout pass'. So you start with the wheel further from the pivot point than your final dimension and gradually advance until it hits a stop at the correct place. If you go beyond that point, as you say, you will end up with an undesirable result. Conceptually, it is similar to using a vertical axis ball turner on a lathe. You turn the stock to the diameter of the ball, advance the cross slide until the pivot is under the workpiece centreline, then advance the cutter until it touches the OD of the stock. Note the cross slide reading or set a stop at that point. Then you can back off the cross slide and work inwards to your stop, sure that you will end up with the correct diameter ball.
------------------------------------------------------------------------------------------------------------------------------------------------- Yes I get what you mean, I must admit I did that sketch before i was in possession of any Clarkson instructions a good few years ago. I think the method requires that the cutter to be re-sharpened is ground back sufficiently first so that when the setting button is used with the slip gauges, that will be the new datum to grind the radius back to as described. I have never actually got round to modifying my own attachment yet, it is still sat on the shelf unused.
Phil
Edited By Phil P on 26/12/2020 13:58:15 Edited By Phil P on 26/12/2020 13:58:47 Edited By Phil P on 26/12/2020 13:59:28 |
Thread: Gear Cutting |
26/12/2020 11:58:55 |
Martyn The angle stated on the cutter is the tooth pressure angle and is more often than not either 20° or 14½°. You will need to work out the cutter required from the finished diameter of your coupling and the number of teeth required on it, so it will be the DP (Diametral Pitch) number if using imperial cutters, or the M (Module) if if using metric. Have you seen these by the way, it might save you some time. https://www.vintagecarparts.co.uk/categories/vintage-car-parts-miscellaneous-vernier-coupling Jason........... Have a look at the above link, you can see that on the Simms outer couplings the gap is parallel and the tooth is tapered, The inner coupling that sits between them has parallel teeth. Phil Edited By Phil P on 26/12/2020 12:02:50 Jason......You just beat me to it with your correction Edited By Phil P on 26/12/2020 12:04:12 |
26/12/2020 11:38:07 |
I had an "interesting" debate with an expert on one of the forums a few years ago about the radius grinding fixture. The debate was on how one should apply the cut after each new pass on the grinding wheel the expert said that you apply the cut by advancing the table of the cutter grinder as you would in most other cases. Mt argument was that if you do that the finished radius with get progressively smaller as you are moving the pivot point closer to the wheel. This is the explanatory sketch I did at the time. What is needed is a way of advancing the cutter holder forwards on the grinding fixture, the mk2 head has the tenon in line with the angled holder so that could be achieved, but I plan on making mine with a fine adjustment screw built into the design. That might be something you want to think about. If you need an instruction manual for the radius attachment mk1 or mk2 let me know by PM. Phil |
