Here is a list of all the postings peter ravenscroft has made in our forums. Click on a thread name to jump to the thread.
Thread: z axis arduino |
02/12/2018 14:02:17 |
hello the error i get is exit status 1 error compiling for board arduino/ genino uno it will load the the script with hello- world so know it is comunicating with the board and loading i think there is an error in the program regards pter |
02/12/2018 13:38:16 |
hi has anyone tried to up load the program (sketch ) for the z drive in mew no 275 as i can not get it to load keeps coming up with error all the time regards peter |
Thread: manual to cnc |
15/05/2018 18:55:55 |
hello all many thanks for your advice i should have taken silly old duffer's advice you have to read it very carefully i got there eventualy it is very arkward to say the least will let you know how i got on regards peter |
14/05/2018 17:46:56 |
i already have the driver i do not think it is the driver as it will load other programs i have used several arduino units the last on being a dividing head which works ok thanks for your help regards peter |
14/05/2018 14:55:45 |
hi can anyone help me i have bought an aduino and i am trying to load the program grbl as recomended by the article but all i get is copy error message the ardiino will load other programs no problem i am wondering if anyone else has had a problem trying to load grbl regards peter |
Thread: John wildings great wheel skeleton clock |
17/11/2017 18:09:32 |
have you seen the series on you tube about building the great wheel clock it is in about 24 parts good viewing search for clickspring it may help you as it is very detailed regrads peter |
Thread: Arduino Rotary Table MEW 249 |
11/02/2017 12:38:33 |
hi i thought you might like to see my offering of my dividing head based on the chuck felllows deign with the software from the one in model engineer workshop regards peter |
Thread: Miniature pressure gauges |
13/01/2017 18:25:14 |
Andrew you will find a whole chapter on making pressure gauges in one of kozo's books i think it is the heisler but i am not sure regards peter |
12/01/2017 18:03:32 |
thanks carl regards peter |
11/01/2017 18:11:19 |
hi john is that the way you connect remote switches as i am about to wire up a control box when the switches arrive hopefully i'll have a unit working shortly regards peter |
10/01/2017 18:27:16 |
hi john if daves dont work try 50 btn right 195 up 380 down 555 left 799 select i had the same problem but is now ok regards peter |
Thread: swiss molly by don young |
18/10/2016 18:06:02 |
hi has anyone built or seen a Swiss molly designed by don young or have a photo of one as i am thinking of building one regards peter |
Thread: Showmans engine generator |
09/10/2016 11:11:10 |
there is one described in the construction articles for the Darjeeling loco based on a hand wound torch i have built on and it works ok regards peter |
Thread: tony hills dividing device |
27/05/2016 17:56:01 |
many thanks neil my friend bought one on Sunday at Doncaster but does not have Internet regards peter |
26/05/2016 17:05:01 |
hi can anyone tell me where the downloadable files are for the Tony hills dividing device are as is in the latest edition of model engineer workshop as i can not locate them regards peter |
Thread: Doncaster Model Engineering Show |
22/05/2016 16:58:09 |
just a note to say many thanks for regrinding my rather abused milling cutters what a superb job regards peter |
Thread: The Manchester Model Engineering Exhibition |
27/02/2016 15:04:18 |
i parked in a street around the corner only a 5 mins walk regards peter
Thread: non delivery of magazine |
04/02/2016 15:21:30 |
arrived today ( Thursday) many thanks regards peter |
Thread: Railmotor 3 |
02/02/2016 18:03:51 |
hi if you make the railmotor 3 make sure of the position of the turret bush on the boiler as the platework will foul it when erecting it regards peter |
02/02/2016 11:46:01 |
hi can anyone help me i have not yet received my latest issue of model engineer can someone give me the number to call to rectify this regards peter |
